Question about Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
I use that router to connect to outside grid antenna.Tall me if is possible.
    President:
  • 547 Answers
It certainly is possible, as the WAP54g has detatchable antennas, but keep in mind that 2.4Ghz cables are both very expensive and very lossy, so you'll want the WAP54g to be as close to the external antenna as possible.
Typical outdoor installations have a weatherproof box mounted with the antenna, to keep the cable length to less than 12 inches. You have to run power and ethernet to the enclosure, but neither of those have loss issues over distances of less than 100M (roughly 300 feet)
Posted on Sep 29, 2009
Testimonial: "Thanks for the information,but i like to know if you know a campany that sell this boxes.Thanks hmam44."
  • Rob C Oct 06, 2009
    I don't have any company recommendations, but google for "Pelican Enclosures" and you'll find lots of them.
Avalon radio
I would check the connections on the grid, if they are ok you have to live with yagi effect.
Mar 25, 2014 | 2000 Toyota Avalon
Which router modem is best ?
If you get a wireless-N router, and you have a wireless-N adapter on your computer, then it should work...depending on the physical environment and building type. If the building has steel-beam construction, or log walls for example, then this will inhibit the wireless signal drastically. Also, having a clear line of sight between the router and intended coverage area will help. Trees and tall brush can also kill the signal. Try to place the router closest to the area you want to cover, so the signal doesn't have to pass through several walls. Try placing it on a window ledge facing the area to be covered. If all else fails, there are high-powered N routers available, signal amplifiers and larger antennas for the router, and also consider mounting an antenna outside. Start with an N router and an N adapter for the computer first though as this is the least expensive solution, and may do the trick.
Hope this helps!
Joe
Apr 16, 2012 | NetGear WGR614 Wireless Router
One of my friend in my neighborhood using netgear wifi router when i connect with that performance vise netgear seems 2 b better is thr any setting to enhance the performance .... we both r using airtel...
To enhance performance is to enhance signal strength which can be accomplished with a repeater or an ACCESS POINT router with detachable antenna.
THen you can connect an omnidirection or bidirectional antenna which will enhance the signal.
You can check TP-Link products. Their routers are with detachable antenna. They have a grid antenna which is like a bid dish for detecting signals.
God Bless You!
Feb 05, 2011 | Belkin (F5D7230-4) Router (587009)
Is it possible to Wirelessly connect Router to a Router? We have a Router (outside the house) by which we connect to the internet inside the house. The problem is is that the internet connection is not...
1.Yes you can connect router to router.
2.Buy ruckus 802.11n.It got MIMO antenna.I hope it will work for u.You can use single router to access internet from all room
Feb 04, 2011 | Computers & Internet
My sat nav won't pick up any satelites
All GPS devices will need a clear view of the southern sky (in the northern hemisphere anyway) to obtain a "fix" or "lock" to display the location on the map.
A fix can usually be had in under a minute or two. The first time "out of the box" however, may require additional time to display the proper location on the display or output. If the device has built-in batteries, bring the device outdoors to an open area (no tree cover, tall buildings, etc.) and allow up to 10 - 15 minutes for the initial fix. If there are no batteries in the unit, extend the cord to allow the device to be outside the car - in a similar location described above (an open parking lot is very good), and allow 10 or 15 minutes to update the location.
GPS device require an open view to the satellites in the sky. Heavy tree cover, tall buildings, etc can cause significant problems for the GPS to obtain the info to determine its location. Some device provide a jack for connection of an external antenna input. These often have an amplifier built in, and can compensate for less than ideal conditions. Antennas with an amplifier built-in are called "active" antennas. Some vehicles may have a film on the windshield (usually a defroster) that can interfere with receiving the satellite signals. In this case, an external antenna would be a logical choice. When placed on the roof, or other location outside, it feeds the signals to the GPS in the car.
A low profile, active external GPS antenna. This will often outperform the one built-in to your GPS.
Oct 07, 2010 | GPS
Weak signal recption
Since wireless networks use radio waves to transmit signals, it’s possible that typical household electronics-your microwave, cordless phone or even the baby monitor- can interfere with this signal. Make sure you move your wireless router away from those devices that use the same 2.4GHz frequency range.
Other causes of interference are brick and cinder block walls, metal doors, metal frames around windows and doors, and metal filing cabinets.
Take these simple steps to reduce wireless interference:
  1. Move the router further away from the interfering device or object.
  2. If there is interference with a phone, you can change the channel of the phone or the Router so they use different channels. If there is still too much interference, you may have to buy a different phone system, operating at either 900MHz or 5GHz.
  3. Place the wireless router in a central location of your house, such as a family room or office.
  4. Arrange the desktop or laptop’s wireless antenna so that it points toward the wireless router.
  5. Avoid placing the antenna close to an outside wall (unless outside is where you want to be). If you want to connect while you’re outside, place the router near a window.
  6. Place your Access Point as high as possible. If your network goes through multiple floors, try to place the Access Point on the upper floor
Oct 04, 2009 | Linksys Computers & Internet
I have a DI-524 Air Plus G Router and would like to send signal to a location 350 feet away in another building. Is this possible? Currently I can receive a very weak signal, but not strong enough to...
not without a repeater or maybe outside antenna. then the signal would probally be too low. you are working too far for wirless and thru building walls.
Jul 07, 2009 | D-Link AirPlus DI-524 Wireless Router
My wifi will only work inside buildings
wireless has limited range and can be affected by walls, doors, glass. Some models of routers if they have removable antenna's can be replaced by highgain antenna's which can drastically improve your range.
Apr 16, 2009 | Acer Aspire 3680 Laptop
CWR-854 router
Type in the address of your router - you say that is set to192.168.1.254 and you will see the config page( after logging in ) for your router. This is more usually 192.168.1.1 though .
Jan 18, 2008 | Cnet CWR-854 Router
Cant find satalittes
You may have to do a reset. The reset button is under the flip up antennae.
Oct 30, 2007 | Garmin Nuvi 660 GPS Receiver
Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point Logo
275 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
