We have a brand new 5 ton ac unit the part that goes outside how we got it is a long story but a good one but we need to but the other half that goes in the celing and idea how much this should cost me and what it that part called so i dont sound stupid when i call to get prices
  • 439 Answers
This is called an "A" coil. You need a 5 ton "A" coil to match your outside unit, give or take 1/2 ton. The cost will vary greatly depending on the make of your unit.
Posted on Sep 29, 2009
Testimonial: "thks"
    Top Expert:
  • Heating & Co... Master
  • 13,676 Answers
Inside evaporator/ air handler outside is called condenser
I have a 2.5 ton ac outside. the indoor unit downstairs in the basement is a goodman. a new a coil was put in about a month ago. which is a goodman product. ive heard goodman is not a good product. a
the inside coil and outside unit should be matching in tonages another word if you have 2.5 ton outside the inside sould be the same. it don't matter what brand name or who made it.
Aug 04, 2012 | Goodman CKL36AR36 Air Conditioner
5 ton ruud stops working if you pull the 3 amp fuse then put it bak it starts back working
You are resetting the circuit ,and starting the system back up,something is not right,but more information is needed,and gauges(AC) need to be connected to the unit to tell the whole story.
Apr 16, 2012 | Ruud Heating & Cooling
I live in Phoenix, AZ. I have a 2 story 2300 sq ft home built in 2001. I have two Carrier AC units outside on the side of the house. They are the originals. The Large unit (upstairs) model 38CKC042340 and...
T the upstairs is a 3 1/2 ton 10.0 SEER condenser, and the downstairs is a 2 1/2 ton 10.0 SEER condenser. You can use any 10 SEER Unit on replacement, but if you go any higher in SEER (efficiency), there is a possibility the unit will freeze up. The reason is because the indoor coil also has an efficiency rating (10.0 SEER). It is not a good idea to mismatch units when it comes to SEER. Otherwise, you can use any brand of unit, if you want to go higher in efficiency, you need to change the indoor coil as well. Hope this helps. Mark
Jul 31, 2011 | Heating & Cooling
I JUST NEED TO KNOW WHAT MY TONNAGE IS.
Look for your model number on your condensor, outdoor unit. Your tonnage will be towards the end of it and divisable by 6. I.E. 36=3tons or 42=3.5tons. Ac units are messured by the half ton. If you have a split system I.E. heater inside and ac outside your system will be 1 - 5 tons. If this doesn't help post your model and serial number. I can then give you tonnage, age, so forth.
May 16, 2011 | Heating & Cooling
I'm looking to purchase a Rudd 2 stage model, 16 SEER, 5 ton along with a 100000 BTU 95% furnace. I have a two story home and will only be using the 1 AC. Will the Rudd cool both floors?
Assuming that there are ducts ran upstairs and downstairs, it all depends on the square footage of the living spaces, i.e. bedrooms, living room, dining room, etc. You need an average of 1 cfm per sq ft. For every 1 ton of air, you have an average of 400cfms. So your 5 ton unit will cool/heat 2000 sq ft. A 16 seer unit with a 95% furnace is a nice buy and you will notice the difference for sure. Hope this helps!
Aug 03, 2010 | Ruud Central System Air Conditioner
Can I mix brands/tons when installing AC unit to existing coils?
First off - the 'rule of thumb' is 600' per ton of Air Conditioning. In other words your old unit is a 2 ton unit. So - 2 tons x 600' = 1200'. As you can see if you install the 2.5 ton unit - you will be installing a AC that 'could' cool a 1500 sq ft house (2.5 x 600' =1500 sq ft.). Slightly more than what you need; and the 3.5 ton unit is 'way to big,' (3.5 x 600' = 2100 sq ft.).
Note: fyi - many in the AC business will sometimes refer to tonnage in btu's, i.e. 1 ton = 12000 btu - hence a '2 ton unit' can also be referred to as a 24000 btu unit and vice versa.
So... from the above - you can easily see that "2 tons" of Air conditioning is what is required to cool the 'average' home of 1100 sq ft. "roughly speaking."
Note: it is always best to have a professional 'size' your cooling/heating needs.
One of your questions was could you 'mix tonnage?'
The answer is 'usually you don't mix the tonnage of your outside/inside units.' However, professionals sometimes do (mix the tonnage) in certain situations, and installing a 2.5 ton outside unit with an existing 2 ton inside unit is often done, however, there are some 'tech issues' here and - I would "again" recommend that you call a Service Tech to help you with the sizing/mixing of your cooling/heating needs.
hope this has helped
Jun 20, 2010 | Carrier 38CKC036 Air Conditioner
How to tell the size of my ac unit?\
thats a 5 ton ac unit
10AJA6001AH
basically 1 ton = 12,000 BTU
so 24 is 2
30 is 2 and a half
etc
Jun 21, 2009 | Weather King Heating & Cooling
What ton is my old Luxaire AC unit? it is model EESQ36
Sure but you need ot have an AC man to replace it and vac down the system plust change the dryer/reciever.
Jun 12, 2009 | Weather King 10AJA3601AH Air Conditioner
Is the Model #25HBA360A300 a 5 ton unit?
36k-car-ms Key Features AC Type: Split System Additional Features: Ductless Cooling Capacity: 36000 BTU/hr Electrical Requirements Voltage: 220It is a 3 ton aprox 550 sq feet per ton is required
May 01, 2009 | Carrier 36KCARMS Air Conditioner
Is a 5 ton unit to big for a 24 by 40 two story
That depends on to many items like what city is located, how and what type of insulation is in the house, how many windows it has and if they facing to the sun etc.The best way to know what you need is make a heat balance and they will tell you exactly the amount of BTU you need for the house But a 5 ton unit is probably enaugh unless you live in a very hot place in the Caribean.
May 01, 2009 | Goodman CKL60AR60 Air Conditioner
Heating & Cooling Logo
90 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
