Question about Chicago Faucets 733-OHCP Urinal Valve....
Water run on in chicago 732 urinal valve
Water run on
  • 127 Answers
Valve is sticking inside....need to get repair parts or replace valve.
Posted on Oct 18, 2009
How do I increase the water pressure when flushing a wall-mounted urinal?
I don't know witch valve you're working with but most volume control adjustments are located under a screw off cap on the front of the valve. Remove that cap and there will be a small slotted screw that when you turn in it reduces the flush time and out increases it.
Feb 08, 2011 | Eljer 161-1190-00 White Bedfordshire Wall...
Water leaking on floor...when flush..no urine water
Before you flush the toilet, take the top cover off the tank.
Then flush.. Sometimes water sprays from the float valve,
sprays up against the underside of the cover, then runs down
the back of the toilet.
All my best to you.
LeRoy
Nov 01, 2010 | Toto - Toilet - One-piece - Ultramax -...
Compressor will run but not produce air
Check your safety valve is closed by pulling it out and releasing it. You can use a mixture of dishwashing soap and water to drip on the valve to see if it makes bubbles identifying a leak. Next make sure the petcock valve on the bottom of the tank is closed and not leaking by using the soapy water again. If you cannot close or fix the valve replace it. The next trouble shooting will require checking the air input to the tank but be careful since the tubes could be hot.
Aug 18, 2010 | Chicago Pneumatic Qrs 5 HP/3 Phase Rotary...
Push valve for urinal adjustment. How do we
HI im Rossouw
Most sisterns with 2 buttons 1 for urin 2 for bouls have have a button on top of the sistern
Remove the lid of the sistern by thast lifting it or unscrew the head of the bottem
After the lid is of iets easy, wear the arms are of the indevidual bottons u mist thast find the 1 u want to be urin and turn it right for less water and left for more water
Plz rate mt advice thanx
Jul 12, 2010 | Mansfield Plumbing Products Mansfield...
I have a Sloan urinal that will not stop flushing. I have rebuilt it with a total rebuild kit. I cleaned the inside of all surfaces and I flushed the entire piping system to no avail. It will not stop...
The rubber vacuum relief needs to also be changed if you have not. It is located in the tube that runs down to the urinal from under the flush valve. The handle could be hanging up.....or there could still be sediment stopping the diaphragm from working properly.
Nov 21, 2009 | NRS 180-1.5 Sloan Exposed Urinal...
I need a blue print on how a sloan urinal flush valve works and how the water flowes through it. if posable exactly how it works.
SLOAN FLUSH VALVES ARE SIMPLE. IT DEPENDES ON THE PROBLEM. IF THE VALVE KEPS RUNNING AFTER IT IS FLUSHED THE RUBBER DIAPHRAM IS DIRTY OR OLD AND THE RUBBER DIAPHRAM IS GETTING HARD. AND STICKING. THE VALVE WORKS ON A VACUME TO CLOSE THE DIAPHRAM TO STOP THE FLUSH PROCESS. WHEN YOU PULL ON THE FLUSH HANDLE YOU BREAK THE VACUME THAT FORM ON THE TOP OF THE DIAPHRAM WHICH ALLOWS THE WATER TO FLOW AS THE WATER FLOWS IT IS ALSO STARTING TO PULL A VACUME IN THE TOP OF THE DIAPHRAM TO CLOSE THE DIAPHRAM AND STOP THE FLUSH.
AS THE DIAPHRAM GET OLD AND WORN IT GETS HARD AND DOES NOT MOVE AS FREELY AND STICKS OPEN AND WON'T LET THE VACUME CLOSE THE DIAPHRAM AND THE URINAL WILL CONTINUE TO FLUSH. HOPE THIS ANSWERED YOU QUESTION
Oct 01, 2009 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
Urinal leaks need help
You will have to shut water off, that is what the screw does(so it can be worked on). you will need 2 pipe wrenches, always use 1 wrench to back up or hold fixture when using other wrench to open valve. That said with top of valve off now you can replace the flush valve diaframe. You can go lowes or some other improvment store/
Sep 19, 2009 | Toto TEU2DNS-11 Commercial Electronic...
Chicago forge horizontal air compressor will not build
Here are some simple tests that will help solve your problem. Check for leaks with soapy water on all the joints and the drain valve. With compressor running and it has reached all the pressure it can muster, remove the air filter and place your finger over the intake port, you should feel good suction and the compressor should speed-up if pump is working and pressure is leaking out. If you feel good suction then pressure could be leaking past cylinder/ring if it is oilless. Check upper part of cylinder for scratches or torn vinyl ring. If you do not feel suction, but rather air blowing out of intake then you may have bad reed vales or torn gasket in head. Another simple test is to run compressor for a few minutes and disconnect power then listen for air leaks at the pressure switch unloader valve. If leaking replace the in-tank check valve (brass valve). Follow the discharge airline to the tank, there you will find the checkvalve. Good Luck and email if you have questions.
May 03, 2009 | Chicago Forge AF4HH 15 - Gal. 4.0 - HP...
Hot water first from faucet, two minutes later cold???
you could be having a problem elsewhere in house system! do you have a garden hose hooked up with a "Y" hose? or something in system were hot and cold connect...then a valve after? what happens is the hot water can back siphon through cold lines..its rare, but this happens, and is dangerous! water from hot water tank is full of bacteria, and if you drink it , well thats not good!
Mar 26, 2009 | Chicago Faucets CHICAGO FAUCET Mixing...
Chicago Faucets 733-OHCP Urinal Valve.... Logo
109 people viewed this question
Top Chicago Faucets Plumbing Experts
Paul Carew
Tom Chichester
Are you a Chicago Faucets Plumbing Expert? Answer questions, earn points and help others
