Question about Tomtom GO 720 GPS Receiver
Can SD Memory cards be used with my Go 720??
My GO720 has tape over the SD slot and a simulated plastic SD card inserted. The tape says "No SD required" If an SD card is usable what functions, maps, songs, etc can be down loaded that can be usable on the 720
  • 51 Answers
The "no SD required" is just letting you know that all of the important stuff to make the unit run is all on the hard drive of the unit itself. Yes you can use a SD card to hold maps, photos, or music. For instance if you were going to Europe, you will be able to get a European Map and download it onto the SD card. Another instance would be if you wanted to download some mp3 files.
Posted on Sep 29, 2009
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
Micro sd card in sim card slot removal
I just did the same thing. I didn't want to put anything metal in to the slot. After trying with various pieces of hard packaging plastic I put double sided sticky tape on a piece of plastic and slid it down into the slot. The sd card attached itself to the sticky tape and I was able to pull it out. Good luck
Jan 06, 2012 | ViewSonic ViewPad 7 Android Tablet
Can not gt my sd card into the slot do u need a spefic kind
Yes the type of card matters for the slot. If your pc/ laptop is newer and you have never used the slot, then more than likely the dummy plastic piece is still in it. This needs to be removed before you can insert any cards into it. Also, an SD card will only fit an SD slot, there are many other types of cards as well. If your card slot says that it will except SD, XD, miniSD, and so on.....then you can insert the SD card that you have.
Aug 27, 2011 | Computers & Internet
I have 1gb kingston microsd card not opened tell password now.plse tell me master password
I can help. What is not the problem, is the position of the switch entirely. With the SD card Face up and the tiny white plastic switch on the left side, should be slid toward the card edge connector (the shortest side). I know you may have done this and it still doesn't work. Here's why, On the opposite side of the SD card from the switch, there is a tiny "Notch" cut out.
Place a piece of tape, masking, electrical, sometimes transparent will work. Be very precise in placing the tape over the notch, but not over the brass connector on the opposite side. Then place it in your card reader, format it, read and write files to your desire.
This is a little known issue with the design of all SD cards. The notch forces them to work in camera's, MP3 Players, PDA's, etc. that are portable devices, but not in USB card readers or computers with SD reader slots.
The card reader with the SD card has this extra built in feature to protect copyrights (for some reason on blank cards), and makes it useless for custom applications. Once you have "Unprotected" the SD card, installed your files, then remove the tape.
If you get the same error again after applying the tape, add a second layer. Double check that you did not cover the connection edge, and the plastic tab is closet to the side you insert in the device you are using.
Sometimes it takes several tries, but it will work with patience. If you have existing files on the SD card, insert it, right click, select properties. Then remove the "Read Only" check by the box and try to delete or add files then. If it says Disk Write Protected, then check the tape again.
Dec 18, 2010 | Kingston 1GB Secure Digital Memory Card
Sd card not recognizable
I read the following spec for your camera: Recording Media Internal Flash Memory 64MB Video/Image
SD/SDHC Up To 32GB Video/Image
So, I think that an 8 GB SD card should work.
Try another capacity and brand to make it work.
Jul 12, 2010 | Kingston 4GB Secure Digital High Capacity...
My Canon Powershot A560 memory card is locked and it is the camera doing it not the memory stick. When I turn on my camera I get an error message"memory card error" then when i press to view pictures it...
Turn the Canon Powershot A560 over so the bottom is facing up.
Locate the door on the bottom of the camera. The door is labeled "CARD/BATT. OPEN."
Place your thumb on the slider on the door. Push the slider up to unlock the door. Then, slide the door out to open it.
Find the SD card. Inside you will see four batteries and the tip of a small plastic disc. This plastic disc is the SD card.
5
Eject the sd digital memory card. To eject the card, gently push on it and then release the pressure. The SD card will pop out part way. Go ahead and pull out the card.
6
Turn the card so the writing is right-side up. On either the left or right side of the card, you will see a grove with a tiny plastic switch in it. If the switch is at the bottom of the groove, the SD card is locked.
7
Unlock the SD card. Using a fingernail, slide the switch to the top of the groove. The card is now unlocked.
8
Return the SD card to the camera. Place the card in the slot and push down until you hear a click. The card is now successfully reinstalled. Do not worry about inserting the card the wrong way, because it will only fit one way.
Nov 06, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Can i insert this type of memory card into the slot into the computer directly? it says on my laptop that sd, xd and M (symbol for pro duo? )can be inserted. But when i try to insert it, it doesn't appear...
it is advisable to buy a AIO (All in one) card reader, you can use this to many different type of memory card, the built in slot for memory card in your laptop sometimes only suite to a single type or model (ex. SD slot..MMC Slot etc.)
in your case your memory card is not fit to it, don't force it you might damaged your card
Nov 01, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
What does no card mean? Thank you.
"No card" means that either
  1. You have not inserted a memory card
  2. The memory card is not formatted, or
  3. The memory card is damaged and therefore can't be read by the camera.
How to insert the memory card:
  1. Open the camera’s battery door by sliding it downwards.
  2. Insert the SD card into the slot as shown inside the camera’s battery compartment. The SD card can only be inserted one way.
  3. Press the SD card completely into the camera and then close the door. Open the door and press on the memory card if you wish to remove it.
Note: There is only one way to insert the SD memory card into the slot. Do not force the card into the slot. This may damage both the camera and the SD memory card.
Before you can use the card, it has to be formatted:
  1. Insert the memory card into your camera as described above.
  2. Turn the camera on by pressing the power button.
  3. Use the multi-select button to select the "SET" option.
  4. Press the right arrow button to set "System" then press down key to select "Format".
  5. The default option is ‘Format’. Select this option by pressing the OK button.
  6. Select "Yes" to format the card.
If all this does not work it might be that your SD card is damaged. Try to replace it with another one. If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 08, 2009 | VuPoint DC-ST300-VP Digital Camera
My computer does not recognize my SD 2GB SD Flash Card which I insert into my camera and take pictures. I have a slot on my computer for SD cards. Can I just put the card in the slot and access the...
yes you can directly use the SD card slot, make sure you unlock the write protection before inserting it into the slot if you wish to modify or copy the contents from or to the card.
Jun 24, 2009 | SanDisk 2GB microSD Memory Card
Memory expantion
If TT Go720:
- Buy a SD card, the faster the better..
- Choose between a SD or SDHC card.
- Mount in card slot, and your done...
The unit will read from both internal and SD card at the same time.
Example:
- Make a folder on sd card named "mp3"
- Put some mp3 somgs in there, and they will appear in the Music and Media option on the unit...
Any more questions, please don't hesitate.. ;-)
(Please remeber to vote. Thanks.)
Jun 21, 2008 | Tomtom GO 720 GPS Receiver
Tomtom GO 720 GPS Receiver Logo
135 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
