Question about Kenwood KDC-315S
System resets each time turn of car. how do i fix
System resets each time turn off car. how do i fix this?
    Problem Solver:
  • 10 Answers
In the back of the stereo check to see if the yellow cable is connected properly i had the same problem
Posted on Sep 29, 2009
How do i reset my airbag light in my 04 Chrysler Pacifica
If the fault is rectified then you need to connect a code reader to the obd socket to reset the code!
Aug 05, 2015 | Chrysler Cars & Trucks
How do i fix RCA tablet if frozen and wont turn off
Try a hard reset. On many android based tablets, this is done by pressing the power button and volume up button at the same time (for your particular tablet, check the manual, and look for "hard reset")
Dec 26, 2014 | RCA 7" Dual Tablet Travel Dvd Cd Jpeg...
Engine stalls,engine seems like it isn't getting fuel
This is the passcode security system installed at the factory. check your owners manual to reset it. Better yet reset it 3 times to ensure the reset is done. It will take you 30 minutes because you turn the ignition to on, not start, and let it sit for 10 minutes. Turn it off then back on for another 10 minutes and then repeat once more. That fixed the situation for me for awhile. My best advice is to sell the car. This happens repeatedly and no one seems to have a good fix.
Jul 13, 2014 | 2003 Chevrolet Malibu
Resetting p0302 code
There is no reset per say, you fix the problem and after about 100 miles the system resets itself if the problem was corrected. You can also reset the light with a scan tool or code reader. Once again if you turn off the light the system will turn it back on in a short time if the problem is not corrected.
Sep 17, 2012 | 2002 Nissan Quest
How to reset security system in 2002 vw passat
Unlock the drive's door twice with the key, turning CCW each time. If that does not work, then remove the battery for a half hour and turn the headlights on for 10 seconds or so.
Feb 28, 2012 | 2002 Volkswagen Passat
Need reset code for change oil light
Hello thegoat1969: My name is Roger and I will help you. To reset the oil reminder you will need to perform the following. 1. Turn the key on engine off. 2. Press the accelerator pedal fully tree times within 5 seconds. If the CHANGE OIL SOON light flashes two times,system is resetting. 3. Turn key off,start the vehicle.If CHANGE OIL SOON light comes back on,the system did not reset,repeat the procedure. After the restart wait 10 or 15 seconds to give the lamp time to reset and go off. Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
Feb 16, 2011 | 2000 Chevrolet Impala
We have a 1997 cadillac deville. installed a master window switch and left rear window motor. Technition reached inside vehicle and unlocked rear door lock by hand and set off alarm. we tried several times...
My wife had a car that to reset the problem we had at the time, the owners manual stated that in order to reset we had to turn on the key to the run position(do not start the car just turn key to run) next hit the brake pedal 3 times quickly and hold on the last push off the brake pedal, while holding down the pedal turn off the key. Release the pedal then turn the key back to the run position and this may fix your problem. Check your owners manual. Your car procedure may differ.
Jan 26, 2011 | 1998 Cadillac DeVille
I have a 2000 monte carlo ss 3800 series. Sometimes the security light comes on and car will not start. When security light is not on, car always starts.Any ideas?
The passlock is having issues try this procedure and see if it helps. If it does not the passlock and ignition tumbler may need replaced.
PASSKEY LOCKOUT RESET ALL GM CARS 1999 AND UP
1) Put the key in the ignition and turn to the "ON" position. Leave it that way for 10 minutes. After 10 minutes turn the key and take it out. Repeat this process (2) more times (3 times, 30 minutes total) This should reset the PASSKEY system to recognize your key
Jan 12, 2011 | 2000 Chevrolet Monte Carlo
How do I get my passcode for my 03 chevy Impala, and how do I reset it? I just bought a new battery today because I thought it would fix my security issue I'm dealing with on my car but this seems to not...
This may be a passlock issue.Try this procedure to see if it will reset your passlock.
Sep 03, 2010 | 2003 Chevrolet Impala
MY CTS IGNITION WONT TURN BACK AND IT STATES THAT IS IN LOCKED MODE ON THE DASH. DOES ANYONE HAVE AN IDEA OF WHAT IT COULD BE ?
this is a Pass Key anti theft problem, do the following to reset the system, if this doesn't work u will have to take it to the dealer, they are the only ones with the test gear to find and fix the problem
PASS LOCK RESET GM CARS 1999 UP
1) Put the key in the ignition and turn to the "ON" position. Leave it that way for 10 minutes. After 10 minutes turn the key and take it out. Repeat this process (2) more times (3 times, 30 minutes total) This should reset the passlock system to recognize your key.
Feb 22, 2009 | 2003 Cadillac CTS
Kenwood KDC-315S Logo
43 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
