Question about Garden
Ariens 1440h cutting problem
I have an ariens 1440H riding mower and the tension pulley spring popped off. Does anyone have a belt diagram for this and where the spring clips to?
  • 389 Answers
ariens 1440h cutting problem - moz-screenshot.jpgGo to this site: http://www.ariens.com/corporate/pages/partsradar.aspx (copy and paste in your address bar)
follow the instructions given and you can download a VERY GOOD picture of where it goes
Posted on Sep 29, 2009
Spring mount location for belt tensioner for murray 45256x92a
Try this site to get your manual and see if the exploded parts diagrams help
Mar 30, 2015 | Murray Garden
How to I tell if the tension is correct on a Arien zero turn belt?
Most modern lawn mowers including ZTRs all using an automatic belt tension system; ie spring load idler pulleys. The only time you need to check the belt is when your are having problem and most time the belt will need replacing due wear or physical damage.
Nov 29, 2014 | Garden
How to relace drive belt on ariens tractor a20va46?
There are multiple belts on the Ariens A20VA46 lawn tractor. Which belt are you asking about?
Service and Owner's manuals can be downloaded from the following link: Find Manuals by entering your tractor's model and serial numbers.
The deck drive belt is easy to change by releasing spring pressure on the idler pulley (usually under a plastic cover). See the user's or service manual for directions from the above link.
The two transmission belts are somewhat more difficult, but are usually long-lasting. The newer type of continuously variable transmissions used on these tractors have a friction belt like a snowmobile but under much less load. As a result, they are long-lasting. The engine to transmission belt is a conventional V-belt and may require occasional replacement. Usually, there's a similar tensioner pulley you would release in order to replace this belt.
Jul 14, 2014 | Ariens 34 In. Zoom Series Riding Mower
Ariens Sierra 1440H Lawn Mower
the solenoid is sticking inside the housing
Apr 30, 2010 | Ariens Lawn Mower Universal Solenoid...
Belt systme view - how all belts are hooked up
you have 2 pulleys going to the blades, 1 pulley coming from the pto, and a belt tensioner. the belt goes on the outside of the pto, outside left side blade, inside belt tensioner, out side right side blade.
Aug 16, 2009 | Ariens 34 In. Zoom Series Riding Mower
Blade belt diagram for John Deere LX178 Riding
Remember the belt rule, V of the belt goes in V pulleys.Flat pulleys that are stationary or move get the back of the belt. You can figure it out. Its not rocket science. Remember at some point there has to be a tensioner,usually gets the back of the belt if its a flat pulley. U may have to remove the spring and then reattach the spring after the belt is routed.
Jun 07, 2009 | Garden
Ariens sierra 1440G belt configuration
Hi, you may have more than one problem. There should be one belt from the mower deck going to the electric clutch pulley which is on the engine shaft. On the shaft there are two pulleys, one belt comes from the mower deck, and the other comes from the transaxle pulley. check to see if your belts are in the right areas.
If this doesn’t work for you, please write back. Thanks,
Nov 27, 2008 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
515 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
