Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool conquest sibe by side GS6SHAXKQ01 freezer has defrosted and food is thawed
  • John Broderick May 11, 2010
    Is the compressor running? How old is the unit?
I have whirlpool conquest model GS6SHAXKQ01 - Came home to puddle of water, everything in freezer is melting, frig is getting warm. Lights come on both sides...Suggestions? Thanks
Posted on Feb 09, 2010
We have a whirlpool et1rhmxkq03. I have replaced defrost timer and thermostat. Defrost timer seems to stall and freezer thaws and the compressor stops running. I tap the control housing in the refr
The problem is with the "thermostat" right next to the defrost timer. When you tap on the control, you are actually tweaking the thermostat and not the defrost timer. Here is the thermostat to order.
Here is a diagram of the control box. The thermostat is number 13 and the defrost time is number 4.
Nov 11, 2012 | Refrigerators
Freezer appears to be defrosting but, everything is running
Switch off the freezer and clean it properly by emptying th freeze. And then switch on the freezer
Feb 26, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer issues with Conquest
freezer is supposed to defrost? need more info..
if you need a part try www.appliancepartssolutions.com
Jan 16, 2010 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
FREEZER SIDE TOO MUCH ICE FRIDGE SIDE NOT TOO COLD
If it has ice buildup on the back wall inside the freezer, it appears to have a defrost problem. Unplug it, put your food in another unit (or ice chests), open the freezer door and let it thaw out overnight for at least 12 hours or more, or until all the ice has melted from *behind* the back wall. Then close the doors and run it for 4 hours and check to see if the fresh food side is cold. If it is, call a repairman to fix the defrost problem. That could be a burned out heater, terminator, or defrost timer depending on your exact model.
Jan 03, 2010 | Whirlpool Refrigerators
Freezer is not working
Check the inside, back lower wall inside the freezer. If there is ice built up on it, you have a defrost problem. if so the heater is most likely bad and will need to be replaced. You can take a blow dryer and defrost the ice, removing the panel so you can defrost behind it also. Once you have, you can see the heater and at that time you can get to it to check it and see if it's bad. You can put the panel back on and turn the fridge back on and it will work right for 3 to 4 days. This will give you time to either repair it or have it repaired without loosing any food. Good luck
Dec 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Is there a drain hole in the freezer area on whirlpool model # ET18LK?
To get to it , remove the food from the freezer and remove the ice maker , if equipped , and remove the 2 screws holding the freezer bottom "panel" . Remove the 2 or 3 screws holding the rear freezer panel on , and remove the panel . About in the middle , under the coils , is the drain hole . If iced up , defrost the hole with a hair dryer until visible . Hot water will help defrost the hole . When water starts to flow , use a small piece of hose , inserted into the drain , and blow thru until clear . This will remove any debris built up in the unseen drain line .
Sep 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer quit freezing. temp now 41 fan blowing, coils clean,
Your defrost system is probably out. It's probably frozen up. Check your heater first, then the t-stat and timer. You will want to let the unit thaw out completely for a full day before replacing these parts. We have parts that we can ship to you. Hope this helps! Ella :>)
Aug 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer cycling on and off, will freeze then thaw out
You have a defrost timer that has possibly slowed down because it is defective. I need you to time the defrost timer or turn the defrost timer inside the fresh food compartment until the refrigerator compressor stops running. It should remain off for about 20 minutes. If a lot longer and the refrigerator does not defrost regularly about 3 times a day then it needs to be replaced. Yes there could be something other than the timer, but if you need my help I'm here let me know, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Jun 17, 2009 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
the first one sounds like it is slowly leaking freon.
  •  the second Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 28, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Don't let them tell you that the problem is related to "sulfur" in your water. It's a scam so that they don't have to repair the problem. The actual problem is that they don't use quality parts to build these units anylonger.
May 29, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
689 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
