I am connecting a second monitor directly to my sceptre x9g monitor. I have changed the settings to reflect second monitor. The second monitor is displayed in device manager. Still am not getting anything except "check signal cable" displayed on second monitor. I do not know how to change monitor port if that is required. Help!
Not sure If I am understanding this correctly, you are trying to connect a monitor to a monitor? I have never heard of that before. As far as I know you need a video card that has dual output to use dual monitors. I am not saying you can't do what I think you are saying but I never heard of that before. Also on a side note depending on the resolution and amount of colors your operating system is set on, you need a video card strong enough to drive both monitors.
Was this helpful?
Yes
No
Popular Solutions for Sceptre X9G Komodo IV 19 in.
Monitor has no power (ie. no light). Has integrated pwr/aud/logic/inv board. No visible signs of any...
(More)
Monitor has no power (ie. no light). Has integrated pwr/aud/logic/inv board. No visible signs of any problems. Only have 1.6v at pwr switch, and 5v going to logic side of board. Board is model 490491200100R, can't find any information on this board.
hello. how did you reset the eprom on the lcd monitor? my monitor turns on for 2 seconds then shuts...
(More)
hello. how did you reset the eprom on the lcd monitor? my monitor turns on for 2 seconds then shuts off. i took it apart and when i lift the glass and put i flashlight behind it i can see that the monitor works but the bulbs are not turning on. is there a way to apply separate power to the bulbs?
just like antdotwhat my monitor started doing the same thing as theirs on the same date. I turned...
(More)
just like antdotwhat my monitor started doing the same thing as theirs on the same date. I turned on my computer and the on light flashed on and of constantly this time with a black screen. I turned the computer off and back on and the monitor started working properly. This morning I turned it on and same thing. I tried turning the computer off and this time it would not work. I tried this several times. I think the monitor is no good anymore.
