Question about Cole HERSEE PUSH-PULL SWITCH -- OFF-ON
I have a 1975 Dodge pickup with a push/pull switch for my fuel tanks. It decided to quit working today (since 1975) and I am having a real hard time finding a replacement for it, does Cole still make such a thing? And if so where can I get one? Can't change tanks or get fuel guage to work.
  • 59 Answers
Try finding one in a local scrap yard or look on kijiji.com or ebay
Posted on Jun 03, 2010
Have a dodge ram 50 pickup.. Hard to start.. Once started it will idle... Try to pull out and it hesitates and wants to die.. Back off on the gas and sometimes it will idle or dies..
Dodge Ram 50 Pickup Questions - Page 5 - CarGurus
www.cargurus.com > Questions > Dodge
CarGurusGet fast answers to your Dodge Ram 50 Pickup questions from experts in the ... 1986 Dodge Pick Up 5.9 Wont Start I Put New Distributor Set The Timing, New.
Dodge Ram 50 Pickup Questions - Carburetor - CarGurus
www.cargurus.com > Questions > Dodge > Ram 50 Pickup
CarGurusCarburetor - I recently bought a 1989 2.6L Ram50 for my son. ... Asked by redoverfarm Apr 13, 2010 at 03:36 PM about the 1989 Dodge Ram 50 Pickup ... check your fuel injector...may be clogged dirty, get a fuel injector cleaner or carburator ... Also gets poor gas mileage and is hard to start when the engine is warm !
Dodge Ram 50 Pickup Questions - 87 d 50 2.0 runs ok ...
89 Ram50 wont start.. - DodgeTalk : Dodge Car Forums, Dodge Truck ...
www.dodgetalk.com > ... > Dodge Ram Truck 1st Gen (88 - 93) Forum
Sep 22, 2011 - Hey guys i got a 1989 Ram 50 and im hoping i can get some help here. She drives like a champ but she only starts when i push start it, once i ...
Dec 26, 2015 | Dodge Cars & Trucks
Gas pump shuts off early when fueling 2004 Dodge Ram 5.7 SLT Pickup.
My work truck does this as well. Pulling out the nozzle doesnt work either. I know it sounds wierd, but try turning the nozzle sideways or upside down when filling the tank. Works well with my work truck.....
Jan 25, 2015 | 2004 Dodge Ram 1500
VULCAN oil heater c.1975 UNUSED oil in tank on outside wall. 2 months continuous airflow. Tried turning knob every way, pushing button up/down = ON/OFF (?), unit NEVER USED and will NEVER BE USED.
Not quite sure what is asked, but if you just need to turn off the airflow a breaker or fuse box should be nearby. Flip the breaker and/or remove the fuse. Fuel oil is always dangerous... even a small amount. The lines will still have vapors. Best to remove this unit or flush out the tank and lines and block it off.
Dec 09, 2014 | Heating & Cooling
What's your problem?1998 dodge caravan fuel pump no power
the fuel pump working good and the relay too , i change the egr valve and another valve go in the air filter and nothing . now when i put the swicth the pump start runiing and them stop them start runing alot of time . now i check in the fuel injector if i got gas them i push the little thing in the injector them push a lot of gas .... now today i go put down the gas tank i go make sure if not have a electrical problem in the fuel pump. i hope this is the problem .....
Sep 14, 2012 | 1998 Dodge Caravan
I hit a bump with my rodeo and it just quit running and i don't hear the fuel pump kicking on when i turn the key on any ideas?
Check the power wires on the fuel pump and make sure that it is pumping fuel to the engine.
Its a possibility that something under the hood could have come loose when you hit that bump.
Check everything, all electrical connections, and all fuses.
Mar 03, 2011 | 1997 Isuzu Rodeo
For some unknown reason our Linciln just decided not to start today. Full tank of gas, not real cold out and absolutley no problems until this morning. Any ideas?
First thing would be to check all your fuses. Pull one out at a time if needed. If the fuses are good, then you have either no spark or no fuel because of bad fuel pump or fuel pump relay.
Dec 31, 2010 | 1998 Lincoln Town Car
Where is the fuel pump in an 88 dodge pickup 318 c.i., fuel injection? ( hopefully not in the tank....)
Yep, usually the tank. And not only dangerous to extract, the replacement is costly... But you need it to work....
Oct 17, 2010 | 1988 Dodge D-Series Pickups
2004 Dodge 2500 diesel loses power while driving.
either your fuel guage is not reading properly and you have less fuel than you think or your fuel pickup nedds to be adjusted sometimes the pickup looses the ability to pull the fuel from a certain level which would indicate that the pick up is going bad or is already bad if you replace just the pickup see if you can get one thats a little longer than the one that you have already so that it can go deeper into the tank. maybe the pickup tube has fallen off also and the pump can only pull the fuel when the tank is full. hope this gives you some ideas as to where to start.
May 07, 2010 | 2004 Dodge Ram 2500
How to change a fuel filter on a 2002 dodge ram 1500 4.7
This is the year that dodge decided to put the fuel filter in the gas tank instead of inline on the railing. Just either empty the gas tank or make sure that there is hardly and left in it considering it will be heavy. Pull the necessary lines off top of tank and hoses and than take the nuts that hold your straps on the tank off. Remove tank and pull fuel filter.
Apr 01, 2010 | 2001 Dodge Ram 1500 Truck 2WD
Daughter put "diesel Fuel" into 2003 ford taurus. What's the best way to drain fuel tank?
the easiest way is to lift the car and unhook the fuel filter and cycle the fuel pump to push it out of the tank. you may have to cycle the key quite a few times to get it out but is easier than dropping the tank to empty it. if you crank the starter for a second the pump will run longer each cycle should get a couple gallons per cycle from the fuel line.
May 05, 2009 | 2003 Ford Taurus
Cole HERSEE PUSH-PULL SWITCH -- OFF-ON Logo
78 people viewed this question
Top Cole Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Cole Electrical Supply Expert? Answer questions, earn points and help others
