Question about Maytag EPIC MFW9700S Front Load Washer
THERE IS STILL WATER IN THE DRUM AFTER THE WASH LOAD HAS FINISHED
AFTER A LOAD HAS FINISHED WHEN YOU SPIN THE DRUM YOU CAN STILL HEAR WATER SPLASHING AROUND INSIDE OF IT
    Genius:
  • Maytag Master
  • 1,474 Answers
Check filter . clear..Good luck
Posted on Sep 29, 2009
Frigidaire topload washer inner drum not rotates during wash cycle
inner drum is not supposed to rotate . just the agitator .spin cycle is when that will rotate
Sep 28, 2016 | Frigidaire Washing Machines
Is it normal to have substantial amount water remaining in the washer after final spin?
Hey friend, thank you for allowing me to assist you!
It is normal to have water in the tub after your Frigidaire washer has completed the final spin cycle. The water that is in the tub is there to help prime the pump. Hope this information is helpful. -Matt
Jul 27, 2014 | Frigidaire Affinity ATF7000E Front Load...
WHY IS THERE THE SOUND OF SPLASHING WATER FROM THE DRUM AFTER A WASH?
The balance ring is filled with salt water to stabilize the spin cycle, this is normal.
Jul 06, 2014 | Whirlpool WTW4800XQ Washer
During the spin cycles in the wash the machine makes a loud whining noise while spinning? As soon as the cycle is finished the problem goes away. Is this a faulty belt or what. Please help.
Either the belt or you transmission could be slipping and it making the belt work harder on a full load. Try running the spin cycle without water to see if you hear it. If you do then it is the belt, but if you only hear with water then it is your transmission.
Apr 18, 2011 | Frigidaire FEX831CS Top Load Stacked...
We find water standing in the drum days after we wash a load. it isn't there when we unload a wash but shows up later. it reeks of sulphur. is the motor on the water pump going/gone bad? it works during...
Turn off the water supply valves behind the washer after you complete a lod. If there is no water in the tub a few days later, the machine has a bad internal water valve.
Oct 20, 2010 | Washing Machines
You can hear water behind the drum when you spin
I don't believe you have a problem with your washer. It is NORMAL to have residual water in the drain lines and drain pump following a wash cycle. You will be able to hear the water sloshing around if you move the drum or drain lines. This is the lowest point of the drain cycle and gravity will ALWAYS cause some water to be there. As long as the water is not visible in the spin basket inside the drum, and the washer is properly draining during the wash and rinse cycles, you have nothing to worry about.
If you have any questions, please post back and let me know. I hope this is helpful to you.
May 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have just run a wash cycle and when it had finished the clothes were still very wet and water was laying in the bottom of the drum. I have tried to do a repeat wash but the machine will not work but...
You have most likely selected by mistake the no spin option coupled with extra rinse  - press again the rinse button to unselect that and put the spin speed at max.
Jan 16, 2010 | Hotpoint WMA50 Front Load Washer
Water remains in tub after spin cycle
Have you tried to clean the drain hose on the back of the washer? It may have build up inside that you are loosening up by using bleach.
Sep 06, 2009 | Frigidaire ATF6000ES Front Load Washer
When i spin wash tub wigth my hand i can hear lots of water still in the machine under neath the wash basin
That is becouse most washing machines are made up of an inside drum where your clothes are washed and an outside durm that catches the water when the washer spins the water out of the washed clothes. A pump is connected to the bottom of the outside drum. If the pump fails, the water would not get pumped to the drain and would collect in the outside drum.
Aug 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Neptune-is water supposed to remain, after wash is finished, between tub and outer shell
if you hear water when you spin the basket,that is the front tub balance ring.it is filled halfway with water in order to assist mach in balancing load.that is a normal sound.the mach may also leave some water between the basket and outer shell depending on lengh of drain hose.as long as the clothes do not come in contact with the water it is fine.
Sep 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
131 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
