Question about Acer Aspire One Netbook 8.9" Notebook
UNMOUNTABLE DISK VOLUME Message on ACER Aspire One.
I am able to get as far as the blue screen that states UNMOUNTABLE DISK VOLUME then it reboots again and again and again.
  • 3,940 Answers
Unmountable boot volume is most likely an indication of a failing hard drive. Boot to your Windows CD and run CHKDSK /R and see if issue resolves. If it doesn't then you are probably replacing the hard drive.
Posted on Sep 29, 2009
My laptop was infected with spyware and after several reboots it crashed with error message Unmountable boot volume, is it due to spyware or hard drive failure. Can it be fixed.
yes it can be fixed usually this is done by reformatting that means you need the original disks that were used in your PC . but there are other ways to correct this problem which often called ( the blue screen of death)if you had important documentation that you need to retrieve or dont have original disks take it to your local PC repair shop they will save you info and reformat your PC in Australia this cost around $80.00 and took a few days
Jun 23, 2012 | Acer Aspire One Netbook 8.9" Notebook
Hello, I own an acer aspire one ZG5 netbook, and today I got an error while trying to start it, the blue screen to be exact. Here's the error: A problem has been detected and windows has shut down to...
Hi Stefi,
An unmountable boot volume error means that the operating system cannot boot from the hard drive either because the boot files are corrupted, the hard drive is faulty or there is a problem with the cable connecting the hard drive to the computer. If you are booting your PC and come across a Blue Screen of Death stating UNMOUNTABLE_BOOT_VOLUME, don't despair.
You would need to repair the volume inorder to fix this issues.
To repair the volume, follow these steps:
  1. Start your computer by inserting the Windows startup disks or the Windows installation disk if your computer can start from the CD drive.
  2. When the Welcome to Setup screen appears, press R to select the repair option.
  3. If you have a dual-boot or multiple-boot computer, select the Windows installation that you want to access from the Recovery Console.
  4. Type the administrator password when you are prompted to do this.
    Note If no administrator password exists, press ENTER.
  5. At the command prompt, on the drive where Windows is installed, type chkdsk /r, and then press ENTER.
  6. At the command prompt, type exit, and then press ENTER to restart your computer.
  7. After you repair the volume, check your hardware to isolate the cause of the file system damage.
If this procedure does not work, repeat it, but type fixboot instead of chkdsk /r in step 5.
Hope this helps .
Please let me know if you need further help
Apr 12, 2012 | Acer Computers & Internet
I have an Aspire 5520 it all starts fine but after a few mins it flicks over to a blue screen and then reboots but is unable to find any thing apart from the GFX card and just keeps trying to boot from GFX...
Hi, Thank you so much for giving so much information... But can you please tel me the operating system that you are using. and also the exact blue screen code it will be something like 0X00000000ED (unmountable boot volume)
Please get back to me once you see this message :)
Nov 06, 2010 | Acer Aspire 5520-5908 Notebook
Hi i have an acer aspire 3690 and cannot boot the pc as it says unmountable boot volume. i dont have the recovery cd or bios password as bought from someone i used to know in the uk and im no longer living...
Hello
Thank you for using
FixYa for your problem
If you receive the “unmountable boot volume” error and have an installation disk, you still have a chance to save your system.
1. Insert your XP installation disk into an optical drive and boot up your computer.
2. When you see a welcome screen, hit the R key on your keyboard. This will enter you into recovery mode with a DOS prompt.
3. Now type chkdsk /p and hit Enter. This will launch a utility which will check for errors on your hard drive.
4. After the process is done, type fixboot and hit Enter to repair any damaged boot files which may have become corrupted. When asked to say yes or no, type the Y key on your keyboard.
5. Type exit and press the Enter key to reboot your computer.
If all went well, you should now be able to boot back into Windows without a problem!
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 19, 2009 | Acer Aspire 3690-2196 Notebook
Startup repair won't run
"Unmountable boot volume" this problem is your hard disk partition which is failure to recognize & identify the operating system running on the hard disk. Reformat your hard disk and put another operating system to run again your computer.
Jul 27, 2009 | Computers & Internet
Will not load windows I get an error message stating unmountable boot volume
i) i think you hard disk or hard drive(of your laptop or desktop) is malfunction or not working properly.....
   or it has gone bad, i think you have to send it for repair or replacement;
   error messge: unmountable boot volume is specifically for harddisk malfunction and requires repairing or replacement(strictly)
Thanking you
M. Sridhar
Dec 29, 2008 | IBM ThinkPad 600E 2645 Notebook
Unmountable disk volume
I do not think that you need a "driver"
I would like you to click here for more info on your problem
Oct 22, 2007 | Computers & Internet
Acer Aspire 1403LC (app 6 years old) Screen resolution problem
You may have a corrupt driver, go to this site and down load vga driver, as i cannot see a grphics driver for your system http://support.acer-euro.com/drivers/notebook/as_1400.html
Mar 08, 2007 | Acer Aspire 1403LC Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
1,610 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
