Question about Vizio P50HDTV10A 50 in. Plasma HDTV
Flashing from green to amber about ten times AND PULSING BLACK SCREEN.
    President:
  • 2,923 Answers
You are saying that you don't have a display on your Plasma TV? Are you still getting sound even without a display? If you do, then the problem has is the inverter board.
If you don't have a display and no sound, then the problem is the power supply for vented caps.
If the TV is still under the warranty, take advantage of it, contact the manufacturer for free repair.
But if not, contact a repair tech and have it repaired. Replacing the inverter board should not costs too much. Inverter board costs $80 or less.
Have a great day!
Posted on Sep 29, 2009
My acer desktop computer screen is black, the power says it is on but no pic, keeps cutting off, tried to back up and restore, cut off, says problem with windows and it shut off as well, HELP!
  • When the computer will not boot up, it sound like it is booting as the CPU fan is running and the lights are on. It also finds the CD ROM but it won't boot from a CD either.
  • Sometimes when you have a computer black screen on startup and the power switch light will be green and then turns to orange or amber. Everything is running.
  • Everything seems to be running but you can't see anything on the screen, not even a flashing cursor. Your black screen in Windows has occurred before the Windows logo screen:
  • 1- adapter or video card
  • 2-RAM
  • 3-and Black screen on startup with an amber flashing light
  • Not enough power getting to the motherboard.
  • A dead power supply.
  • A bent pin or shorted out USB port causing a problem.
Apr 09, 2013 | Acer AX1430-UD30P Desktop Computer With...
When i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked...
when i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked normally after being off for a couple of days, but now it is doing that again.
Amber light flashes 7 times, then green for a couple of seconds, then amber 7 times etc.
Jun 02, 2010 | Canon BJ I6500 InkJet Printer
Status light is red, why? I have a Roomba Discovery.
Hi.
If the red light is solid, that means that the Roomba is near to full discharge. If the light is flashing red, then the Roomba is completely out of charge.
If the Roomba is fully charged, then there may be a fault.
Here full list of light codes:
Pulsing Amber - Charging
Green - Fully Charged
Amber - Partially Discharged
Red - Almost Fully Discharged
Flashing Red - Fully Discharged"
Here manual
See also
Roomba DISCOVERY MODELS' DIAGNOSTIC TESTS
May 24, 2010 | Vacuums
Flashing amber light on printer
As you give print command check what is the error msg flashes on ur PC.
Next check whether any paper piece is jammed inside the printer, dust it with Airblower so that cleans out.
Third check the ink levels in both color and black cartdriges.
Regards
Oct 03, 2009 | Office Equipment & Supplies
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Happy turkey day, I have a westinghouse lcm-19w4,when I turn it on the screen flashes gray horizontal lines in the middle of the screen for a second then goes black. this happens a couple times then the...
You either have a hardware problem with your video card. ( may have pop out of socket when you plug in the monitor) or the cable is not allow communication to the monitor. As long as the amber light comes on you know you have power so focud on data cables and hardware.
Nov 27, 2008 | Computers & Internet
Canon i320 amber light flashing will not print
I believe that 7 amber flashes refer to a cartridge error. Check that the cartridge is seated correctly.
Nov 05, 2008 | Canon i80 InkJet Printer
MY SONY LAPTOP WONT BOOT
The flashing amber light means the screen is in power save mode. Since you are not seeing a "No Video Signal" things are looking up.
You want to use the menu buttons on your screen to navigate through and locate the power save time out settings. Its best to set it for 'never'.
If that makes the change a fix, let me know, I'll guide you through the settings on your desktop display to control the display time out.
Regards,
Worldvet
Jul 24, 2008 | Computers & Internet
Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Feb 24, 2008 | Gateway FPD2275W LCD Monitor
Black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Jan 12, 2008 | Dell OptiPlex GX270 PC Desktop
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
46 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
