Question about Lexmark X644e All-In-One Laser Printer
Lexmark x644e LCD Display Inverted(Upside Down)
Hey Guys,
I have a weired problem with x644e printer. When I turn on the printer the LCD Display is fine but after few seconds the LCD Display turns Upside Down. I checked in Diagnostic/Config but there is no such option to fix it.
Any help in this regards will be highly appreciated.
Maq
  • maq_ans Dec 18, 2007
    Thank you so much for your quick reply but I am afraid I tried the firmware update but it didnt do any good for me.
    Any possible solutions please. Someone told me that Inverter Card and LCD Assembly needs to be replaced??? However, I am not sure about it.
    Please help me.
    President:
  • 4,402 Answers
First thing i would do is update firmware
http://support.lexmark.com/static/229-1-0-530.html
Posted on Dec 18, 2007
  • Cary Farah
    Cary Farah Dec 19, 2007
    never heard of an inverter card...
    I had an interesting thought, try going into the unit via webpage
    http://
    and see if there is a configuration setting to flip it!
    http://support.lexmark.com/cgi-perl/know...
SOURCE:
Lexmarx x644e dark copy
Check the transfer roller, cartridge
Apr 14, 2014 | Lexmark X644e All-In-One Laser Printer
Check toner cartridge
The error 200.16 on a Lexmark X644E indicates that the main drive motor is not working due to high mechanical load due to paper jam or bind. The recommended actions are:
- Make sure paper path is clear.
- Check motor to system card connections.
- Replace transport motor.
I suggest you contact our Technical Support Hotline on 1-800-539-6275.
Jul 26, 2012 | Lexmark X644e Laser Printer
No Nvram printer en impresora lexmark x644e
2 options:
1 - Turn off the machine and unplug the power cord leave it unplugged for 10 minutes turn it back on.
"probably not going to resolve it" - T
2- you will need to replace the system board / formatter. this is the board where you plug in the usb/ phone line/ network cable.
"This should definitely take care of it based on my experience with this machine."
Oct 19, 2010 | Lexmark X644e Laser Printer
The text on the printer's display shows up backwards, upside down, and when you scroll thru it, things get all cluttered. The printer operates just fine, its just impossible to scroll thru the menus on...
If your 6360 has a blank display, garbled characters, inverted, upside down, or backwards display the control panel is bad and must be replaced.
Here's a video to replace it. It's very easy and takes about a minute.
Apr 30, 2010 | Xerox Phaser 6360 Laser Printer
Lexmark Printer x644e, Geting Blue Screen of Death
allen_logan
To be able to properly address your BSOD I will need some info from the BSOD. The link below will show you the info that I need.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Thanks
Issken
Feb 02, 2010 | Lexmark X644e All-In-One Laser Printer
Xerox Phaser 6350 Control Panel display problem
If your display has a blank display, displays garbled characters, or the display is inverted or upside down, check out this video
Sep 10, 2009 | Xerox Phaser 6350/YDT Laser Printer
Lexmark x644e LCD Display Inverted(Upside Down). Restored factory defaults but that did not help.
You will likely need to replaced the LCD panel
Lexmark p/n: 40x0494
You can order it here at www.fastprinters.com
40x0494
Dec 08, 2008 | Lexmark X644e All-In-One Laser Printer
Picture inverted
You have a defective main digital board.
Apr 03, 2008 | iLO 3200 32 in. LCD Television
Lexmark x644e LCD Display Upside Down(Inverted)
Hello there,
I've seen this before. The X64X series with this inverted display seems to work fine (printing,scanning,faxing..) the reason for this is still unknown. But I've got it fixed twice by resetting the NVRAM on this MFP. If you are unsure of how to reset NVRAM, please follow the instructions below:
1.Power off the MFP
2. Hold down the 6, 7 and 8 buttons down and turn the MFP On.
3. Please hold down the buttons till it reads resetting factory defaults and then release the buttons. The MFP should now come back to ready status.
Please check out if this solves the issue, If not the machine would need a hardware service.
Merry Christmas!
Dec 18, 2007 | Lexmark T632 Laser Printer
Its projecting upside down!
check the projector menu. there will be a setting for image orientation. it can be set for normal or inverted. inverted is used when the projector is hung from the ceiling.
Oct 20, 2006 | Panasonic PT L711U Multimedia Projector
Lexmark X644e All-In-One Laser Printer Logo
410 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
