Question about Briggs & Stratton Garden
Gas leaking from air filter? - Briggs & Stratton Garden
  • 437 Answers
Sounds like the needle valve is not closing off the flow of gas to the carburetor. Maybe a bad float, or the needle and seat need to be replaced.
Sounds like a carburetor rebuild is in order.
Posted on Sep 30, 2009
Gas is leaking after I put gas in. It looks like the fuels lines are in. Does the filter attach to the gas lines? I don't see an air filter on my 536-77240000 craftman edger.
If you just replaced the lines, alot of times the lines outerm diameter is not correct, causing leaks...other times its the gas cap itself, However, there shouldn't be any hole under a gas tank... at least not where any air filter would be close by..
Sep 26, 2015 | Garden
Gas spits back if I pump too fast, and the check engine light is on --maybe a vent is clogged--Help!
GASOLINE in the air filter is a serious fuel injection problem....to be honest....I have never heard of such a problem...air goes through the filter into the cylinder where it mixes with gas....to have gas spit back into the air filter.......exhaust valve stuck? Maybe intake manifold is leaking? Gas from the tank goes straight into the cylinder via the fuel injection hose...how does it get into the air filter is really a problem. .
Dec 03, 2013 | aFe 2001 Ford Ranger - 2.3L 4-cyl. engine...
Rich condition no codes
Could be a number of things: a vacuum leak: check your hoses for proper routing and no leaks from cracked, brittle rubber. Check your intake manifold where it mates to block for an air leak (if you have an air leak-vacuum leak, your computer compensates by spraying more gas.)
Could be an injector is leaking gas into a cylinder, or not operating properly.
Is your air filter clean? A tune-up (plugs, wires, air filter, fuel filter) may fix the problem.
Another possibility is a tired oxygen sensor.
Good luck.
Oct 11, 2011 | 1998 Ford Escort
19e412-0134-01 won't start. gas leaks out air
The float is stuck on the carb flooding the engine and leaking gas out of air filter. Remove the float bowl after the gas is turned of or drained. Thoroughly clean carb And bowl with carb cleaner. Reove the float {very carefully} if it is copper, shake it. If you here fuel in it then it is no good. If not then clean everything and reassemble. If it needs to be replaced, most small engine repair shops will have your parts.
Aug 28, 2011 | Porter Cable BSI550 W 5,500 Watt Generator...
How to determine evaporator icing problem of air conditioning units
Due to :
1.. Evaparator coil dust blocked. 2. Air filter blocked. 3. Less rpm of fan motor. 4. Short of gas. 5.Filter drier chocked 6. Compressor less pumping.
To rectify:
1 & 2.Clean air filter and evaporator. 3. Replace fan capacitor. 4.Check for gas leak and recharge. 5. Replace new filter drier, vacumize and gas charge.
Dec 16, 2010 | Heating & Cooling
OBDII SETS CODES P0401, P0171 & P0174 . 1998 Mercury Sable
P0401- Exhaust Gas Recirculation Flow Insufficient Dectected
Possible causes - Harness or connectors (EGR volume control valve circuit is open or shorted.)
- EGR volume control valve stuck closed
- EGR volume control solenoid valve
- Dead (Weak) battery
- EGR passage clogged
- Exhaust gas leaks Possible solution - Clean EGR Valve
- Repair EGR harness or connector
- Replaced EGR volume control solenoid valve
- Replaced EGR volume control valve
Code P0171- Fuel Injection System Too Lean Bank 1 Possible causes - Intake air leaks
- Front Heated oxygen sensor may be faulty
- Injectors may be faulty
- Exhaust gas leaks
- Incorrect fuel pressure
- Lack of fuel
- Mass air flow sensor may be faulty
- Incorrect PCV hose connection Possible solution Dirty air filter of faulty air flow sensor are common causes of the problem P0174- Fuel Injection System Too Lean Bank 2 Possible causes - Intake air leaks
- Exhaust gas leaks
- Lack of fuel
- Incorrect PCV hose connection Possible solution Dirty air filter of faulty air flow sensor are common causes of the problem.
Jun 28, 2010 | 1998 Mercury Sable
Gas leaking out the air filter
If you are leaking gas out of the air filter then there is a leak in the fuel system that is letting fuel get by the seals and into the air cleaner.
Apr 10, 2010 | 2005 kawasaki VN 800 Vulcan Classic
OUr Yard Machines mulcher is leaking gas (big
At the gas filter? Air filter? Is it a Brigg's? If it is the gas filter, are there clamps that need tightening> Is it the right filter? The hose size is most important. If it is the air filter and it is gushing out, then you have a stuck float in the carb. Hope this gives you some ideas.
Jul 10, 2009 | Garden
Craftsman Edger 536-797520 is leaking gas from the air filter
The needle valve is sticking open. The carb needs cleaning and diaphragm replaced. Probably best taken to a shop unless you have experience with diaphragm carburetors. Dwain
May 27, 2009 | Craftsman Gas Mini - Tiller/Edger
Garden Logo
359 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
