GE Profile JGP636 Gas Cooktop
Problem for GE Profile JGP636 Gas Cooktop
I have a JGP636 or 960. One burner won't \r\ndo
By burdickdebbi on Sep 29, 2009
I have a JGP636 or 960. One burner won't do the click, click, click when turned to lite. We have replaced the electrode MS21, buy it still won't ignite. What else do we need to do?
Thank you,
Debbie Burdick
Best Solution
posted on Sep 29, 2009
Very Helpful)
muebe
Rank: Guru
Rating: 90%, 258 votes
When you turn the burner knob on does the igniter click and turn off on it's own when the flame ignites? If it does then it has flame rectification. That means it can sense when the flame is on. Or does it click when the knob is in the light position and not stop until you move the burner knob? Then this is standard ignition. If it is standard ignition it sounds like it is the igniter switch built into the burner knob might be defective. Are you able to turn on any burner knob and when they are in the igniter position do all the electrodes spark or just the burner that you are turning on? If they all come on then they are wired in a series. If they are wired in a series do you get a spark at the electrode of the problem igniter? If so you can turn on one of the other burners to ignition position then while it is clicking turn on the problem burner to light it. If the cooktop uses flame rectification then there may be a problem with the switch built into the burner knob or the flame rectification sensor for that burner might be bad.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 11, 2009
Not Rated)
nomail254
Rank: Guide
Rating: 75%, 3 votes
change the spark module...before you do that take the wire from the burner thats not working and switch with different burner at the spark module located at the back...if still not working you might need igniter order at searspartsdirect.com
Was this helpful?
Yes
No
Popular Solutions for GE Profile JGP636 Gas Cooktop
Questions and Unsolved Problems for GE Profile JGP636 Gas Cooktop
Do you recommend GE Profile JGP636 Gas Cooktop?
Answer
Answer
I have a GE Profile gas stove bought in 1994. I need the oven cleaning instructions.
Answer
first time using new ge profile the grate became scratched...what kind of pots/pans will not scratch... (More)
Answer
My indicator on light stays on all the time. Even when top is cool
Answer
What is the best way to clean a Jenn Air downdraft fan? What degreaser would you recommend?
Answer
electric cooktop, ge profile. no heat from the burners, indicator lights work, panel breaker is ok
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Profile JGP636 Gas Cooktop:
Top Kitchen Cooktop Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Kitchen Cooktop Experts
Top Range & Oven Repair
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
