Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
Keeps saying "Coffee Beans Empty" - Saeco Royal Digital Plus
Hello. The digital display on the coffee machine keeps saying Coffee beans empty and wont make a coffee. The griner is trying to grind, but nothing is coming out.
Yesterday, someone was using the preground coffee spout. Could that have anything to do with it?
    President:
  • 1,618 Answers
Either the coffee chute from the grinder is blocked, or the grind is too fine. Remove brew unit and check grinder chute.
Posted on Sep 29, 2009
5 Suggested Answers
  • 1089 Answers
SOURCE: How i can take the griner out to clean. I lost my manual.
Hi
When you use pre-ground coffee make sure that you use just 1 level scoop. Never use a heaping scoop as it will either kick the coffee out and not make anything or will break your brew drive.
Posted on May 28, 2009
EsWorld
  • 1618 Answers
SOURCE: No coffee brewing with beans, but with coffee brewing with ground coffee.
It is possible that the grinds chute is blocked, remove the brew unit and check the chute from the grinder chamber, make sure that it is not blocked with coffee grounds.
Posted on May 31, 2009
SOURCE: I have a Saeco Royal
Hi, well i am sorry to hear you are having problems with your machine, and with a problem such as you describe, it would seem either the grind motor is faulty, or the controller/sensor that starts the motor is? It's just too hard to exactly isolate from a description as you would no doubt understand.
The very best thing you can do to get it repaired at a reasonable cost, is to contact the Agents, or the manufacturer, for & of, the machine, and ask them for a referral to an authorised service center/person.
Now when engaged with the repairer, first only ask for a "Quote" as to the cost and type of repairs required. This way at least, you can then, make an informed decision as to repair or replace.
Posted on Mar 31, 2011
EsWorld
  • 1618 Answers
SOURCE: grinder sounds like it is grinding the coffee
Coffee grind is set too fine.
Posted on Apr 15, 2011
I have a Royal digital machine it will grind coffee for an extended period then stops and displays out of beans.Although there are still beans in the hoper, pull the brew draw out and the ground coffee...
Try this first. Empty the brew unit of any coffee. Then pull the lever at the top center of the door with the + & - on it to the -. then make a coffee. There is a micro swithh in the doser box that can get coffee dust a in it and not operate properly. It may need to be replaced.
Oct 30, 2010 | Saeco Royal Digital Plus Coffee...
Saeco Royal=,beans do not appear to be grinding, machine whirs for 30 seconds then says add beans have tried 2 different types beans after cleaning bean hopper works first 2 coffees ok then stops
Coffee Beans were roasted by local business,believe they were either not roasted enough or over roasted causing the problem, I have since tried Supermarket(Vittoria Roasted Beans) and machine is working perfectly.
Thankyou
Keviroy
Oct 02, 2009 | Saeco Royal Professional Espresso Machine
Royal machine ventilate
Open the hot water valve to allow the pump to prime.
Sep 15, 2009 | Saeco Royal Digital Plus Coffee...
Saeco royal cappuccino coffee machine beans container empty fault
Hi
More than likely your grind is to fine. Push the lever back 1 # larger(Higher #). If you want stronger coffee, push the doser lever on the door to the back then pull forward 1 click.
Oct 30, 2008 | Saeco Royal Cappuccino Espresso Machine
Saeco magic comfort coffee machine grinder
Make sure you not get any water in the grinder, if you got water in the grinder then you have to clean it.
You can try to set grinding to coarse and try to make 3 cup of coffee.
Jul 22, 2008 | Saeco Magic De Luxe Espresso Machine
"COF. BEANS EMPTY" message
Here is a link for completely cleaning the grinder - this often fixes the problem:
http://www.cerinicoffee.com/Saeco_technical_documents.asp
Nov 12, 2007 | Saeco Royal Digital Plus Coffee...
The machine won't start up
in the self test does it flush the unit ? If not you have to prime the unit by allowing it to pump hot water through the frothing valve. Open the valve and the pump should pulse water out. After this the machine should indicate it is in the operating mode for coffee
Jun 20, 2007 | Saeco Royal Professional Espresso Machine
Coffee beans empty
Try changing the beans to a different brand I had this same problem with the brands that were around $30 a kilo but not with the cheaper ones. They seem to clump together and not drop in to feed the grinder. It could be that you just need to adjust either the internal or external grinder settings also.
Mar 20, 2007 | Saeco Royal Digital Plus Coffee...
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
629 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
