Question about Broan-NuTone Allure III QS330SS Kitchen Hood
The fan keeps on going even after it is turned off? Is there a way to shut if off?
  • 396 Answers
Replace the On/Off switch. Lowes or Home Depot may have the switch in the lighting or electrical dept. If not, try your local Ma and Pop hardware. They might even help you put it in!
Posted on Sep 29, 2009
The fan doesn't turn off even the oven is not in use,the cooker is almost brand new
draft fans are not usually controlled by any front panel controls , no they work strictly by temperature , they keep going till oven cools off then shut down , now if it never stops even if oven is ice cold , then the control that feeds fan is defective and needs service
Sep 28, 2015 | Ovens
Why does fan motor keep running after engine is shut off
This is normal and there should even be a warning label near the fan shroud. It is cooling the radiator and as long as it eventually does go off there is nothing to worry about.
Jul 21, 2014 | 1999 Dodge Caravan
The Auxilliary FANS keep on turning ON even if the engine is stop or no ignition please HELP
The fans will run even if the vehicle is off. This is to keep the engine from overheating
after it is shut off. (residual heat). Now if the fans run continuously after the
vehicle is shut off and do not shut off in say, 15 minutes then the fan relay may
be stuck or the temperature sensor has failed. The fans may also come on after
a long drive several minutes after the vehicle has stopped as heat builds up
because there is no air flowing across the radiator. They may even be controlled
by the engine computer in some vehicles. You can have a code check
run at many parts stores for free.
Also, check the coolant
level with the vehicle off and totally cold at the radiator itself to be sure that
it's not low (Even if the reserve tank is full you can still be low creating hot pockets in
the block). Make sure the overflow tubes are connected to the reserve tank
I have seen them fall off and drain the radiator slowly without being noticed.
Hope this helps.
Mar 30, 2011 | Mitsubishi Montero Cars & Trucks
Honeywell Chronotherm iv fan keeps running even when heat and cool turned off. How do I turn it off?
To turn the fan off, press the "fan key" until it says "auto". This will turn the fan off. When the programs scheduled, changes, the fan will go on again. You have to repeat the fan to "auto" each time the schedule changes.
May 12, 2010 | Honeywell Programmable Thermostat Heater
Both motor fans keep running after car is shut off
Faulty fan relay, little square box, costs an arm and a leg. Try the local automotive parts recycler, you can't get BWM parts at the junkyard :)
The little box is located, with teutonic efficiency, next to a bunch of little boxes just like it. Check your owner's manual or a shop manual for which one it is.
Sep 03, 2009 | 2001 BMW 325
The fan motors keeps running after car is shut off. Also sometimes fans start when car is started cold.
If the fans didn't run any further the engine continues to warm and possible seizure will occur. This is also the reason you will probably go through batteries in the long run. Hopefully this helps the issue you are having.
May 25, 2009 | 2003 Mazda MPV
Blower fan keeps running even aafter the engine is shut off
3 Inspect Thermostat Faulty Thermostat. 4 Inspect Antifreeze Needed Coolant Level Low.
Mar 27, 2009 | 1993 Buick Park Avenue
Honeywell Thermostat RTH 7500
In some cases the fan will keep running to remove all the heat from the heat exchanger.It can be set to run shorter or longer.You might check that out.
Mar 16, 2009 | Heating & Cooling
Fan keeps running after engine is turned off
why does the cooling fan start working as soon as i start the car and doesn't shut off until i turn off the car?
Oct 05, 2008 | Mitsubishi Lancer Cars & Trucks
Broan-NuTone Allure III QS330SS Kitchen Hood Logo
261 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
