Question about Sanyo DS20425 20" TV
My Sanyo TV Model number DS20425 will not stay on. It comes on for about 2 sec then turns back off. You can do this for about three times then it will not even try to come on.
Look for d482 to be shorted if it is ecg 552 will replace and r482 will be open too iused a one ohm 1 wat res to replace so far it working just fine
Posted on Dec 04, 2009
Play xbox sanyo tv
The best option is to try a different component cable and inspect both ports for any wear.
Alternatively, try the same cable on another TV if you have one near by.
Jul 01, 2017 | Sanyo DS20425 20" TV
I can not get my rca remote to work on my Sanyo model DS20425
If you don't have the code, you could do a code search and when you hit the code search button on the remote, continually hit the power button until your tv turns off. Then save it, but it may take awhile. You may have to hit the power off a 100 times or more if you don't have the code.
Nov 13, 2011 | Sanyo DS20425 20" TV
I am trying to program a jensen universal remote -- model no. jer422r55n74919p to a sanyo tv -- model no. ds20425 PLEASE HELP
Try these found soultion on Fixya!
1. Manually turn on your component.
2. Press and hold the component key you wish to program, in your case the TV key.
3. While holding down the component key press the four-digit code using the number keys (0-9) to enter it.
4. After the fourth number is entered, the illuminated ON-OFF key turns on. At this time, release the comonent key. If the illuminated ON-OFF key turns off, you have entered a valid code.
NOTE: For Sanyo TV it could be any of the 8 next codes:
1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180
Good Luck !
If that fails try the manual search as follows:
For a manual code search and entry:
1. Turn on the component
2. Press and hold the component key (TV, DVD, VCR-AUX, SAT-CBL)
The illuminated on-off key turns on and stays on
3. While holding the component key down, press and hold the ON-OFF key. The illuminated ON-OFF key turns off.
4. After holding down both keys for three seconds, the illuminated ON-OFF key turns back on.
5. Release both keys. The illuminated ON-OFF key remains on
6. Press and release the ON-OFF key repeatedly until your component turns off. Wait four seconds between each keypress. Each time you press the ON-OFF key, the illuminated ON-OFF key blinks, and the next code in the list is sent. This process continues until all of the codes in the code lists have been searched. If your component turns off, you have found the correct code. (If it cycles through and the illuminated ON-OFF key blinks four times and turns off, all codes have been search. The manual code search method is exited.)
7. Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON-OFF key turns off. You must press the STOP key to save the code or the correct code will not be saved.
8. To confirm that the component is programmed with the correct code for max functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your component do not work try programming the remote with a different programming method. Be sure to retrieve the code your remote programmed.
Please let me know if this works for you.
Thanks and good luck!
Feb 10, 2011 | Televison & Video
Turns off after 30 seconds
i think the convergence amps are weak, or the akb circut has caused the tubes to go bad, google your model number to see if it is in the tube problem. sony made some projos w/ bad tubes in them. tv lasts only three or four years,no cause i had one
Jul 10, 2009 | Sony KP-65WS500 65" Rear Projection...
Sanyo model DS20425 remote control not workimg. Changed batteries, did not help. Do I need code? If so where do I find it?
CHECK THE INFRARED LIGHT ON THE REMOTE AT THE TOP.. WIGGLE IT TO SEE IF ITS LOOSE, IF SO, SIMPLY OPEN IT UP AND RESOLDER THE LIGHT... SOLDER GETS OLD AND BECOMES LOOSE SOMETIMES
Jun 07, 2009 | Sanyo DS20425 20" TV
Remote codes
need a code for neon 32"tv model no 3298
May 11, 2009 | Sanyo DS20425 20" TV
Remote code
Just ask at http://manualfox.com/remote.htm
- they find you every remote code. Send them model #s of TV and remote!
Apr 16, 2009 | Sanyo DS20425 20" TV
Moved tv and it went dark
BE VERY CAREFUL!! This area is part of the output transformer which produces the HIGH voltage to the screen. The one to adjust is the SCREEN control. I would be surpised if just moving the TV would have caused this to have altered.
Mar 28, 2009 | Sanyo DS20425 20" TV
Programing codes
Here is the link I just found the manual on for this remote control, which I needed the codes for myself: http://safemanuals.com/brand-user-guide-instructions-owner-manual/RCA go there type in the remote model RCR450 enter, click on the link that comes up and download the Manual in PDF form.
The codes for Sanyo are 1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180 depending on which model you have.
OR:
1: Turn on the device you want to program ex: the TV
2:hold the button for the device you need to program in ex:TV
while holding down TV button hold down ON/OFF at the same time for 3 secs and the light should turn on and stay on.
3:click the ON/OFF button until the TV finally turns off may take many times but as long as the light stays on when your not pushing a button you still have codes to go through.
4:press the stop button and the device is programmed into the remote.
Mar 11, 2009 | RCA RCR450 Remote Control
Looking to replace lost remote for Sanyo TV Model #DS20425 can you direct me for replacement
The Sanyo part number is: 6450656934
It used to cost about $25, but is no longer available from the distributor I use. Hopefully the part number will help. Realize that most universal remotes should work just fine. Just be sure to get one that has a menu button.
Dan
Jul 15, 2008 | Televison & Video
Sanyo DS20425 20" TV Logo
500 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
