Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
LCD screen does not show menu or play pictures
The LCD does not seem to be working correctly. It seems to work and not work at the same time.
When I take a picture, it WILL show that picture immediately after it is taken.
When I press the menu button, the menu screen WILL NOT appear. Likewise, when I hit the play button, it will not show the pictures that I have taken.
Any kind of help would be greatly appreciated.
Thanks!
advance
  • 107 Answers
SOURCE: Blank LCD screen
Thanks for that link, I will keep it handy! Be careful however, because the exact same symptom can be caused by a stuck shutter. To tell if it is a stuck shutter follow these steps: 1. Turn off the flash!! 2. Look down into the lens. 3. Take a picture. Did you see anything change? The opening at the center should be momentarily covered by a matte black shield. If you take a picture and see no change inside the lens then the shutter is stuck closed or open. If Canon finds your shutter to be stuck and not a CCD failure, the repair will not be free.. very not free. David Millier Advance Camera Repair
Posted on Mar 13, 2007
SOURCE: Digital Camera Malfunction
I have a power shot A70 camera. If you call technical support they are fixing the black screen issue free of charge including shipping and insurance. They are calling it a ccd issue with the power shot cameras.
Posted on Jun 06, 2007
t00nz
  • 4738 Answers
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
Posted on Mar 15, 2008
  • 31 Answers
SOURCE: camera won't take pictures LCD also won't work
get out your manual and find out how to do a reset. Then read the manual. if you can't do a reset take it back to the dealer you bought it from.
Posted on Jun 16, 2009
  • 7 Answers
SOURCE: My LCD screen is black. The camera seems to take
its actually probably the display. there is 3 different displays. 1. shows picture with icons 2. shows just the picture and 3. is a solid black screen. just hit the display button to cycle through until your desired display is present
Posted on Apr 05, 2010
Samsung SyncMaster 2232gw unstable
It seems from the begining you have had nothing but trouble, if under warranty return the item, because it will eventually fail, it is a matter of probability.
Apr 22, 2012 | Computers & Internet
Display works when you look at pictures taken but not in picture taking mode. you can still take pictures looking through the view finder but the lcd screen in dark.
This does not seem to be an issue.
Try this one:
Go to setup menu by pressing F button situated behind your camera. select the setup menu and go to LCD option put the LCD on. now check if it works the way you want
Oct 08, 2010 | Fuji FinePix S700 Digital Camera
Screen blacks out on certain channels randomly..doesn't happen all the time audio still works the picture just goes completely black for a bout a second then reappears.. very annoying.it's new and it also...
Ur LCD inverter backlight board have problems,just not dead yet.When ur LCD inverter backlight board is dead.U will get only sound and no picture at all.
Feb 26, 2010 | LG 55LH90 55 in. LCD HDTV
LCD not working
my samsung mini dvd had problem with recording, the screen would go black (though menu displays come up fine).
could do play back but not record.
i put it in the sun for awhile or in a warm spot and it will record and show display.
it is not a complete fix but worth trying (on top of the heater works good too). of course the fix doesn't seem to work when i REALLY need to record something.
also had stripes coming across screen recently on playback, gave it a good tap and the stripes went.
Jun 17, 2009 | Samsung Compact MiniDV Digital Camcorder
Canon Powershot SD1000: LCD screen display
Hopefully you resolved this already. If not, push the "DISP." button left of the MENU button. Pushing it gives you three options: black (for discreet shooting so your LCD doesn't give garner dirty looks from fellow concert goers), liveview, and liveview with info overlayed (shooting mode, ISO, etc.). Good luck!
May 05, 2009 | Canon PowerShot SD1000 Digital Camera
JVC GR-X5e camcorder, lens cap message. Does not show a picture.
It shows all menus, numbers and graphics on LCD, but seems like there's no picture coming through the lens. In both modes, video and still. It seems like it can not see anything as if the lens cap was on all the time.
Could this be a problem with sensor.. CCDs? Lens? Something else?
Feb 19, 2009 | JVC GR-X5 Mini DV Digital Camcorder
Sony DCR-TRV27
i have (or probably had) the same problem. Try this - there is a small reset button on the left side panel of the camcorder. While the set is on VCR model press this and keep pressed for 30 seconds or so. The corrected image should return and probably the problem would go away. I tried this by chance and the problem doesn't seem to recur.
good luck.
I have another problem though:
In my Sony DCR-TRV27 - A part of the left side console buttons do not work - the tape controls (REW, FF, STOP, PAUSE, PLAY) work alright. The Memory Stick controls seem to work alright. But, pressing the Menu button does not bring any menu display on the screen. Similarly, the scrolling wheel on the front seems not working. A couple of years back the moisture went inside (I went to Niagara falls!). For few weeks whole of the panel wasn't working but now most of it works. But I cannot get the Menu option work. I would be glad to hear if you have any other suggestions / advises. thanks for your time,
Nov 06, 2007 | Sony Handycam DCR-TRV27 Mini DV Digital...
Polaroid LCD only shows green verticle lines?
your picture tube is not blown you are having problem in the color circuit there is an ic that controls that circuit,the tv is also having a vertical problem an ic also controls that circuit you will have to call a tech to repair your tv good luck
Apr 27, 2007 | Polaroid FLM-2011 Television
Nikon S6- LCD screen black
I have The same problem with my S6, and was wondering if you found a solution? Ive done everything but contact Nikon or a camera shop.
Apr 16, 2007 | Nikon COOLPIX S6 Digital Camera
Projector won't show picture
My projector will not show the picture but i have sound
Oct 27, 2006 | Panasonic PT L711XU Multimedia Projector
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
32 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
