Question about Kodak ESP 5 Printer
I just installed new ink cartridges and when I try to print the printer says out of ink. I did the maintenance and still the same thing. Can someone help?
  • 89 Answers
  1. Have you lifted the protective foil off the contacts? If you have, then you'll just clean the contact with a Q-Tip swab.
  2. Do not put any type of cleaner on the swab it must be done with a dry swab.
  3. Return ink cartridge firmly in place.
Posted on Oct 06, 2009
The printer's black ink cartridge won't print without the Tri-color print cartridge
Most of the HP printers are designed to allow printing onlywhen all cartridges are installed and
have ink.
Install a new tri-color ink cartridge and printing will continue as usual.
My printer, which is HP, does the same thing as yours, until I replace the empty cartridge,
printing stops.
Feb 22, 2011 | HP DeskJet 3745 Printer
Black ink not printing even tho a new black ink cartridge was installed recently and working properly until I opened the unit to install a new color cartridge and now the black ink is not printing and the...
Try to reseat your cartridges. Unplug and replug your printer into the power source to reset itself. If that doesn't help, try to clean your cartridges and check if print quality improves. If you're using Windows, go to Start -> Programs -> Lexmark X74-X75 -> Lexmark X74-X75 Solution Center -> Maintenance -> Clean print nozzles to fix horizontal streaks.
Feb 17, 2011 | Lexmark X75 All-In-One InkJet Printer
Black not printing
Canon Bubble Jet i560 Ink Jet Printer not printing black
Aug 01, 2010 | Canon BubbleJet i560 InkJet Printer
THE INSTALL COLOR INK NOTICE KEEPS STAYING ON. EVEN AFTER I KEEP INSTALLING DIFFERENT CARTRIDGES
Go into printer maintenance and chose the Canon printer (assuming you have multiple printers). Once you chose the printer you can then perform maintenance and do cleaning and priming. Essentially when you click install new cartridge the system will essentially prime the printer so that when you print a document it will not have to prime itself. It should prime automatically once you close the lid and install the new cartridge.
Feb 08, 2010 | Canon PIXMA iP90 Mobile Printer
Black ink not printing or very light or split. Have installed new ink cartridges. Getting some color and headings or seals. But mostly Blank!
HI
Usually when you install new cartridges,the printer print an alignment sheet.
in case if the printer isn't printing the colors okay,
you can try cleaning the cartridges by going to the printer drivers,
goto the control panel--->printers and faxes--->rt click the printer icon and goto properties,under properties there should be an option for either maintenance or service this device button,when you click it ,it gives an option for aligning the cartridges,
you can also goto the printing preferences and it allows you to adjust the color
there is an option to clean ink cartridges
Jul 14, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Blank ink not printing
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please try to print the self test page.
A technique to improve print quality is to try and clean the cartridge nozzles. You can clean the cartridge using the following steps given below:
Click on "Start," go to "All Programs," and down to the Lexmark. Click on the "Solution Center." Next, click on the "Maintenance" tab. Select "Clean to fix horizontal strips." This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean to fix horizontal strips" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution Center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge (or cartridges) from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean to fix horizontal strips" one more time. If this fails to address the problem, the entire procedure may need repeating.
If you have replaced your ink cartridge with a new one and are continuing to experience difficulties with print quality, please try cleaning and wicking the ink cartridge. If this fails to resolve the issue, the maintenance station may have an excess build-up of ink.
The maintenance station is located inside the printer on the right hand side. This is the same area where the cartridges sit when in the "idle" position. To access the maintenance station: Unplug everything from the back of your printer, open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fanbelt. On some models, the cartridge access will be very small, but the belt should still be visible. Take the top part of the belt and move it gently to the right.
***Note*** please do not pull outwards on the belt. The cartridges should come over towards the left side of the printer. The maintenance station will be on the right side on the bottom of the printer behind the fixed cover. Clean the area with several damp cotton swabs or damp papertowels until the build up of ink is removed.
Once the maintenance station has been cleaned you should "wick" the cartridges. Remove the cartridge from the printer. Get a clean damp paper towel and lay it on a flat surface. Set the ink cartridge right side up, with the ink nozzles touching the towel and hold in this position for about 15 seconds. Then wipe the nozzles across in one direction only (left to right). Repeat this process, each time using a clean spot on the paper towel, until it looks clean. Dab the cartridge on a dry towel to make sure that the ink is flowing.
After you have wicked the cartridges place them back into the printer, securing them into place. Plug the power back into the printer. Close the cover and click on "Old Cartridge Installed" on the "Control Program" screen. Once the printer has reset, run the "Clean Print Nozzles" page twice. This should resolve the issue.
your's tech expert
Jeeth
Mar 19, 2009 | Lexmark X1270 All-In-One InkJet Printer
Dx4450.New ink put in but won't print
Hi Mel
unplug the printer--> remove all the cartridges from the printer--> wait few minutes--> plug the printer--> install the cartridges
I hope this helps. If so, please take a moment to accept and rate my solution accordingly
Nov 15, 2008 | Computers & Internet
Lexmark x3430 low ink warning
when you installed the new ink cartridge did you go into your program menu and find the lexmark solution center? If not, you have to go to the solution center, choose the maintenance menu and tell it you have installed the new ink cartridge. If you don't it will not recognize the new one.
Jun 23, 2008 | Lexmark X3470 All-In-One InkJet Printer
Colour Ink
1. On your PC, go to Start, Programs (Windows XP: All Programs), Lexmark series.
2. Select the Solution Center.
3. When the Solution Center appears, click on the Maintenance button.
4. Select the option to Install a new print cartridge. The carrier should slide over at this point and allow you to insert and/or remove cartridges.
5. Make sure the correct cartridges are installed inside the printer first, then inform the software which cartridges have been installed. Note: This applies also to installation of a single cartridge.
6. Print the Print Alignment page to ensure the print quality is satisfactory.
7. Close the Solution Center.
Mar 23, 2008 | Lexmark X1150 All-In-One InkJet Printer
Kodak ESP 5 Printer Logo
56 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
