Question about HP Officejet 7310 All-In-One Printer
My problem is with the scanner. The error message
My problem is with the scanner. The error message says can not aquire image. This is unusual. It has always worked before. I was trying to scan from the glass - to windows word.
SOURCE: brother 5460cn won't scan to email,file,ocr,image
i have the same problem and it was resolved after downloading the control center updater.
here the link
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/dlf/000000/003100/dlf003176.html?reg=us&c=us&lang=en&prod=dcp130c_all&type2=2&os=7&flang=8&dlid=dlf003176
Posted on Nov 20, 2007
Riztech
  • 731 Answers
SOURCE: My scanner always scans with blurry lines across scanned images from it
I believe that you are trying to scan via HP solution center.
Did u tried scanning from Scanners and Cameras in control panel, and did u notice any lines?
If u get the same lines, we have to remove the USB Composite device and imaging device drivers.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Check for Imaging Devices, click on + sign, then u will see "hp photosmart c3100" right click on it and click Uninstall. Then, Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HO DESKJET F300)
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
7.Try scanning.Please let me know after following the steps!
Posted on Feb 09, 2008
  • 4 Answers
SOURCE: The scanner dont work in my HP officejet 5610 all in one
This is a known issue with HP printers. Do not worry, if you get this message that the scanning software could not be found the please go to the link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=441125&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
Select the Operating System.
From the list select. ... HP Full Feature Software and Drivers
Then scroll down to the 3rd option......
Click on Download only >> Save the file to the desktop.
Start installation and make sure that the Printer is not connected using the USB cable to the computer.
While installing, you will get the option to connect the printer. Do not connect the printer.
Select the option "I will connect it later". Go next the installation will be complete.
After the installation is complete...leave the CD inside the computer.
Connect the computer and the printer.
It will show you the configuration window.
Wait until you see the "Start using the device" option.
Click on "Start using the device".
You should see the solution center window now.
If it is succesfull. Try scanning using the Solution center.
If it is succesfull, you can now scan using the printer as well.
Try it and let me know if it works and please let me know your issue in detail.
Posted on Aug 05, 2008
  • 1894 Answers
SOURCE: Problem with scanning both from the auto feeder and from scanner glass
this is what HP has to say
This document applies to all HP product models. Issue When the product is turned on or in the middle of an operation, an unexpected noise occurs, such as clicking, thumping, or grinding. Blinking lights and error codes might accompany the noise. NOTE: Noises can be caused by a number of things. This document focuses on isolating, identifying, and resolving known causes of product noises. Solution Noises are subjective and can be difficult to describe. Some noises are normal to the operation of the product and might include the following:
  • The product might make humming and buzzing sounds as the carriage moves around on the right or left side of the product while cleaning the ink cartridges. This is normal when a product is turned on, before and after printing, after a product has been on standby for some time, after replacing an ink cartridge, or in the middle of a large print job.
  • During a print job, the movement of rollers, gears, carriage, and paper (paper feed and ejection) creates some noise.
  • During a print job, if the product is printing in the fast or draft mode, the noise level might be higher than when using the best or normal mode.
  • At the end of the print job, a louder clicking noise occurs as the paper is pushed to the output tray.
  • At the end of a print job, a noise emanates from the left or right side of the product as the pens are capped. The product might try to do this a couple of times.
Abnormal noises are a symptom of a problem. The most accurate way to determine the origin of a noise is to isolate where it comes from and when it occurs. Use the following steps to try to isolate the noise issue. NOTE: Error codes might indicate the source of the noise. Make a note of any error code or blinking lights that appear. Step one: Check for loose or broken parts
  1. Raise the cover of the product.
  1. Check inside for loose or broken parts.
  2. If there are broken parts, the product needs to be serviced.
  3. Step two: Make sure that accessories are installed correctly
  1. Press the power button (c00636182.gif ) to turn off the product.
  2. Remove the power cord from the back of the product and unplug the power cord from the power source.
  3. Check any accessories (duplexer, envelope feeder, automatic document feeder (ADF)) to make sure each is installed and seated correctly.
  4. Plug the power cord into the back of the product and plug the power cord back into the power source.
  5. Press the power button (c00636182.gif ) to turn on the product.
  6. If the noise still persists, remove each accessory one at a time to try to determine if the noise is associated with a single accessory or a combination.
  7. If the noise stops when a specific accessory is removed, that part might need to be replaced. If possible, exchange the accessory with a known good one or a new one to determine if the noise is associated with the accessory. NOTE: If the product is fully functional with the accessory in place, the noise might be normal.
  8. If the noise persists, proceed to the next step.
Step three: Check connection with computer Turn off the computer to determine if the computer is the source of the noise. If the noise persists, proceed to Step four. If the noise stops when the computer is turned off, try to isolate any issues with connectivity:
  2. Disconnect the USB cable from the product.
  3. Unplug the power cord from the wall outlet and from the back of the product.
  4. Wait a couple of minutes to allow static to be discharged.
  5. Plug the power cord into the wall outlet and plug the power cord into the back of the product.
  6. Connect the product to a different USB port.
  7. Turn on the computer.
  8. Press the power button (c00636182.gif ) to turn on the product.
  9. If the noise persists, service the product.
Step four: Check for a paper jam Paper jams can prevent the internal components of the product from moving, which can create unusual noises.
  2. Disconnect the power cord from the back of the product.
  3. Remove the rear access door.
  4. Remove any paper that is inside the product by pulling it out through the rear access door and then securely replace the rear access door.
    1. If a paper jam cannot be removed from the back of the product, raise the product cover, carefully remove the paper jam from the front of the product, and then lower the cover.
