Question about One For All URC-3021 Remote Control
I need code for Samsung HDTV 1080i Monitor. - One For All URC-3021 Remote Control
Can anyone please help me out with the codes for a one for all urc-2099b00 remote for a Sony HDMI DVD PLAYER and Samsung HDTV monitor 1080i tv also a Daewoo surround sound system ??? ??????
You can use code search to find something that will control each of the devices. You will have to search through all codes in each device category. If your search is unsuccessful, you may have to resort to using more than one universal remote. All universal remotes do not contain all possible codes.
Jun 01, 2016 | Sony Audio Players & Recorders
Need code for Samsung 1080i monitor
Code should be 10812, if that doesn't work try 10060, 10702, 11060, 10766, 11903, 10587, 10650, 10814, 10178, or 10030. The reason for so many codes are Comcast has different remotes that use different codes for Samsung's monitors and tv's. If this doesn't work let me know the color of your remote to find the code.hope this helps.
Mar 20, 2013 | Samsung Hmx-q10 hmx-q10bn - 1080i - 5.0mp...
I have a Samsung Rear Projection TV with an HDTV 1080i Monitor. I know the convergence is messed up because the blue would not move when I tried to adjust it on the menu. So, then I tried to make it
You will need to replace both convergence Ics and the pico fuses that blow when the Ics fail. You can get the replacement Ics and pico fuses from www.tvreairworld.com they also provide free tech support to help you install them
Oct 27, 2012 | Samsung HC-P4752W 47" Rear Projection...
Unlock code for a samsung gt 1080i
I have the same problem with my phone samsung GT 1080i. it is locked. My IMEI:3547260436219878
Feb 04, 2011 | Samsung Cell Phones
Black boarder on screen of my samsung hdtv 1080i
You may have to change the aspect ratio but doing so may change the picture quality. Your owners manual should explain how to do this. If you don't have the manual you may be able to download it from Samsung for your particular model TV.
Nov 15, 2009 | Samsung 37 in. Flat-Panel LCD HDTV
I have a samsung hdtv 1080i that has sound but no picture
It means you covergence setting not ok.use remote press (mute183) set covergence lines remember before you save these setting press self focus botton in remote and exit by smode
Jul 24, 2009 | Televison & Video
What do I need to get for viewing HDTV
The TV you have will only process an HD via the component video connections. Your cable box needs to have component outputs and you will need to buy a component video cable to connect from the cable box component video outputs to the TV's component video inputs (should be 2 sets, #1 for up to 720p and #2 for up to 1080i...
Oct 28, 2008 | Samsung PCL5415R TV
Upgrade Possible?
you will need to contact RCA helpline for the procedure
Jul 28, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
One For All URC-3021 Remote Control Logo
510 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
