Question about Garden
Can't find a replacement belt for Scotts Self propelled
My bely came off and as luck would have it I can't read the part number on the belt now. The mower is a Scott's 21'' rear driven self propell.
6.5 Intek 3 in 1.
  • Chuck
    Chuck May 11, 2010
    What is the Mfg. Model Number of the lawnmower?
  • 389 Answers
It should be a MURRAY part number 37X84 ( NOTE: that is read 37 "ex" 84 NOT 37 "by" 84, it is a part number not a measurement) but without knowing the exact model number of your lawnmower, I can't say for certain.
Posted on Sep 29, 2009
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
Self propelled not working
The weakest link in your problem is the belt, and it's path. The belt comes off the engine crankshaft and goes to the self propel shaft at front or back of your mower. I believe your problem is that your belt has broken, or just slipped off of a pulley. Check the drive belt and you should be OK. GOOD LUCK FRIEND.
Sep 15, 2014 | Garden
Self propelled feature stopped functining. I previously replaced the wheels after the gears had worn down. Now I can't get any response to engaging the self-propelled cable.
Have you checked the drive belt? There should be a belt running from the main shaft (above blade) out to the wheel drive. You didn't list model number but I'm assuming it's front wheel drive. There should be a cover over this belt so it might be hard to see from underneath. Also there should be a cover on top going to the drive transmission. If the belt is OK, check to be sure lever is moving the transmission lever.
Oct 30, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Self propelled mower no longer propells
SOUND LIKE THE TRANS IS WORE OUT
Oct 01, 2009 | Garden
Self Propel Belt, how to replace with the new one
First I suggest you either take a digital picture or draw the belt wrap...that way you'll know how to wrap new belt. You'll need to remove both front wheels and pinion drive stubs. Slide the shaft out far
enough so you can install new belt on lower sprocket. push belt up through access opening in deck.
Then finally install the new belt..make sure to slide belt over sprocket on shaft coming out of motor block last. It might require a std. screwdriver to slide belt over edge of sprocket. Re-assy wheels etc.
If you feel like this task is too tough..just draw yourself an assy. drawing as to how it comes apart, it will be worth it when you re-assy.
May 29, 2009 | Toro Lawn Mower With Toro Power Tools
Hoover wind tunnel u5755-900. smoke, smell. self-propel
Can you verify the model number? However, based on your posted description, it sounds like the flat belt is either broken or fell off. to access the belts turn it over and remove the bottom plate (4 screws). the Flat belt will connect to the motor shaft in the back and the large black pulley.
Mar 13, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Install self propelled belt
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=647063
Generic problem for all Vacuums
Posted by wmtp on Jun 04, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Usually the self propelled vacuum have 2 belts and you should replace them both 2 the same time 1st the self propelled belt and then the brushroll belt. Normally you would hook the belt on the pulley side of the brushroll or self propelled unit and then stretch the belt onto the motor pulley side of the motor using a belt puller or a screwdriver with a bend on the end for pulling and or stretching either belt onto the motor pulley. If you have a problem please feel free to contact your local vacuum cleaner dealer.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 04, 2008 | Vacuums
Garden Logo
434 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
