Question about Remington Electric Pole Saw
I need an oil cap for my pole saw 108526-01 - Remington Electric Pole Saw
    President:
  • 2,220 Answers
An IPL (exploded parts list) for your pole saw can be found here: (I recommend you save a copy)
http://shoppingcart.msservicecompany.com/msservice_net/product_files/RPS96/RPS96_BD.pdf
Page 2 Item 8 pn 107512-01 $3.98
Can be ordered here:
http://www.desaparts.com/index.htm
The model you provided enabled me to fully answer your question. Atta boy/girl. Thanks
Lou
Posted on Sep 29, 2009
  • 193 Answers
You can call 1-800-654-8534
Oil is out on the remington pole saw- what brand do I need?
unless the warning tag on the saw says otherwise, use standard bar/chain lube oil which is used on any chainsaw.
Aug 28, 2012 | Remington Electric Pole Saw
What kind of oil or lubricant is required on a Remington Pole Saw, model # 108526-01?
Hi. Use any brand name bar and chain oil for your pole saw. Usually this oil is only sold by the gallon....so you may have quite a supply on hand. J.
Aug 01, 2010 | Remington Electric Pole Saw
Remington electric Pole Chain saw - what type of oil do I use?
SAE 30 motor oil if the temperature is between 30 & 75°F.
-Colder use SAE 10 oil.
-Warmer use SAE 40 oil.
take a look on amazon: Amazon com SAE 30 motor oil
Apr 24, 2010 | Remington Electric Pole Saw
What kind of oil solution do I use in my remington chain pole saw
I recommend bar and chain oil (SAE 30 with additives to make it adhere) available at hardware stores and home centers.
From a Remington OM, page 9 (edited).
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE 30 motor oil if the temperature is between 30 & 75°F
  • Colder use SAE 10 oil.
  • Warmer use SAE 40 oil.
3. Replace oil cap at once. Tighten oil cap firmly for a good seal. This will avoid oil seepage from tank.
4. Wipe off excess oil.
  • It is normal for oil to seep when saw is not in use.
  • Empty oil tank after each use to prevent seepage.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 30, 2010 | Remington Polesaw Wizard
What type of oil do I use for pole saw?
Use bar and chain oil (bar oil is SAE 30 with an addative to make stick to the bar and chain) available at home centers and hardwares. Excerpt from a Remington OM follows:
“FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE #30 motor oil.
Note: For temperatures below 30°F, use SAE #10 oil.
For temperatures above 75°F, use SAE #40 oil.
3. Replace oil cap at once. Tighten oil cap firmly for good seal. This will avoid oil seepage from tank.
Note: It is normal for oil to seep when saw is not in use. Empty oil tank after each use to prevent seepage.”
Lou
Mar 09, 2010 | Remington Polesaw Wizard
Lost oil cap and bulb
Remmington's parts department.
Sep 14, 2009 | Remington Electric Pole Saw
Where can I find a chain oil cap for a Remington Pole saw,Model 108526 - 01
call Tim independent cycle 660-826-0149 he will have part or will find one
Aug 05, 2009 | Remington Electric Pole Saw
I need a new oil resevior cap for my Remington pole saw model #108526-01 and I do not know the part number.
According to your owner's manual... http://12.153.20.74/manuals/108539-01L.PDF. You will need part # 107512-01. You can contact Master Parts at 800-466-1446 or you also can find them online at www.masterparts.net. I hop this helps you!
Jun 23, 2009 | Remington Electric Pole Saw
Remington Pole Saw Model # 106890-020 - Chain Oil Cap broke
Call Master Parts at 1-800-446-1446, or go online at www.masterparts.net. They have the part (107512-01) you need. I hope this helps...
Apr 26, 2009 | Remington Electric Pole Saw
I have the model 108526-01 Remington pole saw which has the round pole with a plastic compression nut (which recently broke). Can I buy the newer octagonal pole and if so, does it use the same saw mounting...
I have the sollution, had the same problem with the broken compression nut. Just use two hose clamps, one to hold the pole extended and the other clamps around compression base. Its a cheap easy fix and it work great fo me. The Real Mr.Fixit
Apr 03, 2009 | Remington Electric Pole Saw
Remington Electric Pole Saw Logo
359 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
