Question about Kenmore Washing Machines
ON the second wash I did today, after the second wash my clothes came out with streaks of black. What would cause this?
  • 69 Answers
Grease is leaking into the drum under the agitator cone.
Remove the agitator cone. There will likely be a removable plastic piece with an O-ring. Oil could be leaking out of the O-ring into the washer, and water could be leaking into the bearings. If there is damage to the O-ring replace it, or if there is a bunch of schmag that is compromising the seal, clean it out, and re-install everything. This solved the problem in my washer; hopefully it works for you.
Posted on Sep 29, 2009
My LG Front Load washing machine is leaving black streaks and smudges on my clothing. These streaks and smudges are ruining my clothes!
There can be several things that can cause this problem. The most common are:
1. Fabric softener - did you switch brands lately?
2. Chlorine bleach - if added at the wrong time
3. A mechanical problem with the washer, like a leaky transmission leaking oil.
4. Rust staining, sometimes caused by the water being used in the machine.
Here is a link to a site that discusses this issue more in depth:
http://www.stain-removal-101.com/washing-machine-stains.html
Jul 26, 2015 | LG Washing Machines
I am getting black streaks on clothes after washing.
Make sure the washer is level, especially front to back. Do not overload washer. Check to see if marks are coming from build up of gunk in the outer bowl.
Apr 09, 2015 | LG WM2301H Washer
Loud grinding noises and black streaks on clothes
Your drum rollers may be going bad (grinding noise) which will sometimes cause the drum to drop slightly, creating a gap where the clothes get caught as the drum rotates. (black streaks)
Mar 29, 2014 | Maytag Dryers
White clothes come out with random black streaks
Drum is dirty from main barring leaking. This is job to fix by professional
Sep 22, 2012 | Asko W6021 Front Load Washer
Black streaks on my laundry
Marks on clothing in a washer are usually caused by a reaction between detergents and fabric softeners, especially cheaper bargain brands.
If you are sure that the black streaks are getting on the clothing in the washer versus the dryer, it could also be oil from the transmission getting into the washer tub. See if the spots will come out using a petroleum distillate of some kind. (paint thinner, etc). If a petroleum distillate will remove the marks, it is most likely something petroleum based that is making the marks.
This is a rare occurrence, and most marks on laundry are caused by the dryer. Typically, the drum rollers wear out and rubber and metal filings can get into the dryer and mark/streak clothing. Hope this helped and sorry for the problem you are having. Best wishes.
Jul 24, 2009 | Frigidaire ATF6000ES Front Load Washer
White streaks on dark clothes after washing.
Reduce the load !!
You are getting white streaks because the clothes are so compressed the machine is not agitating them correctly.
My daughter gets the same problem and she still insists on packing the clothes in.
My wife washes the same clothes for her with the right load and they come out fine
Jun 18, 2009 | AEG Lavamat 88840 Front Load Washer
Black streak on cloths?
FRONT LOAD ,, BLACK STREAKS ARE USUALLY CAUSED BY RUBBER DOOR BOOT NOT CLEANED W/ FINGERS FEEL AROUND AND SEE WHAT YOU FIND ????????????
Nov 28, 2008 | GE Energy Star WCVH6260F Front Load Washer
Calypso grey/dirt streaks
THIS SERVICE POINTER APPLIES TO THE FOLLOWING BRANDS:
LAUNDRY PRODUCTS REFRIGERATION PRODUCTS KITCHEN PRODUCTS
COMMERICAL LAUNDRY
OEM BRANDS
ALL SERVICE POINTERS ONLINE: http://www.servicematters.com/tech_ref/tech_ref_main.htm, SERVICE POINTERS
COMMERCIAL LAUNDRY ONLY: www.whirlpoolcorp.com/cltpsc, TECHNICAL INFORMATION, SERVICE POINTERS
To receive pointers by email or FAX, or to edit or delete a current email or Fax from our distribution, see
http://www.whirlpoolcorp.com/cltpsc/feedback/feedbacksubscribe_all.html, or FAX changes to 269-923-5342.
CALYPSO WASHER
Model: GVW9959K
Serial Code Date: Prior to CP44
GRAY MARKS OR SMUDGES ON CLOTHING
L8178406
October 2003
Gray marks, streaks or smudges on clothing after a wash
cycle.
CONDITION:
CAUSE:
At the end of the cycle, the wash plate nutates for
approximately 30 seconds to fluff the clothing after the
final spin. The action of fluffing causes the outer wash
plate seal to rub against the stainless steel basket while
they are both relatively dry. This condition causes the gray
discoloration.
RESOLUTION:
An updated machine control, part number 8542693, is
now available. The updated control reduces the fluff time
from 30 seconds to 8 seconds, allowing the clothing to be
fluffed, without causing discoloration.
Gray marks or smudges can be washed out of clothing
after wiping down the basket. The consumer should use
the recommended amount of HE detergent and the hottest
water safe for the fabric or hand wash the garment under
running water. In either case, the fabric must be cleaned
prior to running through the dryer.
Jul 09, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Intuitive Eco
Would suggest doing a full hot empty load, using bleach according to bottle instructions. It sounds like a build up of scum from washing powder, fibre from clothing etc. Can also be caused by overuse of fabric conditioner.
Jun 11, 2008 | Fisher and Paykel Fisher & Paykel Washer
Washing Machines Logo
116 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
