Question about Frigidaire Affinity ATF7000E Front Load Washer
Frigidaire affinity washing machine pause error Same issue
Because our machine was new and covered under warranty, we had a maintenance person come out three times for this issue, but the only solution he could provide was to use less soap. Apparently, too much soap disrupts a sensor. So, if you let the machine run without adding any more soap, it will (theoretically) fix the problem. And this solution did work, to a certain extent.
Even though I started using much less soap, the problem is still persisting. For awhile, I was successfully able to fix it by running a few cycles without soap. Now, however, it just won’t work. Maybe others will have more success with this solution than we did.
At this point, the washer is no longer cover under warranty and our best solution is to buy anything but a Frigidaire or related Electrolux product.
Posted on Aug 21, 2010
  • gormankat Nov 16, 2010
    I wanted to provide an update on this, since the problem has improved once we started using a different detergent. It still occasionally has problems, but it’s much better than what it was.
3 Suggested Answers
IFIXALL
  • 868 Answers
SOURCE: Pause Error - Frigidaire Affinity LTF6000ES0
If you just paused the washer and now displays a error try draining any existing water all out of the machine.Before re filling it see if you still get the error message.I'll be happy to guide you through this.
Posted on May 21, 2008
SOURCE: My Frigidaire Affinity washing machine says it
my affinty washer is stuck in pause mode
Posted on May 02, 2010
Frigidaire affinity error codes
I appreciate your inquiry, friend!
I see that you would like a list of Frigidaire Affinity washer error codes. I was unable to locate a full list of codes. Are you currently experiencing an issue with your washer? What error code is being displayed? With more information I will be able to assist you further. -Matt
Mar 12, 2015 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Frigidaire washing machine model number 137168300a stuck in pause mode
Good Afternoon Friend, this is Z. Thank you for your inquiry!
If you are receiving an error code PAUSE, it commonly indicates that the door of your washer is not securely latched or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume cycle. If these basic troubleshooting tips prove ineffective, try reprogramming your appliance by unplugging it or flipping the household circuit breaker off. It is best to wait approximately ten minutes and then turn on your washer. If the issue persists, then your washer could possibly have a faulty door latch or experiencing a communication error with the control board. I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts.
Jul 12, 2014 | Frigidaire Affinity ATF7000EG
FRIGIDAIRE FAFS4474L IS PAUSE
Hello Radwan, thank you for allowing me to assist you! Error code "PAU" usually means that the door is not securely latched or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume washer. If proves to be ineffective, try reprogramming the appliance by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit on. If the issue persists, then the appliance could possibly have a faulty door latch or experiencing a communication error with the control board. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Aug 28, 2013 | Frigidaire Affinity FAFW3511K Washer
Frigidaire Affinity ATF6700FS2 pauses with every load
Hello - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Nov 04, 2012 | Frigidaire Affinity ATF7000E Front Load...
How do i get code for my affinity washer
Hi - Could you please press and hold the start/pause and cancel button together at the same time for approximately 30 seconds? What error code does it display? With this information I can assist you further with the issue that the washer is having.
Oct 29, 2012 | Frigidaire Affinity ATF6000F Front Load...
Fridgidair affinity washer paused with error code EF2
According to SearsPartsDirect.com ( http://www.searspartsdirect.com/washer-repair/error-codes/frigidaire-front-load-washer-error-codes.html ) : EF2 Condition Too much suds Check/Repair Reduce the amount of high-efficiency (HE) high-efficiency detergent being used in the washer.
Aug 31, 2012 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
How do I reset my Frigidaire Affinity Front Load Washing Machine? When I press a button the ERR code comes on and then it turns off.
My Fridgidaire Affinity front load washer has a ERR pause and I can't reset it. How do I clear this
Jan 17, 2010 | Washing Machines
May 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
2,291 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
