Question about Maytag MDE16CS Electric Dryer
No heat My old commercial maytag dryer ws working fine for many years. Today, it seemed to be running fine until I noticed it was not heating up. Any suggestions?
  • 304 Answers
While your model number is not listed on the Service Manual at the link below, you will find information on how to check out the heater on page 8-6.
Good luck
http://www.servicematters.com/maytag_library/docs/16023110.pdf
Posted on Sep 29, 2009
I have a maytag neptune which is about five years old. It runs fine, but the dryer does not heat up. What should I do orcheck to diagnose problem?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 11, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Drum runs and does not heat. The dial does not move. It does not shut off. It is a Maytag gas dryer about 12 years old. Has worked great untill this problem.
heatman101
Apr 19, 2011 | Maytag Dryers
HI, i was an appliance technician for 8 years but seemed to be stumped> i have a maytag coin op dryer but the model # and wiring diagram are missing. its an older style with the big idler. anyways,...
One way you could isolate the problem is to unplug the quick connect to the transformer and take the heat portion out of the equation ( just to see if the dryer starts on it own only). If the starting on it own goes away then you have it somewhere in that portion of the cycle. Probably 2 wires rubbing somewhere. Why do we need a dang transformer in a dryer? That would be the suspect to me. Never even seen this before. Hope you get a solution. Hope you post it.
Jan 18, 2011 | Maytag MDG16CS Gas Commercial Dryer
Replacing a heating element on Maytag Electric Dryer
Hank,
if you have all those parts , i would indeed replace them all. it will allow your entire heating circuit to strat fresh
just ensure all your paddle connections are tight
but check your heater for continuity too
Oct 21, 2009 | Dryers
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer won't heat up! It tumbles fine, but no heat! My Maytag dryer is only two or three years old!
This problem is normally caused by a faulty thermostat and or heating element. Test and replace if needed
Sep 23, 2009 | Maytag Dryers
Dryer is not heating up
if the dryer has no heat
1) first check the power cord at the terrmial block make sure the connection is not burn.
2) you will have to take the top off check the satety thermostates .
3) check the heater element for open heater
let me know
Dec 21, 2008 | Whirlpool Dryers
Maytag neptune dryer MD6
All you need to do is check the element for continuity with an ohm meter, if it has continuity the element is good. The dryer also will run on 110 volts of power but it needs 220 volts too run the element, so check and make sure all the conections on your cord are secure and that you have 220 at your wall outlet.
Jun 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Whirring noise in clothes dryer
check rear tub rollers and also check the idler pulley
May 11, 2008 | Dryers
Maytag MDE16CS Electric Dryer Logo
150 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
