Question about Hayward Navigator Pool Cleaner
Nav gets stuck on steps and wont back out of a corner
  • 990 Answers
Try adding a hose or turning the return jets in different directions. If it is short on hose it will pull up from pool serface and won't get enough drive to pull itself out of the step. Returns will get a current going in thr pool and can sometimes push the cleaner wher it wants it to go usualy the steps will provide a good stopping point, like a boat getting caught below a waterfall in a river. If this is the problem the cleaner will run good for the first hour or so after the pool first starts. hope this helps, good luck.
Posted on Oct 05, 2009
Tried insulling radio now car wont turn over
you blew fuses. find them and replace then.
in cab or in engine bay, main fuse boxes.
the first step in doing electric installs is to pull battery neg lug.
if not you blow fuses.
on newer cars 1st step is get and write down NAV and radio codes.
or they will be dead. later..
Nov 08, 2013 | 1997 Acura CL
Zodiak G4 Get stuck in corners steps ect.
Check a couple things when these pool cleaners are getting stuck on steps and in corners. Is the correct length of hose being used? It might be necessary to shorten. Make sure that the ideal flow is being achieved. Add hose weights 3 feet from the cleaner head. You might need to also install a wheel guard (part # W83278). This wheel delfector will also work if the cleaners are hanging on the ladder.
Apr 14, 2011 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Brand new vrgp430wbc nav states route 66 has
press and hold the reset button for 5 seconds on the back of the device.
Feb 19, 2010 | GPS
Garmin sat nav wont turn on
Maybe this will help you?, I am giving you the link to the whole manual in detail that you can download in PDF.... This will tell you everything about your unit and trouble shooting and company contact numbers. I hope this helps if so, please rate my free help and some kind words would be nice in the comment section. Respectfully, Mike
Here is the Link>>
http://www8.garmin.com/manuals/2675_OwnersManual.pdf
Dec 12, 2009 | Garmin Nuvi 205T Sat Nav GPS Receiver
Nav gets stuck on steps and does not back up.
You may need to add a hose so the cleaner will pull to the floor enough to get itself out or you may need to redirect the return eye balls in the pool the change any currents they are creating that will drive the cleaner into the step and won't let it out. This you can usually tell is the problem if it runs good when the pool starts but developes after it runs for an hour or so. Hope this helps, good luck
Sep 29, 2009 | Hayward Navigator Pool Cleaner
My sat nav wont load and start
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
Jul 13, 2009 | Garmin nuvi 200W GPS Receiver
Tom tom one xl-wont turn on
there is a tiny reset button next to the memory card.
You can press it with a pin or earring.... hold it down for 15 seconds...
then press the power button for 5 seconds.... heres the link to the page where i found the answer...
Mar 16, 2009 | Tomtom One XL GPS Receiver
Nav system
Installing the DVD Map Disc Your dealer/retailer may have installed the map DVD. If the map DVD was not installed, do the following to load it:
Read the following steps completely.
  1. Turn the ignition on. The vehicle must be in P (Park) to perform this operation.
  2. Press (power) to turn the navigation system on.
  3. Press the NAV hard key.
  4. Touch the Insert Map Disc screen button. The screen opens to access the map DVD slot.
  5. Load the map DVD partway into the slot. The system pulls it in. The screen cannot be closed until a double beep is heard.
    Notice: Pressing directly on the navigation screen may cause damage. Repairs would not be covered by the vehicle's warranty. Do not press directly on the navigation screen.
  6. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
  7. Set the search area. See "Setting the Search Area" earlier in this section.
Ejecting the DVD Map Disc The navigation portion of the system cannot be used if the DVD map disc is not loaded.
  1. Press the MENU key to enter the Menu options, then press the MENU key repeatedly until Nav is selected or touch the Nav screen button.
  2. Touch the Map Database Information screen button.
  3. Touch the Eject Map Disc screen button. The screen tilts, exposing the map DVD slot.
  4. Press the eject button, located next to the DVD map disc slot, and the disc ejects. Pull the disc out. The screen cannot be closed until a double beep is heard.
  5. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
Oct 07, 2008 | 2007 GMC Acadia SLE
Nav-cam 7000 Can't start
After you click on each of the corners, you have to tap the center twice. I believe you get a message that tell you that. You just need to read it :-) Once you tap it twice it "accepts" the adjustments and boots up.
Jan 06, 2008 | Evesham Nav-Cam 7700 GPS Receiver
Hayward Navigator Pool Cleaner Logo
372 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
