Question about Linksys Wireless-G WRT54G Router
After i hooked up the WRT54G2 router it worked fine. then i saw that i needed to run the disc first.after i ran the disc i no longer had wifi.
  • 404 Answers
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Posted on Sep 29, 2009
I need a download disc for my Linksys router wrtg2. I lost it can u post a link to a new one that's compatible with windows 8
Hello Friend,
You can download the software from here
http://support.linksys.com/en-us/support/routers/WRT54G2
Aug 13, 2013 | Linksys WRT54G2 Wireless Router
When I try to conect my new Ipad to WIFI Kearny it ask for a password which I do not have or it no longer works? how can I solve this problem ?? Do I need to buy a new router ? My router is a WRT54G2
There is no need to buy a new router, just log in at the router's settings page using any web browser (for your router usually http://192.168.1.1, admin for user and nothing or admin for password), navigate to Wireless Settings / security settings and write down the WEP or WPA KEY that you can find here. This is the password that your new Ipad is asking for.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Feb 13, 2011 | Linksys WRT54G2 Wireless Router
How do I hook up my linksys to my desk top pc (XP) so I can run my lap top from upstairs
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Nov 07, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
No wi-fi signal transmitted
There is a reset button in the back of your router, which will reset it to all default settings. Try this to get the router to work.
Also is it hard wired into another computer? Check it out that way. make sure the router is working.
good luck
Apr 13, 2010 | Linksys WRT54G2 Wireless Router
I have a WRT54G2 Wireless router. Works okay with
yes mke sure wep is correct code. make sure you home security level is the same as your laptop. have tried hooking up your laptop to the home with a cat 5 cable. we had to do this with 2 dell vista laptops. then disconnect lan and we hooked up wirless just fine. something in vista firewall settings.
Dec 31, 2009 | Linksys WRT54G2 Wireless Router
Ibook wont log onto my network
I ran into this with my home network and my old g3 ibook needed the older speed wifi to connect. I found my old wifi router, hooked an ethernet cable to the newer router (in a regular ethernet port) and connected the other end to the internet port on the old one... they linked and worked fine to provide wifi for the old G3's ..
Dec 19, 2009 | Apple iBook G3 Mac Notebook
Can't install linksys wrt54g2 router with arris tm602g modem
I've tried network magic and everything thing else and I still can't get it to work.
Sep 28, 2009 | Linksys Wireless-G WRT54GS Router...
I have linksys router,it's connect with lan cabel but without lan cable router unable to connect to my laptop
All routers need to have a ethernet cord from the ISP Device. Most people run Laptops Wireless from there routers or if its stationary run another ethernet cord from an open port behind the router to your laptop.
Sep 19, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys Wireless-G WRT54G Router Logo
42 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
