SOURCE: sd memory cards
Up to 1GB memory card works in these cameras. Please use maximum 1GB memory card.
SOURCE: i'm useing the pny optima sd/hc 60 hd 4gb scan
I had same problem. Neither computer nor printer would recognize the SDcard. I took the card to Walgreen's and the card was read just fine. I suspect that we are running XP and do not have the right driver; but I can't seem to find the right driver. Morgen
SOURCE: what size sd card can i use in a dimage z1
You may use any size SD card. Bear in mind that SD cards max out at 2GB. Larger cards are actually SDHC cards and won't work in the Z1.
SOURCE: Minolta Dimage S414 camera doesn't like a new 4GB CF card
This camera accepts only Compact Flash till max. 2Gb size
SOURCE: I have two SD cards that are brand new on is a pq1...
I own a Nikon D5000, that has a 'pqi 4GB SD HC' memory card inside.Within this camera is also something called movie mode, in other words I can record short movies. Now here is the problem, Nikon says how much I can record on the memory card, depends on the speed the memory card records. According th them, I can only record 5 minutes on a 2GB memory card. Does that sound right to you. P-l-e-a-s-e I need help in understanding this.
If this is true,......what side memory card (HD if possible) would I need to record 30 minutes in the movie mode. Thank you so much for your help.
