Question about Kenmore Elite Oasis 27052 Top Load Washer
Kenmore - elite washer show unbalanced on spin
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 12, 2010
Why does it always become unbalanced in spin cycle?
how confident are you to get inside it? Check the balance springs and shock absorbers.
Normally it is two simple things.
First the machine must be level front to back and left to right. Also all 4 feet must be in equal contact with the floor.
Make sure you load the washer evenly with clothes. Mix large and small items so when the spin starts the clothes even out. Never wash just one large item that is very absorbent, like one bathrobe or one blanket..
Dec 26, 2015 | Washing Machines
42936- My kenmore elite he front-load washer w/steel tub-has scrapping/unbalanced like sound coming from washer when in spin cycle, then after completed there is shredded plastic/fiberglass like mater
Sound like one of the wights has come off or is loose and damaging the drum and other parts take a under the machine and you may see the problem
Jul 29, 2014 | Kenmore Washing Machines
Kenmore elite 110.2706 unbalanced load problems
I have the same problem with my washer though it is a Maytag. the part that grips the drum to spin it is stripping, (and not properly grabbing). Repair man said to just get a new but I'm sure if you find a dedicated enough repairman he may be able to replace that part. The repairman said to replace mine because it was over 8 years old.
Sep 08, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite Oasis washer unbalanced signal seems to be very sensitive. Only after several tries of readjusting the load to get it really even that the washer will spin without stopping. I made sure...
If the washer throws an UL error code with out any clothes in the washer then the issue must be concerned with the mechanical alignment inside the machine or a bad CCU.
The most common problem which can cause this is some sort of mechanical hinderance which does not allow the basket to move freely.
The suspension system which holds the basket in its place might be faulty and causing the unbalancing. In this model i think there are plastic ring at the bottom of the basket . Even if they are worn out or moved out of position it may cause the UL error code you are facing
Nov 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Im getting a uL message on my spin cycle and I dont know why.
The "uL" message stands for "unbalanced load." Open the lid to the washer and redistribute the load if the "uL" display appears on the appliance.Redistributing the load should correct any imbalances in the washer and allow the washer to turn freely. Close the lid and press "Start" to restart the washer.
Jul 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My drum is unbalanced
Check whether suspending springs are damper of the wash tub in proper position.
Check your floor surface level and adjust the washing machine suitably.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
Excessive noise during the spin cycle. we have owned the washer for 16 months. problem started 1 wk. the machine is level.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 03, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore HE3 stuck in delay cycle and won't unlock or cancel
YOu more than likely have suds in your washer, or an extremely unbalanced load. push the pause cancel button twice, that should unlock the washer. open the washer, and look inside. Is there a lot of suds, or towels that are tangled up? If so, add some fabric softener to the wash tub and do a rinse drain spin (for suds) for the extremely unbalanced load, take the towels (or what ever load you are doing) and put about 1/2 of them in. I have the same washer and have experienced this "problem" once or twice in 7 years. And those were the two culprits. Hope that helps
Jul 30, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore he5t shaking when it spins
hi..you have an unbalanced load.Make sure it is evenly
distributed inside of the washer and don't overload it.
try this out..
thank u..
kindly rate my response..
May 17, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
143 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
