Question about Samsung WF203ANW Front Load Washer
Water in drum
I have the exact same problem, new samsung front load washer has odour. when I turn the drum there is a swishing sound which sounds like water. I assumed the water was being trapped in the drum which was causing the odour. I had a Samsung repairman come out and he told me there was a ring around the drum that has oil in it which is the sound I'm hearing. I honestly don't believe him, I know the difference in sound between oil and water and I believe it is water. Does anybody have the facts on this?
The swish water sound that you hear in the drum is normal. There is some liquid in the drum for balancing. The washer doesnt use that liquid for laundry. The odor smell - you can get rid of it by cleaning your washer. Run empty cycle with bleach and hot water at least once a month. Also use washer cleaner - Tide recommended for a nice cleaner smell. You can get it from any supermarket.
Posted on Sep 26, 2010
WF218ANB noise like a bag of rocks being shaken.
This is a direct result of Samsung's Vibration Reduction Technology(VRT). There is a hoop at the front and the back of the drum holding 18 ball berrings in each hoop (36 in total). These balls use centrifugal force and automatically move to the opposite side of where the load is unbalanced and balances it out. It is only in the washing machines, not dryers.
Dec 16, 2009 | Samsung WF218ANW 4.0 cu. ft. High...
Samsung Front Load washer has odour
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Sep 01, 2009 | Samsung WF203ANW Front Load Washer
My Neptune MAH5500B has a terrible odor and I can hear water swishing when I manually spin the drum.
Pick up some Affresh tablets they are in the detergent isle,and the swishing you here is normal there is a liquid in the balance ring in the front of the tub that makes that noise..
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Not enough water in the drum during the washing cycle
If its a High efficiency washer it doesn't use much water. Usually the front load washers are HE washers
Aug 30, 2009 | Samsung WF203ANW Front Load Washer
Smell in washer SAMSUNG WF203ANW
NO is the outlet pipe fitted properly so that water cannot drain back into washer after use
Jun 30, 2009 | Samsung WF203ANW Front Load Washer
Ideset front load washer
If no water is entering the drum, and it is not leaking out anywere, then there can be no water coming in at all, unless the pump is coming on right away and pumping the water out., check the waste outlet pipe as it is filling, and see if water is discharging from hose
One other possibility is that the belt is off and the whining niose is the motor turning on it's own with out turning the drum.
This being the case, u probably wouldn't see any water in the drum, due to the small amount that they take in.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Indesit WA 125 Front Load Washer
Smell in Front Loading GE Washer GCVH6260F
more likely due to using liquid detergent - change to powder
Dec 01, 2008 | GE Energy Star WCVH6260F Front Load Washer
Water in drum
thats normal forthins machine they actuall use a water filled front ring for balance, woll always sounds as water is there. desgined that way
Nov 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Samsung WF203ANW Front Load Washer Logo
373 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
