Question about Proform Exercise & Fitness
Treadmill keeps shutting the power off randomly. it's not the circuit breaker on the frame. there is no burning smell.
  • 40 Answers
It's overheating, you need to lube the belt, and it may be too tight as well.
Posted on Sep 29, 2009
No power
Check the reset/off circuit breaker located on the
treadmill frame near the power cord. If the switch
protrudes as shown, the circuit breaker has
tripped. To reset the circuit breaker, wait for five
minutes and then press the switch back in.
Mar 07, 2014 | Proform XT 70 Treadmill
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
A2550 no power at all
Dear Sir:
1)Most probably you did short circuit.
2) Test the fuse or breaker inside.
3) Check if you breaker from your house or building is tripped, since there are No power Must be 90% that your breaker in your building is tripped.Re-started again.
4) Test again the treadmill, and will be working
Of course when you open for to see the fuse or breaker, see if there are something with smell to burn. If there are burn, you must to Test it.
Finally you must not used extension cords. Use directly to outlet with connection to ground +device for power transient+100% stabilizer of voltage.
sincerely.
Nov 22, 2011 | Nordic Track NordicTrack Treadmill, A2550
Hi. I have a Horizon T-62 treadmill. It stopped working during a workout and my son smelled an electrical burning smell and saw small puff of smoke. I removed motor cover and reset circuit breaker then...
Unfortunately it sounds like the motor has burnt out and would require replacing.
As this treadmills come with a 10 year warranty on the motor if you've not had it for that long the you need to contact Horizon Fitness at the link below.
http://www.horizonfitness.co.uk/6/service/
If they're unable or unwilling to help you then please ask for further assistance and I'll see what I can do.
A replacement motor is in the region of $400 + fitting, but you could possibly fit it yourself.
Jun 22, 2011 | Exercise & Fitness
The power is on but it won't run
Power issues with treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Thanks for the rating Good luck
Dec 22, 2010 | Exercise & Fitness
It does not turn on says safe
This message appears when you remove the Safety key.
Kindly provide me with the make and model of the machine?
Are you sure that the key is intact? Is it properly placed?
Thanks!!
Aug 21, 2010 | Exercise & Fitness
Treadmill will not operate when plugged up.
check the outlet first by plunging in a light to make sure their is power and that the house breaker was not tripped. then plug in the power cord next locate the reset/off circuit breaker on the treadmill frame near the power cord. Switch the circuit breaker to the reset position. Then place safety key on console and the display should light up if not then you may have a lower board problem.
May 17, 2010 | Weslo Cadence Ct 5.8 Treadmill
I have a proform crosswalk calibre complete treadmill and the incline is not working. I know when it happened before I pressed the reset button and it worked - but I can't remember where the reset button...
Plug in the power cord . Next, locate the reset/off circuit breaker on the treadmill frame near the power cord. Switch the circuit breaker to the reset position
May 06, 2010 | Exercise & Fitness
I left the red key in epic view 550 for 1 full day, next day when discovered now treadmill will not start, no lights, no noise, nothing!! Help
Check the reset/off circuit breaker located on the treadmill frame near the power cord. If the switch protrudes as shown, the circuit breaker has tripped. To reset the circuit breaker, wait for five minutes and then press the switch to the reset position.
Apr 30, 2010 | Epic View 550 Treadmill
How do I turn off my Reebok 8050 ES? I can not figure out how to turn it off when I am not using it.
Plug in the power cord. Next, locate the reset/off circuit breaker on the treadmill frame near the power cord. Switch the circuit breaker to the reset
Apr 20, 2010 | Reebok 8050 ES Treadmill
Exercise & Fitness Logo
260 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
