Cannot set up wireless function on a new printer.
Just bought a Canon Pixma 620B wireless printer/scanner. Get error message when trying to set up the wireless function: "ERROR: New Port Could Not be Created." I have a Dell S17-162B, operating on Vista. Advice?
Canon MX892 - when I scan, an error code 2156 comes up saying scanner is turned off or usb cable unplugged
Hi.
Try to check up first scanner power cable and network wireless router.
If it are running running good. your scanner have defective parts. like
IC chipset.
Second option : try to general cleaning your Canon PIXMA MX892 Network-Ready Wireless All-In-One Printer. using vacuum.
Hope can help you.
Sep 15, 2012 | Canon PIXMA MX892 Network-Ready Wireless...
I am trying to scan a document using the Canon PIXMA MG6120 that is connected via wireless LAN to my laptop. I get an error message on the laptop as follows: START OF ERROR...
Your firewall block the communication. You will need to get into your protection software and allow 'full' access of MP Navigator (EXT)
Aug 03, 2011 | Canon PIXMA MX870 Wireless Office...
I have a Pixma MG6150 Multifunction device. PC is sadly running Vista SP2. Trying to set it up wirelessly. Software installed perfectly on a Windows 7 pc but on this laptop it returns an error message...
Try this,
1) Go to Start/Settings/Printers and Faxes
2) Right click the "Pixma MG6150 Printer" and choose property
3) Go to the Ports page (From the top menu), and assigned to port FILE: it should be assigned to a Canon Pixma MG6150 Network port
4) Click button, and select "Canon Pixma MG6150" type, and then new port
5) The "Canon Pixma MG6150" printer will be associated with this new port, automatically
6) Click OK
Hope it can help & good luck.
Oct 18, 2010 | Computers & Internet
How to load new ink into printer Canon Pixma 620B ? Thank you!
Step 1.
Open the hood of your printer; if the ink cartridge holder does not slide into view, check to make sure the printer is turned on.
  • Step 2 Remove any empty cartridges from the ink cartridge holder and dispose of them properly. Some Canon printers have a protective cartridge lid that must be opened before you can change a cartridge.
  • Step 3 Remove all protective tape and plastic film from the fresh cartridge. Canon uses a bright orange protective tape on its ink cartridges. Some Canon ink cartridges also have a bright orange protective cap over the ink nozzle that must be removed before installation.
  • Step 4 Insert the new cartridge into the ink cartridge holder. Tilt the cartridge up slightly and insert end-first into the proper slot; push down gently on the cartridge to lock it into place. Some Canon printers have an indicator light that will activate when the cartridge is firmly installed; other models have a cartridge cover that will lock into place when closed.
  • Step 5 Close the hood of the printer. The printer will indicate when it is ready for use with a message on the LCD screen or by blinking the LED indicator light.
  • Jan 22, 2010 | Canon Office Equipment & Supplies
    Im trying to scan and the canon says: "set the pc to start scan"...? Nothing pops up on the computer, what do i need to do?
    I'm using an MG5220 and got this same message. Here's how I fixed it.
    On the printer control panel press the soft key to select the scan function. Then hit the soft key to select Save/Forward. Then select Foward scanned data to a PC. On the next screen make sure to select the appropriate PC. In my case I'm connected wireless but the selection was set to USB connection and that's why I was getting the error noted above. When I picked the PC that is connected wirelessly everything worked fine again.
    Jul 12, 2009 | Canon PIXMA MX850 Multifunction Printer
    Canon PIXMA MP830 Error Message: Scanner is not operating correctly.
    This problem sucks. It sounds like the scanner has actually gone bad. This can be a couple of things. The actual ccd unit inside the scanner, a position sensor, a motor or a wire harness.
    The latter two are fairly unlikely, the first two more likely. Most probable is the CCD unit. I don't think Canon sells it as a separate piece, but it comes inside a replacement scanner assembly. These complete scanner units are expensive. You'll have to check with your local Canon shop to see what they cost.
    Nov 06, 2008 | Canon PIXMA MP830 All-In-One InkJet...
    NO scanning
    How long is your USB cabel? Support recommends me to use cabel short than 3 meters, I bought 1,8 m cabel, what solved my similar problem (scanner freeze).
    Mar 02, 2008 | Canon PIXMA MX310 All-In-One Printer
    Pixma mp600r scanning setup
    Try turning off the windows firewall.
    If that works, then add the Canon scanner app to the list of applications that are allowed through the firewall, then turn the firewall back on again.
    Jan 24, 2008 | Canon PIXMA MP600 all-In-One InkJet...
    210 people viewed this question
    jasbo
    jasbo
