Question about Whirlpool LER4634J Electric Dryer
I have a whirlpool dryer that made a popping sound and now it wont run it only makes a buzzing sound
  • 27 Answers
The motor sounds like brushs have gone some can b replacd fairly cheap
Posted on Sep 30, 2009
Whirlpool dryer makes a buzzing sound whey start button is pushed. sometimes it will turn on for a few seconds but most of the time it just buzzes.
The buzzing is probably the relay trying to start the motor. See if the motor has a capacitor, have it checked. If the motor is all clogged with lint, the start/run switch can get blocked. Clean out all that lint with a vacuum cleaner.
Check the tub bearing, and make sure the drum spins freely.
Nov 29, 2013 | Whirlpool LER4634J Electric Dryer
Whirlpool Carbrio dryer buzzing noise while running. Works OK just keeps buzzing off and on while drying. Not a grinding sound.
OK, remove the 2 screws on the front lower kick plate. Run the dryer to see if the buzzing is coming from the motor or from the burner area. Post back your results.
Nov 09, 2012 | Whirlpool WGD5600XW Cabrio 27" Front-Load...
Buzzing noise from dryer and wont start
It sounds like your motor has gone bad....it will buzz really bad when it is trying to start and cannot...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Asker's Testimonial " Thanks so much for your help. Now that you'v mentioned it, the buzzing does sound like it's coming from the motor. I'm,now, more comfortable in call " -
Apr 12, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Dryer has started to make a loud sqealing when it starts and gets up to speed, the kind of sound a loose fan belt makes on a car, and now just makes a buzzing sound when the button is pushed but dosen't...
If you push the start button and you here a buzzing sound, This sounds like the motor is bad.
Somthing you can try and this might not work. but open the dryer door and turn the drum a littel bit then close the door and try to start it. If it starts running again then you have hit a bad spot on the motor.
If it just still just makes the buzzing noise then the motor is most likley bad.
Jan 15, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool dryer makes buzzing sound when flame should start.
Sounds like the valve is trying to open and the buzzing is the restriction of it opening. Coil is obviously correct, but actual solonoid is sticking. Replace it and see. If flame isnt detected, it will stop.
Sep 21, 2009 | Dryers
Dryer will not work. Makes buzzing sound when
locked up dryer motor,replace-mike
Jul 17, 2009 | Dryers
Whirlpool gas dryer makes buzzing sound when started, stops mid-c
Maybe something fell down into the filter housing. Get the back off and inspect it with the power disconnected.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 17, 2009 | Kenmore 62602 Electric Dryer
Whirlpool LEQ9858PW0 Buzzes But Won't Start.
sounds as if wither you have a bad motor assy, or something haas fallen down into the "blower assy" preventing the motor form spinning.. in the back wher eyou tested your fuse, just to the left of that you see a large tubular housing (rounded on bottom", thats the cover for the blower , i believe its 3-4 screw holding it on, nad also the 2 screws visable when you remove the filter assy, the housing will pull off( you may need to wiggle it abit) and hopefully youll find a sock or something jammed in the blower assy
Jan 16, 2009 | Whirlpool LEQ9858P Electric Dryer
Whirlpool Dryer (LER7646E) not working
check your power cord and the receptcal if you see any discloring on pronges of your power cord you'll need to replace cord and the receptical it could be shorting out
Dec 13, 2008 | Whirlpool LER7646E Dryer
Whirlpool LER4634J Electric Dryer Logo
98 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
