Question about Hampton Bay AC414-LRU 52'' Kemper Collection Rustic Finish Ceiling Fan
I wired up my ceiling fan and it has been running fine for two to three months but today the remote is not controlling it. It will not do anything i checked voltage at the plug and at the ceiling fan itself could it be the transmitter.
    Scholar:
  • 108 Answers
Did you check the batteries in the remote? (gotta ask sorry). If that isn't the obvious fix, the reciever in the fan base could be out. Hopefully this is a warrenty fix but if not, you can pick up a whole new remote system from Home Depot or Lowes for about 30.00 and are as easy to hook up as the fan itself.
Posted on Sep 29, 2009
Hunter fan 27185 has lost speed
Remote controlled ceiling fans can suffer a lapse of memory when there is a power outage. You eliminated the possibility of a dead battery in the remote by installing a new battery, but just to be sure remove the new battery and press all the buttons on the remote to eliminate the possibility of a stuck button then reinstall the battery. Next disconnect power to the fan at the breaker box, not a wall switch or by tugging on a chain. Turn the fan power on again. Using only the remote, check operation.
Apr 20, 2013 | Hunter Dryers
I have a hampton bay ceiling fan which will only run on the fast speed. I have changed switches but still only the fast speed. I have touched each wire to the load wire to see if it was the swith but no...
Hello Brother,
Installation:
Hang your ceiling fan on the Quick Connect fan bracket and wire the ceiling fan according to the manufacturer's instructions. The three wires coming from your ceiling should match the three wires coming from your ceiling fan: black (positive or hot), white (neutral or negative) and green (ground wire).
Use the high, medium and low keys on the remote to adjust the Hampton Bay fan speed, then use the light key to dim the light and the off key to turn off the fan.
For REMOTE CONTROL FANS you cannot use with any variable speed or slide wall switches. The remote control function must be used with on & off switch outlets only.
Speed Controls Click here Capacitors Link
I hope This Helped you,Thanks for Contacting FixYa...
Apr 22, 2010 | Hampton Bay Heating & Cooling
Need diagram for hunter fan with light kit. Three
Black to black. from fan
Blue to Black and white. from fan
White to white. from fan
The input is from ceiling supply
the black wire from fan is for motor.
the black and white is for the light.
Jan 02, 2010 | Hunter 52" Ceiling Fan With Light And...
How to wire a ceiling fan, it has two black and one green wire.
The two black wires go to the two wires that come out of your ceiling. No polarity issues here. The green cable is a grounding cable. If you don't have a green cable coming out of you ceiling, then find a way to connect it to the metal electrical box. If there is no way to do that, then you can leave the green cable disconnected. Wrap some electrical tape at the end so it doesn't touch anything else. Not the safest practice (to leave things ungrounded), but your fan will work just fine.
Nov 01, 2009 | Hunter 52" Ceiling Fan With Light And...
My ceiling fan isnt working right
dont you have a three position pull switch on the unit like a three-way light bulb or if you have a remote controlled fan it should have it on the remote control
Sep 24, 2009 | Encon Industries (78018) Ceiling Fan
Need a basic diagram to wire a ceiling fan.
Depending on how your place is wired will dictate the solution here.
The light box in your ceiling should have two or three wires. Black and White, or Red, Black and White.
If you have two wires (one switch to control everything):
Black is power - hook this to the fan's power wire (and the fan's light wire if applicable)
White is neutral - hook this to the fan's neutral wire.
If you have three wires (two separate switches):
Red is power for the light - hook this to the fan's light wire if applicable
Black is for the fan - hook this to the fan's motor
Sep 18, 2009 | Hunter 52" Ceiling Fan With Light And...
Installing remote control ceiling fan
Your black wire is line and red is load. So your incoming power hot goes to black and out going power to fan connects to red. White is wired with all three whites together and same with green.
Aug 30, 2009 | Hunter 52" Ceiling Fan With Light And...
Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Aug 17, 2007 | Hampton Bay 04383 Calibre Ceiling Fan
Hampton Bay Ceiling Fan At Slow Speed
I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
Aug 10, 2007 | Hampton Bay 52 In. White Redington...
Hampton Bay AC414-LRU 52'' Kemper Collection Rustic Finish Ceiling Fan Logo
61 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
