Question about Linksys Wireless-N WRT150N Router
Hello I have run the wizaed setup and still can not connect to the internet on my linksys wrt150n router.
  • 404 Answers
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Posted on Sep 29, 2009
My wireless connection is running super slow AND I cant access the router via 192.168.1.1
You can try to reset your router
Reset the Linksys WRT150N wireless home router if you are experiencing connection issues or have forgotten your customized router login information. Resetting the Linksys WRT150N will erase your Internet connection settings, wireless security preferences and all other personal settings from the router. This procedure will restore the WRT150N back to its factory state.
Instructions
1 Locate the "Reset" button on the back panel of the router. The button is situated to the right of the Ethernet ports and to the left of the power port.
2 Press and hold the "Reset" button.
3 Release the "Reset" button after approximately five seconds. The device resets
Tips & Warnings
Use the Linksys WRT150N setup CD-ROM to run the setup wizard and reconfigure the router after the reset.
Dec 29, 2011 | Linksys Wireless-N WRT150N Router
I can't figure out how to open a port on a Linksys WRT150n. I bought a mobile webcam and I should be able to control it over the internet I can never connect unless Im in the network. Research tells me...
Download Routing Commander program from www.routercommander.com, it will automatically forward ports and setup the router. Another option is go to router's web interface and set up it manually according to router's User Guide.
May 21, 2010 | Linksys Wireless-N WRT150N Router
CONFIGURATION PROBLEM ON MY LINKSYS WRT150N ROUTER
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Mar 05, 2010 | Linksys Wireless-N WRT150N Router
I have an internet connection through my desktop that is plugged into a cable modem but when I run the Linksys Easy setup software it says it can't find a internet connection. I have turned off my Norton...
Make sure connections are correct. Cable modem to router with Ethernet cable. then connect router to computer with another Ethernet cable and see if it works.
o this:
1. hut down computer, modem and router.
2. put them on in this order waiting 1 minute between each.
---cable modem
---router
---computer
you also have to check that the router is set up as dhcp
Dec 26, 2009 | Linksys WRT150N Wireless N Router -...
I am having trouble setting up my WRT150N
Try to place the modem in bridged mode
Then run the setup wizard
It should work
Else configure the details Manually on the router
Sep 26, 2009 | Linksys Wireless-N WRT150N Router
I am installing my new wrt150n router and no internet
Turn off modem and router. Connect router to computer. Turn router on. Connect router to modem. Power up modem. When it discovers the modem it will assign to it the new IP address.
Hope it helps.
Sep 25, 2009 | Linksys Wireless-N WRT150N Router
Router Question
hello!
-- what is the brand of your modem? have you tried connecting your computer directly to the modem and check if you can get online? If yes, Internet connection is fine and the problem is on the router if not, call your ISP first and check your connectivity with them.
-- have you tried connecting your computer directly to the router without connecting the modem to the router and check if you can access the router setup page? there are some cases where in the modem and the router have same IP address that's why you cant access the setup page of the router because of IP Conflict. Try to access the router page , router not connected to the modem only on the computer and change the LAN IP address of the router to 192.168.2.1. Connect the modem to the router and try again to shut down everything and power on the devices one by one and check if you can get online.
-- if after changing the LAN IP address still doesnt work, try to check if you can access the router page by the new IP Address. Make sure that you do not have other firewall or any security enabled on the pc. If yes, try to enable the MAC Address clone on the router and check again the internet connection. Try to configure the router with a diff computer also help isolate the problem
-- if after that and it still not working last option is to upgrade the firmware of the router. possible that there is a problem with the router and upgrading the firmware normally fix internal problem. If that still doesnt work, the router is defective.
Aug 29, 2008 | Linksys Wireless-N WRT150N Router
Cannot detect the router
What version of the router do you have 1,0 or 1,1? This is located on the bottom of your router. There is a firmware update for both models, I will provide link. Also how is your laptop connected wired or wireless? Let me know and I will try to help you troubleshoot your problem. We always can set up your router manually.
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1169671597537&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=9753741396B13&displaypage=nodata&proxyid=1172713508141
Jan 10, 2008 | Linksys Wireless-N WRT150N Router
Linksys Wireless-N WRT150N Router Logo
96 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
