Question about Kodak EasyShare M1033 Digital Camera
Lens will not stay open - Kodak EasyShare M1033 Digital Camera
  • shevette norwood Sep 29, 2009
    my lens wll not stay open
The lens does not stay open long enough to pose picture. It closes.
These camera's will do that when the battery is very low sometimes.
I'm not sure that is your problem due to lack of more details, but it is a possibility.
Mar 08, 2015 | Nikon Coolpix S3300
Why won't my camera lense stay open
Its the power saving feature that retracts lens if camera not used for a set length of time.
If you want camera lens to stay open longer, change the settings by assigning a longer period of time.
Aug 17, 2014 | Cameras
HELP APERTURE PROBLEM! When I attach any lens to the Nikon FM10
This is normal. the lens stay at the largest opening so you can see to focus, then the mechanics will close to the setting when the exposure is made. This is part of the reflex in single lens reflex (SLR). This part staying open when you focus keeps lyou from having to open the aperture to focus and then close it to the correct setting to shoot the picture.
Jan 29, 2010 | Nikon FM10 35mm SLR Camera
Shutter stays open
Lens is jammed , needs to stripped and reset.
Apr 21, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Lens cap will not stay open
try opening your camera in front unscrew the bolts and pull the front cover.you will see a metal cover not properly align.
Apr 06, 2009 | Kodak EasyShare V570 Digital Camera
Lens cover stays open
hello lmsmith, the reason the lens protection shutter does not close, is that it is either jammed by sand, dirt or sticky substance. it is going to need cleaning by a qualified technician.
Jun 04, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
My canon A520 lens cover don't open
lens opens about 25% . Will not close back.
Mar 15, 2008 | Canon PowerShot A520 Digital Camera
Dropped camera-lens stays open
The only way to fix a lens error is to send into casio and have it fixed. Call them at 800-706-2534 option 2 and tell them you have a lens error. They will tell u how to go about sending it in for repair.
Nov 25, 2007 | Casio Exilim EX-S600 Digital Camera
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Oct 30, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Kodak EasyShare M1033 Digital Camera Logo
41 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
