Question about Canon PIXMA MP160 All-In-One InkJet Printer
Canon mp160 cartridge belt that pulls the cartridges has fallen off! it fell off the right side (inside of printer). wHERE IS THE ROLLER LOCATED THAT IT MUST BE ATTACHED TO?
SOURCE: Change ink cartridges
Unlike many printers, the Canon Pixma MP160 is designed to have the power on when the ink cartridges are replaced. If the power is on, the cartridges automatically move over to the left where they are accessible and easily replaced.
Posted on Nov 04, 2007
  • 13 Answers
SOURCE: Error E 5 on the Canon MP160
Try this website:
http://www.techsupportforum.com/hardware-support/printer-support/174311-solved-error-cannon-mp160-after-refilling-ink-tank.html
Posted on Dec 23, 2007
clusterfx
  • 67 Answers
SOURCE: canon mp160 printer E5 flashing error?
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button 4 times.
The above will get you to Service Mode (and clear the Waste Ink Counter if you wish) and is supposed to work for MP160 also.
Caution if your waste ink pad is full you could overflow if ignored.
Some of the new carts reportedly have fuses which blow if the ink gets too low, denying any further refilling.
To use refills, you will probably have to turn off your Status Monitor.
Go to your printer's Maintenance section.
Posted on Feb 23, 2008
SOURCE: Canon MP160 Errors 1 5
I think you will find that it is the ALARM light that is flashing, is that correct?
If it is just push the O.K. button to except that the cartridge is not the original or has been filled after you got the meassage that the cartridge was empty.
Also it will show that the ink levels are unknown in both cartridges but thats O.K. it will print fine.
Posted on Mar 14, 2008
SASSYBEAR
  • 148 Answers
SOURCE: Ink Cartridge Refill Error E5
press and hold (stop/reset) for at least 5 seconds, then release it. It will tell the printer that refilled ink tanks are installed. Therefore, allowing printing to continue.
Posted on Mar 15, 2008
I do not know where & how to insert the ink cartridge. Pl inform
Hi paragpande,
Canon PIXMA MP160 All-In-One InkJet Printer has sensitive cartridge.
Follow the instruction first:
On top of the printer pick up the cover up, then the printer cartridge is on the side just slide it over to the middle by hand and then remove and install there will be a label for every color where it goes then, sometime theres a lock on it on a side just pull it, then put the printer on and its ready to go.
Note: Be carefull to put an cartridge on printer to avoid problem.
Hope it helps.
Thank You for using Fixya.
Sep 07, 2011 | Canon PIXMA MP160 All-In-One InkJet...
I have just collected a second hand HP 1600 printer and there is a 2cm green vertical line down the left side of the page and a 3mm line down the centre and 2 thin lines down the right side, help!
Dots, Lines and smudges on the printouts are due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines. (corresponding to the location where you are having a green line on the paper)
Also, make sure that the visible inside of the printer and the Black belt are clean and there is no spilled toner inside, which sometimes results in dots.
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Replace the Cartridge or get the PCR Roller changed by a professional.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 16, 2011 | HP LaserJet 1600 Printer
Canon Pixma mp160 cartridge slams to right side e5 error
you need to replace the cartridge,with a new one original canon,not refill
Mar 03, 2011 | Canon PIXMA MP160 All-In-One InkJet...
My roller dont take in the paper
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error. The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix. When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Jun 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error E3 when no paper jam
Canon MP530 print head malfunction
I had the same problem with my printer. There is a switch that tells the printer that the cover is open or closed. Unplug the printer. Open up the printer cover and look on the inside right side edge. About half way back, you'll see a 3/4 inch by 1/2 inch hole where this switch resides. If you put your finger into it, you may be able to push on a lever and it will go down. It should spring back up when you pull your finger out. If you can feel the lever but it just sits at the bottom then there either this lever is broken or the spring fell off.
The problem with my printer was the spring had popped out. To access the switch, you'll need to remove the right side cover. Do this by removing the two screws in the back on the right side. Open the printer cover and find the third screw. It is located on the right hand side, near the front of the printer, on the top. Remove this screw and pop out the cover and see if you can find the spring that is attached to the lever. Make sure you do this in an area that if a small piece fell out you could find it.
Look at the switch and lever. If there is no spring attached to the lever then it is most likely the problem, otherwise the switch may be bad or the electronics inside the printer. There is a hook on the lever and one on the printer. Reconnect the spring and it should fix the problem. I found my spring had completely fallen out and fell on the floor when the cover was opened. It is possible that this spring if fallen out can fall back inside the printer so you may have to shake the printer to find this little spring. It is about 1/2 inch long. Hope this helps.
Dec 20, 2008 | Canon PIXMA MP530 All-In-One InkJet...
E3 Error
Aug 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Hello I have a canon lbp2900 which has been functioning well. When I try to print i get a message asking me to insert a toner cartridge, however there is a toner cartridge in the machine and I am sure that...
I just posted the similar problem recently. After talking to canon printer service tech, this is what solved my problem:
1. open the top cover and remove the cartridge
2. Inside the printer, these is black roller (with sponge&soft material). Press this gently couple of times
3. below this roller, there is a gray roller. press this roller upward couple to times gently
4. insert the cartridge and try to get print out
hope that helps.
May 12, 2008 | Canon Office Equipment & Supplies
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
532
Oct 21, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
56 people viewed this question
old marine
old marine
