Question about Xantrex Technology XPower Powerpack 200 Plus Power Supply (9383183) 200-Watt Power Supply
No air ... compressor seems to be working OK ... a loose air connection?
    Problem Solver:
  • 7 Answers
More than likely bad valves or a hole in your fill side hose, PSP UST are junk, i would never buy one again.
Posted on Aug 05, 2012
    Guru:
  • 1,326 Answers
That would be agood place to start. Try starting the unit and pressing your finger over the head and see if the pressure guage builds air you will only be able to hold it for a few seconds but just to see if its compressing air. If so its fine and check the connection where it is adding air to..
Posted on Sep 29, 2009
Have a Stanley J45C09 450 AMP Jump Starter w/Compressor. Mortor runs but does not generate any pressuer.
If you get no pressure but the motor is running, there is a good possibility that a pin has separated from the piston fly wheel. This is very easy to fix. Unscrew all the screws on the bottom (including the eight smaller screws that hold the battery terminals) and lift up the cover. Look at the compressor (start with the air pressure valve and work to the compressor) and locate where the piston is. It is located at the side of the unit. The connecting rod will be noticeable loose (use your finger to locate the looseness if you need to) and once finding it Just connect it to the compressor. There will probably be a link within the case that has come loose and because it is not connected, the air from the compressor is not being carried to the hose. Just put in the link and presto - it should be fix.
Nov 22, 2013 | Stanley Air Tools & Compressors
The airconitioner will not work in the cooling or the heating mode ,it starts up ok and the compressor cuts in the fan is working ok.
Hope the compressor getting high amphs due to capacitor weak or loose wiring.Check and replace the capacitor. If still your compressor cuts off, the problem is with your compressor. Thanks.
Dec 12, 2010 | Dometic Rooftop RV Air Conditioner
Motor runs, but no air pressure builds in tank
Three things to check.
1) Check that the tank drain is closed
2) Check that your quick connect fitting at the discharge of your compressor is sealing properly.
3) There is a copper or aluminum line that goes from the head of the compressor to the tank. Check the fittings on each end they occasionally come loose due to vibration.
If all of the above is ok:
Check the head gasket of your compressor. The unit you have is notorious for blowing head gaskets.
Hope that helps,
under_psi
Aug 31, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I purchased a Commercial Cool Haier portable rolling air conditioner CPN11XCJ from QVC and the compressor noise is aweful. I was told this was a shipping damage issue. The unit works fine but the noise....
Check the compressor. It probably fell out of it's mounting bracket during shipping. Maybe turned upside down or something. Make sure the compressor is sitting solid and it's rubber feet are in place. If you continue to use this unit with a loose compressor, you may damage or break a refrigerant line.
Jul 08, 2010 | Haier Heating & Cooling
Compressor shut down very quick then it turn on again after 3-5 sec it's off.., what is the solution?
MY HAVE A LOOSE SPADE CONNECTION AT MAIN THERMOSTAT RELAY. MOST OF THESE UNITS DONT HAVE HIGH OR LOW FREON PRESURE SWITCHES BUT YOU NEVER KNOW ON NEW UNITS CARRIER MAY HAVE THEM WHICH MY MEAN LOW FREON OR CLOGGED CONDENSER COIL  THE OUTSIDE COIL LAYERS IN DIRT,BUT THATS NOT A QUICK ON OFF .BURNT WIRES ON COMPRESSOR OR BLOWN RUN CAPACAROR CAN CAUSE QUICK ON OFF. WE HAVE INSTALLED A START CAPACATOR WHEN COMPRESSOR DOES NOT START AT ALL. CHECK FOR LOOSE WIRES ON TERMINALS THEY MUST BE PULLED TO CHECK THEM,THEY CAN SEEM CONNECTED BUT THEY ARE LOOSE. OTHER CAUSES MAY BE THE PROBE IN FRONT OF EVAP COIL WHICH IS TSTAT BULB. STICK IT IN HOT WATER AND IT SHOULD KEEP STAT CALLING FOR COOL.
Apr 20, 2010 | Samsung AW1203B Air Conditioner
The compressor trip at main breaker
possible causes , do not use ext. cord on compressor unless it's HEAVY gauge, also if you have any thing else running on the same breaker, It might cause it to pull too much power.
Oct 06, 2009 | Ingersoll Rand 231C-KS - 1/2" Super Duty...
Ingersoll rand air compressor 185
How old is the compressor ? This trouble shooting is directed to the vane and screw types of air compressors.
Caution,
For exact information on the equipment you are working on, go to the manufacturer’s maintenance and repair manual.
Here are some possibilities.
Compressor does not reach design pressure or capacity:
Air Pressure safety valve is leaking
Receiver air valve is open
Unloader valve is leaking
Loose Piping or fittings
Compressor will not load or unload:
Unloader valve defective
Air control valve is sticking or dirty
Unloader pressure is improperly set too high or too low
Water in the control lines
Plugged control lines
The air compressor CFPM is low:
Dirty air compressor air filter
Defective air intake control valve
High idle on power source improperly set
Damaged or worn rotor blades
Nov 23, 2008 | Air Tools & Compressors
Compressor shuts down 59516.531G
Is the compressor too hot to touch when it shuts down? This would indicate a low charge
Aug 02, 2008 | Dometic 57915531 Air Conditioner
Air conditioner comes on fan only. the compressor doesnt seem to be coming on. the is no cool air blowing. the unit is brand new and was jusy installed.
there will be option in remote to on the fan and compressor separately may be you would not have on-ed the compressor through remote or else there would have been any loose connection in the wire which connects the compressor
Jul 29, 2008 | Friedrich Heating & Cooling
Xantrex Technology XPower Powerpack 200 Plus Power Supply (9383183) 200-Watt Power Supply Logo
129 people viewed this question
Top Xantrex Technology Computers & Internet Experts
steve morris
steve morris
Are you a Xantrex Technology Computer and Internet Expert? Answer questions, earn points and help others
