Question about Canon imageRUNNER 210S Copier
Error codes 051
I'm trying to find out what the Error Code 051 is on a Canon imagerunner 210s
    Problem Solver:
  • 6 Answers
It is around the horizontal registration home position switch (ps14) Check out the paper feed real good
Posted on Dec 22, 2007
Canon ir 400 error code 051
I m E220 Error how to clear the error of Ir 400
Jul 29, 2011 | Canon imageRUNNER 400S Copier
Error code e007 on canon imagerunner 210s
that is code for damaged fixing film u will need a technician to replace the fixing film. or replace fixing unit( for that, open the front cover; open screw of down left side small cover, remove cover; detach connection on the upper left side.remove earthing screws and in the upper centre, fixing unit mounting screw. release feeder leaver oin right side.open left door, slide out fixing unit replace with a new one and revert whole process.)
Feb 07, 2011 | Canon imageRUNNER 210S Copier
Image runner 210s error code E000. What to do?
Your problem in the fuser unit.Check and clean the fuser unit component parts:thermistors,thermofuses,verify the continuity of the heater lamp,and verify the upper and lower fuser roller mechanical.
Nov 24, 2009 | Canon imageRUNNER 210S Copier
051 code showing in gp 405
E051 indicates that the side registration sensor is not detected try to switch off/on the machine but if the same error code display again thre is a small motor that drive the sensor assy should be change.try to move the sensor manualy by opening the upper right side peep inside you will see a long white plastic wth teeth push to this to right side hope this will help
Jul 09, 2009 | Canon imageRUNNER 400S Copier
Canon ir210s gatting error E100
that is a defective laser error code sorry
Dec 23, 2008 | Canon imageRUNNER 210S Copier
E803 Error Code
e 803 error .that is for dc controller or composite power board .if power board just change it.
Dec 16, 2008 | Canon imageRUNNER 210S Copier
Cannon Copier image Runner 400/330 series error 051
E 051 problem is registration horizontal position gear is broken. this gear seem to paper pick up deck back side. remove paper pick up deck and see one small moter and see small gear is there u change it u r problem is solved
Mar 21, 2008 | Canon imageRUNNER 210S Copier
EOOO is a thermistor-fuser error. Your machine will need a fuser, but on occasion a power surge can trip the error, E000 needs a code to reset it, I dont know if same but this is the code on a IR 330s
Press the userbutton then press "2" & "8" at the same time and then press userbutton again.
You will now enter servicemode
press " Copier "
press "function"
press "Clear"
press "Error"
leave servicemode by pressing resetbutton twice.
restart machine.
Mind you it is only a reset, if fault still exist it will go eooo again confirming that it needs a new fuser unit.
Dec 30, 2007 | Canon imageRUNNER 210S Copier
Canon imageRUNNER 210S Copier Logo
176 people viewed this question
old marine
old marine