    NOTE: Remove any paper jam carefully as it is possible to damage the product when removing a jam from the front of the product.
    1. Reconnect the power cord to the back of the product.
    2. Reload the paper in the paper tray.
    3. Press the power button (c00636182.gif ) to turn on the product.
    4. Try to print. If a jam is cleared and the product prints, but the noise persists, proceed to the next step.
    5. Step five: Make sure that the carriage moves freely
    2. Disconnect the power cord from the product.
    1. Make sure that the ink cartridges are locked into the carriage and have not come loose. Also make sure that there are no obstructions under or around the carriage to prevent it from moving.
    2. Close the product cover and reconnect the power cord.
    4. If the noise persists, proceed to the next step.
    5. Step six: Plug the product into a wall outlet
    If the product is plugged into an uninterruptible power supply, that source might make a beeping or whistling noise.
    1. Unplug the power cord from any power strips or surge protectors.
    2. Plug the power cord directly into a wall outlet instead.
    3. Press the power button (c00636182.gif ) to turn on the product. If the noise persists, proceed to the next step. If the noise stops when plugged directly into a wall outlet, the power strip or surge protector might not be allowing sufficient voltage to reach the product and might need to be replaced.
    Step eight: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Comments by scrodamoon in premium
    • 4 Answers
    SOURCE: cannot retrieve application list on scanner
    try boosting the power couplings followed by initiating the inter-active recipter valve. Once you see the deflanger code type in +.ak234//pp.HO.
    This open up the transducer allowing the flow of typherical codes that was being block preventing you scanner from downloading the application list.
    If this doesn't work, write your Congressman.
    Posted on Nov 08, 2008
    Error message
    Incorrect or incompatible driver. See if there is an updated driver.
    Mar 08, 2014 | VuPoint Solutions Digital Film Converter...
    I have canon PIXMA 145. I am not able scan . The moment i place paper and press scan it is showing " printer under repair error code is 2.144.0" Can u suggest me anything. Is it a machanical...
    I have many years reparing canon scanners so here is my suggestion to you.
    When I do my scanning, and by the way I own a canon pixma also. I do it through the software I never hit the scan button. You can do it through Microsoft paint by using from scanner or camera and aquiring and image. I use paint shop pro so I just open that program and just aquire an image from my scanner. I hope this helps you out but I think its a software problem, because the software takes full control of the scanner if you do it the way I just suggested.
    I hope this helps you out.
    Feb 28, 2011 | Canon Office Equipment & Supplies
    My scanner will not scan i think the software is gone off my computer
    A couple of things could be out of place.
    First of all, you need to use software that can scan, some scanners come with software to use, otherwise you have to use an image program that can "Aquire".
    "Aquire" is usually found in a file menu of image editing programs, except Microsoft Paint.
    In the case of "Microsoft Office" programs, it's in the Insert-Image-from scanner or camera menu.
    If your scanner is not listed in these menus, or Aquire dosn't appear on these menus, your scanner driver is not installed. That then will be your first step.
    Hope this helps.
    Dec 11, 2009 | Fujitsu fi-5120C
    Mustek "BearPaw 1200CS Scanner. Micro-star international MS-7222 2.00 Desktop PC newly aquired. Running Windows XP Professional SP 3 Problem:- Installing Scanner from disk fails with message "cannot...
    Maybe you are not following the official instructions properly?
    Please visit this link to download the latest driver and this link to view correct install instructions.
    If this does not solve your problem, do as follows:
    Create a new account with administrator rights from the XP control panel.
    Log on to this new account and try to install the scanner again.
    I am waiting for your reply.
    Oct 15, 2009 | Computers & Internet
    I just bought a new lexmark copier, scanner, fax,
    This should give you a good explanation of what ocr is.
    http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_1268319518_0_en,00.html
    Jul 07, 2009 | Lexmark X3550 All-In-One Printer
    Require driver for Ion Slides 2 PC ... using Vista 64 bit.
    MY ION SLIDES 2 PC WORKED WELL WHEN I HAD VISTA BUT SINCE CHANGING TO WINDOWS 7 IT WILL NOT WORK WHEN CLICK ON AQUIRE I GET THE MESSAGE CANNOT FIND THE SCANNER. PLEASE CONNECT 35MM FILM SCANNER. I HAVE UNINSTALLED THE PROGRAMME AND REINSTALLED IT BUT SSTILL GET THE SAME.
    Feb 22, 2009 | Office Equipment & Supplies
    Canoscan 4200f Light on No buttons working when pushed
     go in the computer software like windows photo gallery and scan an image or document.If the settings are corect as you say it should give you the option to aquire image from scanner
    Oct 02, 2008 | Canon CanoScan 4200F Flatbed Scanner
    Editing text
    Windows
    » HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
    Macintosh
    » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
    Jun 13, 2008 | HP 4570C Flatbed Scanner
    Sleepy Scanner?
    try using windows driver first, so that we will knowif there is a problem with your scanners driver.
    Open paint and click on file and click on from scanners and camera and let me know if it will give you an option to scan from that app or if you will get an error message.
    Apr 02, 2008 | Epson STYLUS CX5900 Printer
    How do I use the scanner?
    Although I am not that familiar with the Mac systems....
    Open your Imaging program, Paint program or whatever program you have to view/edit pictures and photo's. If the proper system files are installed you should have an option to 'Aquire' or 'Import' from the scanner. Your Document reader/writer programs may also have options for aquiring from the scanner also.
    Feb 24, 2008 | Brother MultiFunction Center MFC-440CN...
    23 people viewed this question
    Seeker5211
    Seeker5211
