Question about iSonic DV565 Digital Camera
Having problems getting it connected to computer to copy card onto Dvd
Jazz dv 140
Actually, if you record onto a memory card then you don't need any special software.
The best way to download videos and pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy videos and pictures from the card to the computer's hard drive, the same way you copy any other files.
May 18, 2013 | Cameras
I am unable to dowload onto PC from USB using a Coolpix S2550. This problem has just started after having no previous user usues.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Apr 11, 2013 | Nikon COOLPIX Cameras
Help! How do I get the pictures from my Canon Rebel T3 onto my macbook air?
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Aug 19, 2012 | Canon EOS 1100D / Rebel T3 Digital Camera
Pentax E85 PC connection fail
Put the card into the camera, use the "Copy" command in the Edit menu to copy the two photos onto the memory card, and then transfer the photos to your computer as you usually do from the memory card.
Apr 01, 2012 | Cameras
Having problems downloading pictures from camera onto the pogo we cant seem to find the pic bridge thanks
The best way, removing the memory card from thecamera and plugging it into a card reader. (Either you connected via USB orFireWire and won't run down your camera's batteries.)It will be faster than connecting the camera to the computer. Once the cardis plugged in, it will appear to your computer as a removable drive. Now youcan get copy paste facility. You can easily copy pictures from the card to thecomputer's hard drive.
Hope this helps .
Feb 17, 2011 | Vivitar 7024 Digital Camera
Im trying to review pics copied onto a dvd-r disc and i can't review them
Are you able to see the files on the DVD? Try copying the files onto your computer first before viewing them.If the problem continues, try to use a different computer because your DVD/CD drive might be having trouble viewing burned DVD/CD(s).
Feb 11, 2010 | HP Pavilion dv9000z Notebook
Copy onto PC
You would need a Video capture card to do this you can capture it raw then convert it into DVD format. You can get a capture card from any computer store like frys.com,bestbuy.com or tigerdirect.com hope this helps
May 22, 2009 | Sony CCD-TRV238E Camcorder
TRANSFERRING VIDEO FOOTAGE TO COMPUTER
you can access via USB only SD card on your camcoder.
The only way to transfer from the tape is via Firewire (IEE 1394) . You should have this port on your PC or laptop, if not you can buy external firewire card .
regards,
Konstantin
Aug 06, 2008 | Canon MV530i Mini DV Digital Camcorder
Trouble saving data on a dvd from my computer..
you need Winavi to convert to a DVD format
Nov 02, 2007 | Mitsuba mv300 Camcorder
iSonic DV565 Digital Camera Logo
12 people viewed this question
Top iSonic Cameras Experts
Jay Plesset
BJ Russell
Are you an iSonic Camera Expert? Answer questions, earn points and help others
