Question about Garden
Craftsman 4 cycle weed wacker, only runs while choked. If I ''un choke'', will only idle, press the trigger and it stops. I checked the spark plug, put in fresh gas, cleaned ''spark screen'' in muffler. No luck. I don't see any carb adjustment screws. Is there a way to adjust carb?
  • GeorgeGalo Sep 29, 2009
    Thanks Dolfoff, I appreciate the help.
    George
  • 148 Answers
Be sure fuel lines are healthy...especially any places where they bend. If you feel confident enough you can go into the carb itself and check the inlet screen which is just under the inlet needle. These are a common trouble spot.
The screen will appear to be fine at first glance, but remove it and hold it up to the light and you'll find it to be swollen completely shut!
Might as well install a kit while you're in there. It's only about 10 bucks and the amount of time and effort it costs you is the same.
NOTE: Get a "REPAIR KIT" for your carb...NOT just a diaphragm kit.
Zama carb repair kits found here.
Walbro carb repair kits found here.
Hope this helps!
Posted on Sep 29, 2009
Testimonial: "DolfOff gave a complete detailed explanation, complete with links to the parts websites if needed. Thanks!"
Weed wackier gas trimmer
didnt specify the make and model so generic answer ---check fuel mixture is correct --check the filter in tank is not plugging up--look for damaged / crack in fuel feed lines-look at spark plug --carb may need cleaning --exhaust port may need cleaning
Jul 04, 2016 | Garden
Craftsman weed wacker will start and run
Are you sure you have the right fuel mixture? Many of these require 2 Cycle oil to be added to the gas. If fuel is right, you may have a vacuum leak at the carb (or crack in base where it mounts to the engine). My weedwacker needed to be run on half choke for about 10 min before it got hot enough to run with choke off.
Apr 29, 2012 | Craftsman Weed Wacker Lawn Edgers
I have a craftsman weed wacker model 316.79197 It will cut off when i pull the trigger to give gas. what should i check ?
Be sure the exhaust port is not clogged. Be sure the choke lever is in the run position. Also you might try letting it warm up half choked before you "pull the trigger"
Apr 02, 2012 | Craftsman Garden
Never used weed wacker before I have a Echo SRM225 how do you start the darn. thing..? :) I have pulled and pulled and no I am not out of gas. :)
You need to put it in full choke. If it is in full choke and still won't start, try pulling the trigger a bit. once you have it started in full choke, back it down to half choke and hold down the trigger until it catches. Once it catches take the choke off entirely WITHOUT removing your finger from the trigger.
May 20, 2011 | Echo Garden
Hard start tb475ss troy built weed wacker when i close the cold start lever it starts but its 75 degrees out its like the primer ball is inop but i see fuel moving through the lines when priming did not...
These 4 cycle trimmers need to be primed 10x before a cold start. The bulb will feel *firmer* on the last two or three depressions and you'll know that the carb is primed.
Full choke and and full throttle on first tug should see it hit once with a puff of smoke. Second start attempt should be in choke position two (half choke) and with full pressure on the throttle. Should rev to life on start attempt. Let the engine IDLE for 30 seconds, moving the choke to off at the end of the waiting period. Let engine idle to warm another full minute with no choke, then set to work!
May 02, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Redmax weed wacker wont stay running
Have these unit been stored with fuel in them or sitting around for a long period of time? If so the carbs may need to be overhauled. Also check for a clogged fuel filter and vacuum test the fuel lines for cracks.
Apr 12, 2009 | Garden
Garden Logo
270 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
