Question about Hayward Navigator Pool Cleaner
Nav gets stuck on steps and does not back up.
  • 990 Answers
You may need to add a hose so the cleaner will pull to the floor enough to get itself out or you may need to redirect the return eye balls in the pool the change any currents they are creating that will drive the cleaner into the step and won't let it out. This you can usually tell is the problem if it runs good when the pool starts but developes after it runs for an hour or so. Hope this helps, good luck
Posted on Oct 05, 2009
How do I convert my sat nav from europe to usa
Some Sat Navs can't convert, If it's bought & set to UK & Ireland maps, then you are stuck. 2nd thing , even if you can use Europe Maps on your Sat Nav, you still will be unable, to load USA maps.
Sat Nav not compatable, You will have to buy a NEW ONE.
Mar 07, 2015 | Garmin nuvi 255W GPS Receiver
Tip
Broken Screen Delete Messages Nokia 3109 3109c 2323 2323c
This works for the Nokia 3109/c and also the 2323/c which have a Nokia menu like in the picture. If you have the same menu then it should work. The handsets have a central navigation button which allows you to move up, down, left and right through the menus.
Delete Inbox Messages Blind Nokia Broken Screen
Press Central Navigation Button to get Menu
Press left once
Press up once - Message Menu
Press Central Nav Button
Press up twice - Delete Messages
Press down once - By Folder
Press Central Nav Button - Inbox
Press Central Nav Button - Confirm Delete
Press Button above call end several times to exit from the menu
Note on the 2323 (not sure about the other models) you have an option to keep unread messages. If you still want everything deleted then swap confirm delete step above for
Press Left hand button set above green call button - confirm delete all messages
Delete Sent Messages Blind Nokia Broken Screen
Press left once
press down three times - Sent Items
Press Central Nav Button - Confirm delete
on Aug 06, 2010 | Cell Phones
Sat nav disc reading error 56 plate civic
get it serviced
the magic smoke was lost.
Jan 28, 2014 | Honda Cars & Trucks
A cd is stuck in my Pioneer AVIC Z1 nav system. I
This is a tricky one you could try tyaking the top of the radio off and see if you can help slide it out. Another trick is to get a thin stiff piece of cardboard like the back of a writing tablet cut a strip apx. 2" wide and 6" long. Take a piece of ducktape and with the sticky side up insert under the disc hit eject and see if that will coax it out.
Jul 29, 2010 | Pioneer AVIC-Z1 Car DVD Player
Hi my MMI system on 2004 A6 asgone dead, no power
No solution, same problem, but had many strange moments: 4 months ago during 100 kms or so it stopped, then suddenly came back, and worked ever since. A few days ago, it started happening again: NAV stuck, then radio dead, and gradually the rest disappeared. I did a Reset, and since that moment I see the intro-screen and then it goes black. Hitting the TEL button is somehow also a Reset...
Do the previous 2 posters have anything to report on this matter? It would be VERY welcome!
Thanks,
Jeff
Dec 25, 2009 | 2006 Audi A6
Nav gets stuck on steps and wont back out of a corner
Try adding a hose or turning the return jets in different directions. If it is short on hose it will pull up from pool serface and won't get enough drive to pull itself out of the step. Returns will get a current going in thr pool and can sometimes push the cleaner wher it wants it to go usualy the steps will provide a good stopping point, like a boat getting caught below a waterfall in a river. If this is the problem the cleaner will run good for the first hour or so after the pool first starts. hope this helps, good luck.
Sep 29, 2009 | Hayward Navigator Pool Cleaner
2006 Navigation SYstem DVD stuck
remove all wood grain and plastic
Jul 26, 2008 | 2006 Toyota Highlander
Nav disc
On some cars, it does that with 4.62 version of the disc. Make sure first of all it is version 4.63. In the worst case, you can simply reload the original software back in it again and that should resolve your problem with globe screen restarting over and over.
May 22, 2008 | 2005 Acura RL
Nav-cam 2007 stuck on navigator loading what should i do to get it working again.
I have the new N30 version of the NAV-CAM 2007 software.
Here is where I posted the links:
http://www.driveway.com/NF98ogAJWR
http://www.driveway.com/i1EvQzR8FL
http://www.driveway.com/G3N0Y5jQ4s
When you finish the downloads, you need to unzip all the files, then copy the map files into the maps folder. Once this is done, copy the entire thig to the SD card and enjoy! Joe
May 04, 2008 | Evesham Nav-Cam 7700 GPS Receiver
Hayward Navigator Pool Cleaner Logo
255 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
