Question about Dell Precision M60 Notebook
M60 battery will not hold charge plugged into AC adapter all day
  • 3,940 Answers
If the battery is over 18 months old, the answer is replace the battery. If the battery is NEW then the charging circuit of the motherboard is bad
Posted on Sep 29, 2009
  • 558 Answers
I've tried this with my own Dell.I used a toothbrush to clean the contacts on the battery and the computer and my problem went away.You can try this as well.If this works you should be ok,however if it fails you will have to replace the battery as it has expired.
Good luck
Nc6000 multibay battery does not recharge
Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
(Will charge)
That is AC adapter (Charger) removed, then remove multi-bay battery.
Plug AC adapter back into laptop, THEN plug AC adapter into power.
[You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
(Then plug AC adapter into power)
Post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | HP Computers & Internet
NEW Battery not properly charging
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
Feb 16, 2012 | Gateway MD7818u Notebook
I was just kind of chilling on my laptop most of the day. And it kept like running outta battery like it normally kinda does every now and again. I kept it plugged in most of the day but it wouldn't...
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a 'power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
Dec 28, 2010 | Computers & Internet
1525 dell battery not charging.
this could be one of 3 things.
Bad battery
Bad AC power adapter
Bad internal power jack (where the plug goes into the laptop)
The easiest thing to do is to try and use your laptop with the ac power adapter plugged in and no battery. This should work but if it doesnt then you know it probably is your ac power adapter. But if you feel like you have to wiggle and hold the cord in then it may be the jack on the inside. The only way I know how to fix that is to take it apart and resoder the joint holding that part together to make a stronger electrical connection.
As for the battery if you let it sit out for a day it will discharge any current it currently has inside of it and then you can try again to charge it. If that doesnt work and your cord and jack seem fine then you will need to look for a new battery to replace the one that died. This happens over a couple of years as the battery life shortens over the life of the laptop and more so if you use it heavily.
May 07, 2010 | Dell Inspiron 1525 Notebook
Toshiba m60 will not power up - power supply is
If you know for sure the ac adapter is okay and the laptop won't turn on then its got to be the motherboard that is bad cause that is where the power goes thru to start.
Take out the battery and only hook up the ac adapter and see if the laptop will turn on then, if it does then that means the battery needs to be recharged up or bad if it won't charge up.
If you take the battery out and the laptop still won't turn on then you know for sure motherboard is bad.
Jan 06, 2010 | Toshiba Satellite M60 Notebook
Notebook plugged in. cannot get the dell to turn on. its not the power suppy that i plug into wall
1. remove all ext peripherals
2. remove battery
3. plug ac adapter to wall socket power (without the laptop)
4. check if the ac adapter led stays on, if yes then connect the laptop, check if the ac adapter led turns off after connecting to laptop, if not then turn on the laptop if still no power then have replace the motherboard.
Oct 15, 2009 | Dell Precision M60 Notebook
Problems charging Dell Precicion M60
go to support.dell.com and check your warranty information..thepower cube may be failing..if still under warranty, they will replace free of charge depending on your service agreement
have your express service code ready to put and it will give you all the information you could ever need about your system
www.aa1consulting.com
Jul 24, 2009 | Dell Precision M60 Notebook
Dell Precision M60 won't start up
Without battery connected it wont work. Better buy a new batterry connect it and plug it for charging for 8Hrs conitnuosly without switching on the laptop.
Apr 20, 2009 | Dell Precision M60 Notebook
AC Problems
Sounds like the DC jack is bad. That is where the AC adapter plugs into the laptop. In order to replace that, the laptop will have to be disassembled and a new DC jack will have to soldered on. One other thing to check is whether the AC adapter is still functional. Get a voltage meter, set it on 200 DC, put the positive on the inside of the plug itself, and the ground on the outside. It should read +/- 20V, usually 19.xx
Mar 20, 2009 | Dell Precision M60 Notebook
Batteries AND ac adapter?
Make sure the ac adaptor ius the right polarity for the camera, negative outside plug and positive centre,also make sure the voltage output of the charger is correct 5 volts dc.You do not need batteries as well as the charger.
Sep 04, 2008 | Toshiba PDR-M60 Digital Camera
Dell Precision M60 Notebook Logo
180 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
