Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire front load washer automatically goes to "no spin"
I'm trying to do a load of laundry. The frontload washer is automatically resetting to "no spin" and it won't start. I try to reset the start and it reads error.
  • 125 Answers
SOURCE: frigidaire front load washer problems
most likely something is stuck in the pump. it could also be that you are not using high effiency detergent.
Posted on Jan 06, 2008
aborcass
  • 2651 Answers
SOURCE: frigidaire front load washer no spin
sounds as if theres something stuck in your drain pump, youll need to remove the lower acess panel(2 screws across the bottom front of unit) you'll see teh pump in the rigth hand corner. i would remove as much water as possible before trying to remove the hose to the pump or you will get soaking wetaferer removig the hose youll be able tro see what trapped in oyu pump preventing free draining.. VERY common problem.DISCONNECT POWER THE DRAIN PUMP IS ALWAYS LIVE!!!!!!!!
Posted on Oct 19, 2008
  • 196 Answers
SOURCE: Frigidaire front load washer won't drain or spin
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Posted on Nov 12, 2008
  • 378 Answers
SOURCE: Frigidaire front load washer wont high spin
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Apr 03, 2009
SOURCE: Frigidaire Front Load Washer won't Spin
i fixed mine about 5 times and its always some thing diffrent.
try buyng the inexpencive parts first and leave for last the electronic control panel.
it could be that your washing a smaller amount than the recomended.
Take it to a profesional. dont do like me a DIY guy. Some times i need to take pictures when taking the monster appart and then because they are somany screws missing duct tape, rope or hangerwire becomes usefull.
All mechanics are wise guys you and me are thevictims.
Posted on Dec 02, 2009
Hi i have an Frigidaire FAFS4474LW front load washer and it always stuck in the final spin last 6 minutes and it was keep spinning on the last 6 mins and never ended. It takes over 2 hours to finish a...
Thank you for your post, Tom Lau!
I see that you are having a difficult time with your Frigidaire washer, FAFS4474LW, taking long a time to complete a cycle and not rinsing the clothes out enough. This could be a possible problem with your sensor or control panel on your washer. You may want to perform a reset on your washer to help clear out any miscommunication within the washer. In order to perform a reset you would need to flip the household circuit breaker off for roughly ten minutes. If you continue to have issues with your washer after the reset I would recommend seeking assistance from a professional. This will help you to avoid any unnecessary part purchases. Best of luck! -Matt
Feb 17, 2015 | Frigidaire FAFS4474LW Laundry : Front Load...
417.39022890 Frigidaire Gallery Frontloader won't spin
Does it move at all in the spin cycle? If it does, try to open the door during the spin cycle and tell me if the door opens or stays locked.
Nov 20, 2013 | Frigidaire ATF6000ES Front Load Washer
I have a Frigidaire GLTF2070DS Front Load Washer and during the spin cycle, it started making this horrific noise. I started another load of laundry and now it does not spin. What could be the problem?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 07, 2010 | Frigidaire GLTF2070DS Front Load Washer
My washer sounds like it's dying, but the dryer is fine. Can this be unstacked so all I have to do is buy a new washer?
Welcome to FixYa.
To answer your question, as long as it is indeed a frontload washer with the dryer on top, yes they can be replaced individually.
The model number provided is only partial, therefore I can`t verify the unit is frontload or an Kenmore integrated "laundry center" built by frigidaire.
You can reply with a model number, but as I alluded to if it is frontload, no problem.
Good luck going forward. Thank`s for choosing FixYa. Let me know if you require further assistance.
Macmarkus :)
Aug 25, 2010 | Kenmore 43142 Front Load Washer
Hard bang on spin with my frigidaire gallery frontload washer
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 15, 2010 | Frigidaire GLTF1040A Front Load Washer
Washer won't spin in final spin out
Hello harley1964dm
Welcome
You said, you have a Frigidaire front loader and it will not spin out in the final spin would you please help me. thanks
For a Frigidaire usually ,
If the washer won't spin.
Many times it's because the load is too small. Add 1 or 2 similar items to help balance the load.
If it does not remedy the problem try unplugging the machine for 5 minutes which will reset the system!
Let me now how it goes.
Huuum
Please remember to leave a rating
Oct 11, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
Jul 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire GLTF2940ES Front Load Washer Logo
107 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
