Question about Poulan Garden
The pto will not come on. - Poulan Garden
  • 472 Answers
SOUND LIKE YOU HAVE A BAD SWICTH CK TO SEE IF YOUR GETING POWER TO THE CLUCH IF NOT YOU SWICH IS BAD
Posted on Sep 30, 2009
PTO turns with mwoer shaft disengaged, blades turn when shaft is rotated by hand. Put shaft into PTO housing and the mower wont turn.
bad pto, 400 dollar to fix but a cheap option is to replace the pto switch in the dash first, is the pto switch clicking with the key in the ON position? if it is then it is the pto clutch bad
Jul 29, 2015 | Garden
Pto does not disenguage when I push clutch pedal in
Normally the Clutch/Brake pedal doesn't turn off the PTO.
If the PTO is running, and you do not lock the clutch/brake in the full down position, when you get up from the seat the system will kill the engine. However, the PTO system is still active.
Thus, if you sit back down and try to crank the engine, it won't crank. You must first turn off the PTO switch.
Based on your comment, you are right, the Clutch/Brake will not turn off the PTO as long as you remain in place (and don't try backing up). If you want the PTO to disengage you must turn off the PTO switch.
Mar 21, 2015 | Garden
Why doesn't my Toro z master PTO not engage
check to see if pto will engage if not check voltage at pto if non blown fuse if fuse not blown and power to pto bad pto jump the pto at pto with battery in mower does it start pto if does good pto have to check volts at switch check there start with that let me no what happened
Sep 04, 2014 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
Pto switch will not work...it was replaced tnd it still will not work
check for voltage at pto if voltage there jump pto at the wire hub on pto if still pto dosnt come on bad new pto return it for new one and they get bad one it is a problem if good pto check voltage at pto should be 12.5 at least if not you got a bad stater 200.00 for it then install another 100.00
Aug 29, 2014 | Garden
John Deere 265 replaced pto switch on dash pto drive belt and mower deck belt still pto does not engage...also randomly blows 20 amp fuse from time to time when pto would engage previously...checked...
The electrical is part of the PTO clutch assembly. It should only draw 5-7 amps. Ohm reading is somewhere between 1.7 to 2.5 ohms.
These coils do short from anywhere from a partial short to completely.
Jul 26, 2014 | Garden
Why does my John Deere 5425, Pto keeps shutting off?
Check all connectors going from switch to PTO engagement clutch. Check ground wire from PTO. This problem is either a bad connection or a faulty electromagnetic PTO.
May 12, 2014 | Garden
PTO stay engaged on allison transmission md3060/ PTO chelsea 277
wires to the pto solenoid incorrect and not wired properly through the switch
did you put the correct shims under the flange of the pto mount as it it is incorrect distance , the pto teeth will say jammed in the transmission gear teeth
suggest that you take it to a shop that fits pto and have the installation checked before you damage the transmission
Mar 12, 2013 | Garden
X595 john deere pto wont kick in
These John Deere Garden Tractors have a RIO (Reverse Implement Option) on the PTO. If your PTO is engaged and you back up, the PTO will automatically stop. To reset it, depress your PTO engagement switch to the OFF position. Take your foot off the reverse pedal. Pull up on the PTO engagement switch. The PTO should restart. To use the RIO feature, pull up on the PTO switch for a second or two just before you step on the reverse hydrostatic pedal. The yellow RIO indicator light should come on your dashboard and you can now back up with the PTO still running. Works great for snow blowing when I don't want to keep resetting my electric PTO clutch to keep restarting my snow blower.
If your PTO will not restart, you may have a PTO switch starting to fail, or a likely logic problem in your electric PTO control module, or one of your forward/reverse indicator switches, which is linked to your PTO control module along with the overtemp circuit, is stuck/faulty.
Feb 20, 2013 | John Deere 26HP Hydrostatic 54" Riding...
Cub Cadet 1861 amp light comes on when the PTO is engaged and after mowing for a short time the PTO disengages and now the 30 amp fuse blows and stops the engine
Sounds like you have a short circuit, either in the PTO clutch, or in the wiring that goes to it. Inspect the wiring for any obvious spots where insulation has rubbed off or burned. Also look at the wiring at the back of the PTO engagement switch for these signs. Before buying an expensive PTO clutch, unplug its connector. Drive around with the PTO switch on (even though the PTO won't activate and the blades won't be engaged). If the fuse doesn't blow, the problem must be within the PTO clutch. If the fuse still blows, it must be in the PTO switch or the wiring from there to the clutch. Use an ohmmeter to trace and find the short. Good luck!
Jul 09, 2010 | Oregon Scientific Electric PTO Clutch for...
Mower pto engages when initially started but after
the coil in the electric PTO shorts out when it expands by heat causing it to lose it's magnetic pull and disengages- I hate to say it,but you need a new PTO clutch.
May 07, 2009 | Garden
Garden Logo
27 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
