Hello, I have a zenith stereo console model E913 with a chassis 15wer55. I am trying to find a replacement needle. But can't find the model E913 listed anyway. thanks
3 Suggested Answers
Ganx
  • 113 Answers
SOURCE: I just inherited an old Zenith console turntable
Hiya, check and be sure the turntable is plugged into correct inputs, "phono"
If thats OK, then probably is the stylus but could also be the cartridge itself. Check the wires on the back of cartridge make sure they are fixed properly. If all Ok, then start with a new stylus first.
Hope it helps
Posted on Jul 25, 2009
SOURCE: Zenith Allegro console stylus
I have the same model with the 8 track player, original manual, and original receipt dated 1975.
Posted on May 21, 2010
Does old Zenith Allegro Console Stereo - 8 track/AM/FM/turntable, have a belt drive phono? I can see metal gears to drive the stuck turntable .
The manufacturers of such items would usually buy in such hardware as record turntables from fairly standard catalogues.
One popular brand of turntable was the BSR but the design of other brands were similar. The metal gears aren't for driving the turntable but to drive the multichange mechanism so when one record has finished playing another will drop from the stack loaded onto the extended centre spindle.
This type of turntable is driven by a synchronous motor with a multidiameter spindle via a moveable idler wheel equipped with a soft rubber tyre. Lack of maintenance causes many problems and as the rubber tyre ages it tends to harden and lose traction on the inside of the steel turntable so when the record reaches the end and the metal gears engage there is insufficient torque and everything stops.
It is for that reason many older examples have had the multichange removed or disabled.
Removing the turntable centre motif should reveal a circlip which when removed will allow the turntable to be removed for maintenance.
Jun 07, 2017 | Zenith Televison & Video
Can you replace the turntable in a vintage Zenith Console sterio with a newer turntable?
Generally speaking all you need to do is find the left and right channels leads from the old deck to the amp, cut them off or if thy plug in somewhere unplug them, then you can connected the playback leads of the new deck to the amp and it will then play back.
Jun 22, 2014 | Audio Players & Recorders
I have a Zenith Solid State Console Stereo model E939, which no longer plays in stereo. Any suggestions or solutions???
your botton could be jaming up open radio up blow it out with air in can then see what happens.
Feb 05, 2011 | Zenith Audio Players & Recorders
I have a sears console stereo recorder player model #528.30555400, serial #42471541. My problem is the needle fell off and I do not know how to put it back on? Can you help me?
Usually the needle is a part of the cartridge, and if it is not in a plastic holder intended to be removed, it is a permanent part of the phono cartridge and breaking it off requires replacing the cartridge as a unit.
Dec 27, 2010 | Soundcraft Spirit Epm 6 6 Mono + 2 Stereo...
I recently purchased a old Zenith stereo and turntable console. I am not sure what year it is . The model number says # Y804 and there was a nother number 8YTO2 which has the word chassis after that...
I have one of these with the number. I bet the turntable would work with yours. If you havn't fixed it please e-mail me at marc.lajoie2013@gmail.com
-Thank you and please let me know asap
Nov 25, 2010 | Zenith Audio Players & Recorders
Trying to find a way to get the turntable of a Zenith Allegro Console to work. We have turned to whole unit on and off. AM and FM radio plays. Turntable doesn't turn. At the bottom right of the turn...
Lift the turn table off the case and check the belt if it has one or the idler wheel that mechanically turns the table. Also check the motor to see that it rotates when you simulate a record play moving the needle carrier towards the center, The power must be on to test it. Becareful not to touch the 115 VAC line.
Oct 29, 2010 | Audio Players & Recorders
I just inherited an old Zenith console turntable and stereo combined. Stereo sounds wonderful, but when I play records, the sound isn't loud. Is this a problem with the needle or what? When I touch the...
Hope it helps
Jul 25, 2009 | Audio Players & Recorders
Jul 15, 2009 | Audio Players & Recorders
Schematic for Zenith SF 120 console/Chassis 3B31 and 9B22
This model is old enough to not be available electronically. Your best bet is to locate a Sams Photofact copy of the manual. Check your local library as many carried these. Otherwise, check the web for Sams. These are usually available for purchase for less than $15.
Dan
May 05, 2009 | Audio Players & Recorders
343 people viewed this question
 Grubhead
Grubhead
