Question about Ricoh Aficio GX3050N All-In-One Printer
I cannot find the User guide for my ricoh GX3050N. I still have ink cartridges that have ink. However, the screen is telling me that the ink collector unit is full and needs to be replaced. Where is this unit located?
After printer said ink cartridge was empty I removed it & found it was not-I put it back in printer & now getting error message that the cartridge is used & needs to be replaced. How can I
your only option it to replace it with a new one . printer mfg's have chipped the cartridges and they can not be reused.unless the chip is recoded as new .
Aug 16, 2017 | Ricoh Aficio GX3050N Printer
Changed black cartridge now getting a 990 error
  • Remove options and try again (NOTE: when removing the Postscript board, you must replace the 2 IBM ROMs)
  • If the printer now works, replace options one at a time to test them
  • Replace system board
  • Defective system board
  • Mar 24, 2010 | Ricoh Aficio GX3050N Printer
    Ricoh Aficio GX3050 Gel sprinter - error999
    BULLETIN NUMBER: J001/J003/J006/J007/J010/J011 – 021 07/02/2008
    APPLICABLE MODEL:
    GESTETNER – GX3000/GX3050n/GX5050n
    LANIER – GX3000/GX3050n/GX5050n
    RICOH – GX3000/GX3050n/GX5050n
    SAVIN – GX3000/GX3050n/GX5050n
    SUBJECT: SC999 OCCURS
    SYMPTOM:
    An SC999 (Maintenance Stepper Motor Home Position Error) occurs.
    CAUSE:
    Some of the ink in the machine has dried, and as a result the maintenance stopper motor cannot rotate or
    the levers come loose.
    NOTE: The following conditions make it easy for the ink to dry up (See Appendix 3 for more details):
    - Low humidity
    - Long intervals between machine usage
    - Total period of usage is long
    - Low Print Volume
     COPY QUALITY
    Fixed ink Stepper Motor
    Right Flushing Gate
    Levers
    Tech Service Bulletin No. J001/J003/J006/J007/J010/J011 – 021
    Page 2 of 5
    SOLUTION:
    Production Countermeasure:
    The shapes of some parts in the Maintenance Unit have been changed in two steps ("Step 1" and "Step 2"
    below).
    NOTE:
    See Appendix 1 for the details of the Step 1 and Step 2 modifications.
    See Appendix 2 for the visual differences among the unmodified unit, the Step 1-modified unit, and
    Step 2-modified unit.
    See UNITS AFFECTED for the Serial Number cut-in of Steps 1 and 2.
    Field Countermeasure:
    1. Cycle power OFF/ON.
    2. Install one of the modified Maintenance Units ("Step 1" or "Step 2").
    NOTE: For customers experiencing a SC999, have them contact 1-800 Ricoh38 for replacement.
    Feb 02, 2010 | Ricoh Aficio GX3050 GelSprinter
    RICOH GX3050N and Windows Vista
    You can find the driver on the Ricoh site. here is the link:
    http://www.ricoh.com.sg/downloads/drivers1.aspx?path=http://support.ricoh.com/bb/html/dr_ut_e/ra/model/gx305/gx305en.htm
    Mar 14, 2009 | Ricoh Aficio GX3050 GelSprinter
    Changing ink cartridges
    Make sure the printer is ON.
    Open the top of the printer.
    The cartridges are inside the cartridge carrier. You need to squeeze the tabs on the carrier which will flip up the lids to reveal the ink cartridges.
    For reference, here are links to the setup sheet and the user guide. The setup sheet has pictures that should help.
    X1150 Setup Guide
    X1150 User Guide
    Nov 17, 2008 | Lexmark X1150 All-In-One InkJet Printer
    Ricoh Aficio  GX3050N All-In-One Printer Logo
    168 people viewed this question
    Top Ricoh Office Equipment & Supplies Experts
    OfficeServiceAjnc
    OfficeServiceAjnc
    fares
    Level 1 Expert
    SOURAV KAPOOR
    Level 1 Expert
    Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
