Question about Whirlpool 5' Jacuzzi Tub Bathtub Cetra 532 H525-969
I have a Great Lakes spa hot tub and nothing turns on, setting was saying OH. We turned the breaker off and then back on and now it is saying 5n.
    Problem Solver:
  • 6 Answers
OH MEANS OVER HEAT AND THE 5N WHICH IS ACTUALLY SN IS YOUR SENSOR SO IT WOULD NEED TO BE REPLACED SO YOULL NEED TO CALL A POOL AND SPA COMPANY FOR EXAMPLE..... HOTSTUFF SPAS&POOLS SALEM,OR
Posted on Dec 11, 2009
Great lakes maniste hot tub comes on click like breaker tripping in tub, could it have bad fuse in tub itself?
Does the breaker trip instantly or does it take a minute? If there is a delay i would start with checking heating element. Instant is a direct short, try unplugging all components and if still trips then check wiring and breakers. If power stays on with components unplugged, plug them back in one at a time to see which one causes failure.
Feb 22, 2017 | Pool & Spa
Image739 hot tub turn power on and error code 5n comes on panel board what is code 5n and where is reset button
OK, 5n is meant to say SN meaning sensor. This is refering to your temperature sensor, and means that the computer thinks that the sensor has failed.
Check to see that it is plugged into the board completely, then verify that it is not chewed up by a mouse or rat. Both of these are the most often seen problems.
Beyond that feel free to call me if you still need assistance.
66O-263-O984 Ask for John.
Jun 28, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
There is no off on button, how do I turn my 2005 Great lakes spa on and off
hot tubs turn on/off one of two ways. there will be either an air button that you depress to turn the pump on/off or there will be an electronic topside that has buttons similar to microwave type button that you will push to turn the pump on/off.
Rod
US Parts Center
Apr 17, 2013 | Qca Spas Dream Series Dream Master Hot Tub...
Drained my 2000 Great Lakes Spa now OH is displayed when I turn up the heat it kicks out the breaker..
OH is overheat due to insufficient water flow through the heater.
Common Causes:
  • Gate valves not opened/partially closed.
  • Air trapped in suction lines or pump
  • Blocked suction fitting
  • Dirty filter
  • Restricted water discharge lines
Try remove filter cartridge and run spa.
Check pressure switch for continuity.
Unplug & plug hi limit sensor.
Oct 14, 2012 | Qca Spas Majestic Series Aruba Xl Hot Tub
I have a 15 year old Hydropool Gold Series hot tub that I bought used a month ago. We got it all hooked up and working great but was told the timer never worked so it ran 24/7. Yesterday my husband turned...
If you can find the points on the timer try sanding them down. If they were burnt and stuck the spa would have run continuous. When you pulled the timer you may have broken them free but a burn would have kept them from making contact. I hope this helps, if not you might try reversing the leads coming into the timer or wherever you unhooked it to take it out. good luck.
Dec 05, 2010 | Qca Spas Paradise Hot Tub
Error code reads "5n" or "Sn" on the panel. Great lakes hot tub. chuck
'Sn' is a general error message relating to the temperature sensors.
Assuming that you have a Balboa spa pack (M7 version), turn off the power and remove the spa pack cover, you'll find two temperature sensors mounted in the top of the heater tube one at each end. Follow the wiring from the sensor to the plug(s) on the PCB and check that the connections are good, they have a habit of devekoping a poor connection.
If you have a multimeter you could also check the resistance of the two sensors. They should both be the same. If they aren't the same you'll probably have to replace them.
One final thing just to check... Ensure that there are no blockages within the heater. Unless you have service/gate valves you will have to drain the hot tub, unscrew the unions and check inside the heater for debris within the heater assembly.
If you're from the UK I may be able to help regarding parts etc.
Kind Regards,
Ian.
http://hottub.synthasite.com
Mar 28, 2010 | Qca Spas Dream Series Dream Master Hot Tub...
Reset error code hot tub
tub is in sleep mode usually to change u must press temp button then light button you want to b on standard mode STD
Oct 04, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
Whirlpool 5' Jacuzzi  Tub Bathtub Cetra 532 H525-969 Logo
423 people viewed this question
Top Whirlpool Home Experts
Craig Butler
Craig Butler
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
